path: root/board/mpl
2015-11-05video: Drop DEV_FLAGS_SYSTEM flagBin Meng
DEV_FLAGS_SYSTEM does not have any actual meaning, hence drop it. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-03-24remove unnecessary version.h includesRob Herring
Various files are needlessly rebuilt every time due to the version and build time changing. As version.h is not actually needed, remove the include. Signed-off-by: Rob Herring <robh@kernel.org> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Stefano Babic <sbabic@denx.de> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Marek Vasut <marex@denx.de> Cc: Tom Warren <twarren@nvidia.com> Cc: Michal Simek <monstr@monstr.eu> Cc: Macpaul Lin <macpaul@andestech.com> Cc: Wolfgang Denk <wd@denx.de> Cc: York Sun <yorksun@freescale.com> Cc: Stefan Roese <sr@denx.de> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Cc: Simon Glass <sjg@chromium.org> Cc: Philippe Reynes <tremyfr@yahoo.fr> Cc: Eric Jarrige <eric.jarrige@armadeus.org> Cc: "David Müller" <d.mueller@elsoft.ch> Cc: Phil Edworthy <phil.edworthy@renesas.com> Cc: Robert Baldyga <r.baldyga@samsung.com> Cc: Torsten Koschorrek <koschorrek@synertronixx.de> Cc: Anatolij Gustschin <agust@denx.de> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Reviewed-by: Łukasz Majewski <l.majewski@samsung.com>
2014-10-29kconfig: arm: introduce symbol for ARM CPUsGeorges Savoundararadj
This commit introduces a Kconfig symbol for each ARM CPU: CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136, CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100. Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected for CPU_ARM1176 and CPU_V7. For each target, the corresponding CPU is selected and the definition of SYS_CPU in the corresponding Kconfig file is removed. Also, it removes redundant "string" type in some Kconfig files. Signed-off-by: Georges Savoundararadj <savoundg@gmail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-10-10PATI: fix broken SPI accessDavid Müller (ELSOFT AG)
fix broken SPI access by adding/activating BOARD_EARLY_INIT_F functionality and calling spi_init_f() from there. Signed-off-by: David Müller <d.mueller@elsoft.ch>
2014-09-24MAINTAINERS: comment out blank M: fieldMasahiro Yamada
Since commit ddaf5c8f3030050fcd356a1e49e3ee8f8f52c6d4 (patman: RunPipe() should not pipe stdout/stderr unless asked), Patman spits lots of "Invalid MAINTAINERS address: '-'" error messages for patches with global changes. It takes too long for Patman to process them. Anyway, "M: -" does not carry any important information. Rather, it is just like a place holder in case of assigning a new board maintainer. Let's comment out. This commit can be reproduced by the following command: find . -name MAINTAINERS | xargs sed -i -e '/^M:[[:blank:]]*-$/s/^/#/' Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-07-23stdio: Pass device pointer to stdio methodsSimon Glass
At present stdio device functions do not get any clue as to which stdio device is being acted on. Some implementations go to great lengths to work around this, such as defining a whole separate set of functions for each possible device. For driver model we need to associate a stdio_dev with a device. It doesn't seem possible to continue with this work-around approach. Instead, add a stdio_dev pointer to each of the stdio member functions. Note: The serial drivers have the same problem, but it is not strictly necessary to fix that to get driver model running. Also, if we convert serial over to driver model the problem will go away. Code size increases by 244 bytes for Thumb2 and 428 for PowerPC. 22: stdio: Pass device pointer to stdio methods arm: (for 2/2 boards) all +244.0 bss -4.0 text +248.0 powerpc: (for 1/1 boards) all +428.0 text +428.0 Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Marek Vasut <marex@denx.de> Reviewed-by: Marek Vasut <marex@denx.de>
2014-07-23stdio: Remove redundant code around stdio_register() callsSimon Glass
There is no point in setting a structure's memory to NULL when it has already been zeroed with memset(). Also, there is no need to create a stub function for stdio to call - if the function is NULL it will not be called. This is a clean-up, with no change in functionality. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Marek Vasut <marex@denx.de>
2014-07-07vcma9/lowlevel_init.S: trivial: terminate commentJeroen Hofstee
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-03-10usb: create common header virtual root hub descriptorsStephen Warren
Many USB host controller drivers contain almost identical copies of the same virtual root hub descriptors. Put these into a common file to avoid duplication. Note that there were some very minor differences between the descriptors in the various files, such as: - USB 1.0 vs. USB 1.1 - Manufacturer/Device ID - Max packet size - String content I assume these aren't relevant. Cc: Thomas Lange <thomas@corelatus.se> Cc: Shinya Kuribayashi <skuribay@pobox.com> Cc: Gary Jennejohn <garyj@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Eric Millbrandt <emillbrandt@coldhaus.com> Cc: Pierre Aubert <p.aubert@staubli.com> Cc: Stefan Roese <sr@denx.de> Cc: Daniel Hellstrom <daniel@gaisler.com> Cc: Denis Peter <d.peter@mpl.ch> Cc: Rodolfo Giometti <giometti@linux.it> Cc: Zhang Wei <wei.zhang@freescale.com> Cc: Mateusz Zalega <m.zalega@samsung.com> Cc: Remy Bohmer <linux@bohmer.net> Cc: Markus Klotzbuecher <mk@denx.de> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Gary Jennejohn <garyj@denx.de> Cc: C Nauman <cnauman@diagraph.com> Cc: David Müller <d.mueller@elsoft.ch> Cc: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Cc: Thomas Abraham <t-abraham@ti.com> Cc: Tom Rini <trini@ti.com> Cc: Andrew Murray <amurray@embedded-bits.co.uk> Cc: Matej Frančeškin <matej.franceskin@comtrade.com> Cc: Cliff Cai <cliff.cai@analog.com> Cc: Bryan Wu <cooloney@gmail.com> Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
2014-02-26arm: remove unneeded symbol offsets and _TEXT_BASEAlbert ARIBAUD
Remove the last uses of symbol offsets in ARM U-Boot. Remove some needless uses of _TEXT_BASE. Remove all _TEXT_BASE definitions. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2014-01-24Remove obsolete _LINUX_CONFIG_H macroMasahiro Yamada
Commit 643aae1406c93ddc64fcf8c136b47cdffd9c8ccd deleted include/linux/config.h but missed to delete _LINUX_CONFIG_H macro. It is no longer used at all. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-17Makefile: make directories by Makefile.buildMasahiro Yamada
2013-11-08cosmetic: remove empty lines at the top of fileMasahiro Yamada
2013-10-20usb: add enum usb_init_type parameter to usb_lowlevel_initTroy Kisky
This parameter will later be used to verify OTG ports. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2013-09-20SPDX: fix IBM-pibs license identifierWolfgang Denk
The SPDX License List version 1.19 now contains an official entry for the IBM-pibs license. However, instead of our suggestion "ibm-pibs", the SPDX License List uses "IBM-pibs", with the following rationale: "The reason being that all other SPDX License List short identifiers tend towards using capital letters unless spelling a word. I'd prefer to be consistent to this end". Change the license IDs to use the official name. Signed-off-by: Wolfgang Denk <wd@denx.de>
2013-08-19SPDX-License-Identifier: convert PIBS licensed filesWolfgang Denk
This commit adapts the files that were derived from PIBS (PowerPC Initialization and Boot Software) codeto using SPDX License Identifiers. So far, SPDX has not assigned an official License ID for the PIBS license yet, so this should be considered preliminary. Note that the following files contained incorrect license information: arch/powerpc/cpu/ppc4xx/4xx_uart.c arch/powerpc/cpu/ppc4xx/start.S arch/powerpc/include/asm/ppc440.h These files included, in addition to the GPL-2.0 / ibm-pibs dual license as inherited from PIBS, a GPL-2.0+ license header which was obviously incorrect. This has been removed. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Wolfgang Denk <wd@denx.de> Conflicts: Licenses/README Acked-by: Stefan Roese <sr@denx.de>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23i2c, ppc4xx_i2c: switch to new multibus/multiadapter supportDirk Eibach
Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Heiko Schocher <hs@denx.de> Cc: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2013-04-02replace last __bss_end__ occurrences with __bss_endAlbert ARIBAUD
Simon Glass' commit 3929fb0a141530551b3fce15ee08629f80d5ef2a, which changed all occurrences of __bss__end__ into __bss_end, left behind some untouched __bss_end__ occurrences in all 33 u-boot.lds.debug files, in board/mousse/u-boot.lds.ram and in board/mousse/u-boot.lds.rom. These are replaced here. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-04-01Consolidate bool typeYork Sun
'bool' is defined in random places. This patch consolidates them into a single header file include/linux/types.h, using stdbool.h introduced in C99. All other #define, typedef and enum are removed. They are all consistent with true = 1, false = 0. Replace FALSE, False with false. Replace TRUE, True with true. Skip *.py, *.php, lib/* files. Signed-off-by: York Sun <yorksun@freescale.com>
2013-03-12Refactor linker-generated arraysAlbert ARIBAUD
Refactor linker-generated array code so that symbols which were previously linker-generated are now compiler- generated. This causes relocation records of type R_ARM_ABS32 to become R_ARM_RELATIVE, which makes code which uses LGA able to run before relocation as well as after. Note: this affects more than ARM targets, as linker- lists span possibly all target architectures, notably PowerPC. Conflicts: arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds arch/arm/cpu/armv7/omap-common/u-boot-spl.lds board/ait/cam_enc_4xx/u-boot-spl.lds board/davinci/da8xxevm/u-boot-spl-da850evm.lds board/davinci/da8xxevm/u-boot-spl-hawk.lds board/vpac270/u-boot-spl.lds Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2012-10-22common: Discard the __u_boot_cmd sectionMarek Vasut
The command declaration now uses the new LG-array method to generate list of commands. Thus the __u_boot_cmd section is now superseded and redundant and therefore can be removed. Also, remove externed symbols associated with this section from include/command.h . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-22common: Add .u_boot_list into all linker filesMarek Vasut
Add section for the linker-generated lists into all possible linker files, so that everyone can easily use these lists. This is mostly a mechanical adjustment. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-15usb: lowlevel interface change to support multiple controllersLucas Stach
Carry an index in the lowlevel usb functions to make specify the respective usb controller. Also pass through an controller struct from lowlevel_init to the creation of the root usb device of this controller. Signed-off-by: Lucas Stach <dev@lynxeye.de> Reviewed-by: Marek Vasut <marex@denx.de>
2012-07-29doc: cleanup - move board READMEs into respective board directoriesWolfgang Denk
Also drop a few files referring to no longer / not yet supported boards. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Stefan Roese <sr@denx.de> Cc: Kim Phillips <kim.phillips@freescale.com> Cc: Andy Fleming <afleming@gmail.com> Cc: Jason Jin <jason.jin@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
2012-03-19usb: replace wait_ms() with mdelay()Mike Frysinger
Common code has a mdelay() func, so use that instead of the usb-specific wait_ms() func. This also fixes the build errors: ohci-hcd.c: In function 'submit_common_msg': /usr/local/src/u-boot/blackfin/include/usb.h:202:44: sorry, unimplemented: inlining failed in call to 'wait_ms': function body not available ohci-hcd.c:1519:9: sorry, unimplemented: called from here /usr/local/src/u-boot/blackfin/include/usb.h:202:44: sorry, unimplemented: inlining failed in call to 'wait_ms': function body not available ohci-hcd.c:1816:10: sorry, unimplemented: called from here /usr/local/src/u-boot/blackfin/include/usb.h:202:44: sorry, unimplemented: inlining failed in call to 'wait_ms': function body not available ohci-hcd.c:1827:10: sorry, unimplemented: called from here /usr/local/src/u-boot/blackfin/include/usb.h:202:44: sorry, unimplemented: inlining failed in call to 'wait_ms': function body not available ohci-hcd.c:1844:10: sorry, unimplemented: called from here /usr/local/src/u-boot/blackfin/include/usb.h:202:44: sorry, unimplemented: inlining failed in call to 'wait_ms': function body not available ohci-hcd.c:1563:11: sorry, unimplemented: called from here /usr/local/src/u-boot/blackfin/include/usb.h:202:44: sorry, unimplemented: inlining failed in call to 'wait_ms': function body not available ohci-hcd.c:1583:9: sorry, unimplemented: called from here make[1]: *** [ohci-hcd.o] Error 1 Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Marek Vasut <marex@denx.de>
2012-01-09board/mpl/pati: use the CFI driver for the PATI boardDavid Müller
Signed-off-by: David Mueller <d.mueller@elsoft.ch> Signed-off-by: Stefan Roese <sr@denx.de>
2012-01-09board/mpl/mip405: use the CFI driver for the MIP405/MIP405T boardDavid Müller
2012-01-09board/mpl/pip405: use the CFI driver for the PIP405 boardDavid Müller
2012-01-09board/mpl/common: remove the old legacy flashDavid Müller
2011-12-12board/mpl/common/isa.c: Fix GCC 4.6 build warningsDavid Müller (ELSOFT AG)
Fix: ../common/isa.c: In function 'handle_isa_int': ../common/isa.c:385:21: warning: variable 'isr2' set but not used [-Wunused-but-set-variable] ../common/isa.c:385:16: warning: variable 'isr1' set but not used [-Wunused-but-set-variable] Signed-off-by: David Mueller <d.mueller@elsoft.ch>
2011-12-02board/mpl/common/flash.c: Fix GCC 4.6 build warningWolfgang Denk
Fix: ../common/flash.c: In function 'flash_init': ../common/flash.c:160:16: warning: variable 'size_b1' set but not used [-Wunused-but-set-variable] Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Denis Peter <d.peter@mpl.ch> Acked-by: Marek Vasut <marek.vasut@gmail.com>
2011-11-16pip405.c: Fix GCC 4.6 build warningsStefan Roese
Fix: pip405.c: In function 'board_early_init_f': pip405.c:192:16: warning: variable 'tctp_clocks' set but not used [-Wunused-but-set-variable] pip405.c:182:16: warning: variable 'dataout' set but not used [-Wunused-but-set-variable] Signed-off-by: Stefan Roese <sr@denx.de>
2011-11-16mip405.c: Fix GCC 4.6 build warningsStefan Roese
Fix: mip405.c: In function 'init_sdram': mip405.c:250:4: warning: variable 'tctp_clocks' set but not used [-Wunused-but-set-variable] mip405.c: In function 'initdram': mip405.c:629:9: warning: variable 'ds' set but not used [-Wunused-but-set-variable] Signed-off-by: Stefan Roese <sr@denx.de>
2011-11-08ARM: remove superfluous setting of arch_number in board specific code.David Müller (ELSOFT AG)
2011-11-07board/mpl/common/flash.c: fix GCC 4.6 build warningWolfgang Denk
Fix: ../common/flash.c: In function 'flash_erase': ../common/flash.c:603:24: warning: variable 'l_sect' set but not used [-Wunused-but-set-variable] Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Denis Peter <d.peter@mpl.ch>
2011-08-04Convert ISO-8859 files to UTF-8Albert ARIBAUD
There was a mix of UTF-8 and ISO-8859 files in the U-Boot source tree, which could cause issues with the patchwork review system. This commit converts all ISO-8859 files to UTF-8. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-07-28cleanup: Fix typos and misspellings in various files.Mike Williams
Recieve/Receive recieve/receive Interupt/Interrupt interupt/interrupt Addres/Address addres/address Signed-off-by: Mike Williams <mike@mikebwilliams.com>
2011-07-04VCMA9: various cleanups/code style fixesDavid Müller (ELSOFT AG)
2011-07-04VCMA9: use CFI driver (and remove the old one)David Müller (ELSOFT AG)
2011-07-04VCMA9: remove unneeded config.mkDavid Müller (ELSOFT AG)
2011-03-27rename _end to __bss_end__Po-Yu Chuang
Currently, _end is used for end of BSS section. We want _end to mean end of u-boot image, so we rename _end to __bss_end__ first. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2010-12-09Remove redundant config.mk filesWolfgang Denk
Recent cleanup actions resulted in a number of config.mk files that contained only redundant entries like PLATFORM_CPPFLAGS += -I$(TOPDIR) or settings of variables that were not used anywhere in the code, like TEXT_END = 0xfe080000 Remove these unnecessary files. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Scott McNutt <smcnutt@psyent.com> Cc: Wolfgang Wegner <w.wegner@astro-kom.de> Cc: Josef Wagner <Wagner@Microsys.de> Cc: Tolunay Orkun <torkun@nextio.com> Cc: Frank Panno <fpanno@delphintech.com> Cc: Heiko Schocher <hs@denx.de> Cc: Brad Kemp <Brad.Kemp@seranoa.com> Acked-by: Heiko Schocher<hs@denx.de>
