path: root/board/ms7720se
2014-11-13sh: consolidate CONFIG_SYS_CPU definesMasahiro Yamada
Now each board selects one of CONFIG_CPU_SH2, CONFIG_CPU_SH3, CONFIG_CPU_SH4, so let's move CONFIG_SYS_CPU definition to arch/sh/Kconfig. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2013-10-31sh: convert makefiles to Kbuild styleMasahiro Yamada
2011-02-02sh: Remove config.mk for ms7720se boardNobuhiro Iwamatsu
Move CONFIG_SYS_TEXT_BASE to the board's config file, and remove the unnecessary config.mk file. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2010-12-21Move DECLARE_GLOBAL_DATA_PTR to file scopeJohn Rigby
It can be optimised out by the compiler otherwise resulting in obscure errors like a board not booting. This has been documented in README since 2006 when these were first fixed up for GCC 4.x. Signed-off-by: John Rigby <john.rigby@linaro.org> Fix some additional places. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-By: Albert ARIBAUD <albert.aribaud@free.fr>
2010-08-30sh: Update lowlevel_init.S of ms7720seNobuhiro Iwamatsu
Fix data size. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2009-07-08sh: unify linker scriptJean-Christophe PLAGNIOL-VILLARD
all sh boards use the same cpu linker script so move it to cpu/$(CPU) that could be overwrite in following order SOC BOARD via the corresponding config.mk tested on r2dplus Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-07-08sh: make the linker scripts more genericJean-Christophe PLAGNIOL-VILLARD
currently we need to sync the linker script enty and TEXT_BASE manualy and the reloc_dst is based on it instead provide it now from the ldflags tested on r2dplus Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-03-12sh: use write{8,16,32} in ms7720se lowlevel_initNobuhiro Iwamatsu
Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-07-08sh: Fix SH-boards compile errorNobuhiro Iwamatsu
By Cleanup out-or-tree building for some boards (.depend) (commit:c8a3b109f07f02342d097b30908965f7261d9f15) because filse ware changed, some SH-boards have compile error. I revised this problem. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-07-07sh: Cleanup source code of MS7720SENobuhiro Iwamatsu
2008-07-02Cleanup: fix out-of-tree building for some boardsWolfgang Denk
2008-07-02Cleanup: replace hard-wired $(AR) 'crv' settings by $(ARFLAGS)Wolfgang Denk
2008-01-15sh: Fix board name in MS7720SE's config.mkNobuhiro Iwamatsu
2008-01-15sh: Add support for MS7720RP02 boardYoshihiro Shimoda
Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
