path: root/board/ms7722se
2014-11-13sh: consolidate CONFIG_SYS_CPU definesMasahiro Yamada
Now each board selects one of CONFIG_CPU_SH2, CONFIG_CPU_SH3, CONFIG_CPU_SH4, so let's move CONFIG_SYS_CPU definition to arch/sh/Kconfig. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2013-10-31sh: convert makefiles to Kbuild styleMasahiro Yamada
2011-02-02sh: Remove config.mk for ms7722se boardNobuhiro Iwamatsu
Move CONFIG_SYS_TEXT_BASE to the board's config file, and remove the unnecessary config.mk file. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2010-12-21Move DECLARE_GLOBAL_DATA_PTR to file scopeJohn Rigby
It can be optimised out by the compiler otherwise resulting in obscure errors like a board not booting. This has been documented in README since 2006 when these were first fixed up for GCC 4.x. Signed-off-by: John Rigby <john.rigby@linaro.org> Fix some additional places. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-By: Albert ARIBAUD <albert.aribaud@free.fr>
2009-10-04Convert SMC91111 Ethernet driver to CONFIG_NET_MULTI APIBen Warren
All in-tree boards that use this controller have CONFIG_NET_MULTI added Also: - changed CONFIG_DRIVER_SMC91111 to CONFIG_SMC91111 - cleaned up line lengths - modified all boards that override weak function in this driver - modified all eeprom standalone apps to work with new driver - updated blackfin standalone EEPROM app after testing Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-07-08sh: unify linker scriptJean-Christophe PLAGNIOL-VILLARD
all sh boards use the same cpu linker script so move it to cpu/$(CPU) that could be overwrite in following order SOC BOARD via the corresponding config.mk tested on r2dplus Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-07-08sh: make the linker scripts more genericJean-Christophe PLAGNIOL-VILLARD
currently we need to sync the linker script enty and TEXT_BASE manualy and the reloc_dst is based on it instead provide it now from the ldflags tested on r2dplus Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-01-16sh: Fix compile error on lowlevel_init fileNobuhiro Iwamatsu
lowlevel_init of SH was corrected to use the write/readXX macro. However, there was a problem that was not able to be compiled partially. This patch corrected this. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-01-16sh: use write{8,16,32} in all lowlevel_initJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-01-16sh: lowlevel_init coding style cleanupJean-Christophe PLAGNIOL-VILLARD
2008-09-19sh: Fix compile warningNobuhiro Iwamatsu
2008-07-08sh: Fix SH-boards compile errorNobuhiro Iwamatsu
By Cleanup out-or-tree building for some boards (.depend) (commit:c8a3b109f07f02342d097b30908965f7261d9f15) because filse ware changed, some SH-boards have compile error. I revised this problem. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-07-07sh: Cleanup source code of MS7722SENobuhiro Iwamatsu
Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-07-02Cleanup: fix out-of-tree building for some boardsWolfgang Denk
2008-07-02Cleanup: replace hard-wired $(AR) 'crv' settings by $(ARFLAGS)Wolfgang Denk
2007-12-27Fix coding style issues; update CHANGELOG.Wolfgang Denk
2007-09-23sh: Add support Renesas sh7722 processor and Hitachi MS7722SE01 boardNobuhiro Iwamatsu
