path: root/board/ms7750se
2009-01-16sh: Fix compile error on lowlevel_init fileNobuhiro Iwamatsu
lowlevel_init of SH was corrected to use the write/readXX macro. However, there was a problem that was not able to be compiled partially. This patch corrected this. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-01-16sh: use write{8,16,32} in all lowlevel_initJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-01-16sh: lowlevel_init coding style cleanupJean-Christophe PLAGNIOL-VILLARD
2008-07-08sh: Fix SH-boards compile errorNobuhiro Iwamatsu
By Cleanup out-or-tree building for some boards (.depend) (commit:c8a3b109f07f02342d097b30908965f7261d9f15) because filse ware changed, some SH-boards have compile error. I revised this problem. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-07-02Cleanup: fix out-of-tree building for some boardsWolfgang Denk
2008-07-02Cleanup: replace hard-wired $(AR) 'crv' settings by $(ARFLAGS)Wolfgang Denk
2007-12-27Fix coding style issues; update CHANGELOG.Wolfgang Denk
2007-09-23sh: Update MS7750SE01 platformNobuhiro Iwamatsu
2007-05-13sh: MS7750SE support.Nobuhiro Iwamatsu
This adds support for the Hitachi MS7750SE. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
