path: root/board/ms7720se/Makefile
2013-10-31sh: convert makefiles to Kbuild styleMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2008-07-08sh: Fix SH-boards compile errorNobuhiro Iwamatsu
By Cleanup out-or-tree building for some boards (.depend) (commit:c8a3b109f07f02342d097b30908965f7261d9f15) because filse ware changed, some SH-boards have compile error. I revised this problem. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-07-02Cleanup: fix out-of-tree building for some boardsWolfgang Denk
2008-07-02Cleanup: replace hard-wired $(AR) 'crv' settings by $(ARFLAGS)Wolfgang Denk
2008-01-15sh: Add support for MS7720RP02 boardYoshihiro Shimoda
Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
