path: root/board/mqmaker
2017-04-04rockchip: Add support for MiQi rk3288 boardJernej Skrabec
MiQi is rk3288 based development board with 1 or 2 GB SDRAM, 16 GB eMMC, micro SD card interface, 4 USB 2.0 ports, HDMI, gigabit Ethernet and expansion ports. Signed-off-by: Jernej Skrabec <jernej.skrabec@siol.net> Reviewed-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Eddie Cai <eddie.cai.linux@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
