path: root/board/mpl
2011-11-08ARM: remove superfluous setting of arch_number in board specific code.David Müller (ELSOFT AG)
Signed-off-by: David Mueller <d.mueller@elsoft.ch>
2011-11-07board/mpl/common/flash.c: fix GCC 4.6 build warningWolfgang Denk
Fix: ../common/flash.c: In function 'flash_erase': ../common/flash.c:603:24: warning: variable 'l_sect' set but not used [-Wunused-but-set-variable] Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Denis Peter <d.peter@mpl.ch>
2011-08-04Convert ISO-8859 files to UTF-8Albert ARIBAUD
There was a mix of UTF-8 and ISO-8859 files in the U-Boot source tree, which could cause issues with the patchwork review system. This commit converts all ISO-8859 files to UTF-8. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-07-28cleanup: Fix typos and misspellings in various files.Mike Williams
Recieve/Receive recieve/receive Interupt/Interrupt interupt/interrupt Addres/Address addres/address Signed-off-by: Mike Williams <mike@mikebwilliams.com>
2011-07-04VCMA9: various cleanups/code style fixesDavid Müller (ELSOFT AG)
Signed-off-by: David Müller <d.mueller@elsoft.ch>
2011-07-04VCMA9: use CFI driver (and remove the old one)David Müller (ELSOFT AG)
2011-07-04VCMA9: remove unneeded config.mkDavid Müller (ELSOFT AG)
2011-03-27rename _end to __bss_end__Po-Yu Chuang
Currently, _end is used for end of BSS section. We want _end to mean end of u-boot image, so we rename _end to __bss_end__ first. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2010-12-09Remove redundant config.mk filesWolfgang Denk
Recent cleanup actions resulted in a number of config.mk files that contained only redundant entries like PLATFORM_CPPFLAGS += -I$(TOPDIR) or settings of variables that were not used anywhere in the code, like TEXT_END = 0xfe080000 Remove these unnecessary files. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Scott McNutt <smcnutt@psyent.com> Cc: Wolfgang Wegner <w.wegner@astro-kom.de> Cc: Josef Wagner <Wagner@Microsys.de> Cc: Tolunay Orkun <torkun@nextio.com> Cc: Frank Panno <fpanno@delphintech.com> Cc: Heiko Schocher <hs@denx.de> Cc: Brad Kemp <Brad.Kemp@seranoa.com> Acked-by: Heiko Schocher<hs@denx.de>
2010-10-28Add generic support for samsung s3c2440C Nauman
This patch adds generic support for the Samsung s3c2440 processor. Global s3c24x0 changes to struct members converting from upper case to lower case. Signed-off-by: Craig Nauman <cnauman@diagraph.com> Cc: kevin.morfitt@fearnside-systems.co.uk Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2010-10-06board/mpl: Remove mpl-specific memory test commandPeter Tyser
The mpl-specfic memory test is only documented for one board, doesn't compile cleanly, uses improper coding style, and overlaps functionality with U-Boot's common 'mtest' command, so lets get rid of it. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> CC: d.peter@mpl.ch CC: d.mueller@elsoft.ch CC: wd@denx.de
2010-09-23ppc4xx: Big header cleanup part 2, mostly PPC405 relatedStefan Roese
This cleanup is done by creating header files for all SoC versions and moving the SoC specific defines into these special headers. This way the common header ppc405.h and ppc440.h can be cleaned up finally. As a part from this cleanup, the GPIO definitions for PPC405EP are corrected. The high and low parts of the registers (for example CONFIG_SYS_GPIO0_OSRL vs. CONFIG_SYS_GPIO0_OSRH) have been defined in the wrong order. This patch now fixes this issue by switching these xxxH and xxxL values. This brings the GPIO 405EP port in sync with all other PPC4xx ports. Signed-off-by: Stefan Roese <sr@denx.de>
2010-09-23ppc4xx: Move ppc4xx headers to powerpc include directoryStefan Roese
This patch moves some ppc4xx related headers from the common include directory (include/) to the powerpc specific one (arch/powerpc/include/asm/). This way to common include directory is not so cluttered with files. Signed-off-by: Stefan Roese <sr@denx.de>
2010-08-04Rename getenv_r() into getenv_f()Wolfgang Denk
While running from flash, i. e. before relocation, we have only a limited C runtime environment without writable data segment. In this phase, some configurations (for example with environment in EEPROM) must not use the normal getenv(), but a special function. This function had been called getenv_r(), with the idea that the "_r" suffix would mean the same as in the _r_eentrant versions of some of the C library functions (for example getdate vs. getdate_r, getgrent vs. getgrent_r, etc.). Unfortunately this was a misleading name, as in U-Boot the "_r" generally means "running from RAM", i. e. _after_ relocation. To avoid confusion, rename into getenv_f() [as "running from flash"] Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2010-07-24cmd_usage(): simplify return code handlingWolfgang Denk
Lots of code use this construct: cmd_usage(cmdtp); return 1; Change cmd_usage() let it return 1 - then we can replace all these ocurrances by return cmd_usage(cmdtp); This fixes a few places with incorrect return code handling, too. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-13Move lib_$ARCH directories to arch/$ARCH/libPeter Tyser
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk This change is intended to clean up the top-level directory structure and more closely mimic Linux's directory organization. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-12-21move prototypes for gunzip() and zunzip() to common.hWolfgang Wegner
Prototype for gunzip/zunzip was only in lib_generic/gunzip.c and thus repeated in every file using it. This patch moves the prototypes to common.h and removes all prototypes distributed anywhere else. Signed-off-by: Wolfgang Wegner <w.wegner@astro-kom.de>
2009-12-07POST: Remove duplicated post_hotkey_pressed() functionsStefan Roese
This patch introduces a weak default function for post_hotkey_pressed(), returning 0, for boards without hotkey support. The long-running tests won't be started on those boards. This default function was implemented in many board directories. By implementing this weak default we can remove all those duplicate versions. Boards with hotkey support, can override this weak default function by defining one in their board specific code. Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-27Add a unified s3c24x0 header filekevin.morfitt@fearnside-systems.co.uk
This patch adds a unified s3c24x0 cpu header file that selects the header file for the specific s3c24x0 cpu from the SOC and CPU configs defined in board config file. This removes the current chain of s3c24-type #ifdef's from the s3c24x0 code. Signed-off-by: Kevin Morfitt <kevin.morfitt@fearnside-systems.co.uk> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2009-11-27Clean-up of s3c24x0 header fileskevin.morfitt@fearnside-systems.co.uk
Cleans up the s3c24x0 header files: s4c24x0.h: removes the use of 'volatile' from the S3C24X0_REG8, S3C24X0_REG16 and S3C24X0_REG32 register typedef's. Registers are always accessed using the IO accessor functions which cast the register address as 'volatile' anyway so it isn't required here. s3c2400.h and s3c2410.h: insert a blank line between the static inline functions Signed-off-by: Kevin Morfitt <kevin.morfitt@fearnside-systems.co.uk>
2009-11-27Move s3c24x0 header files to asm-arm/arch-s3c24x0/kevin.morfitt@fearnside-systems.co.uk
This patch moves the s3c24x0 header files from include/ to include/asm-arm/arch-s3c24x0/. checkpatch.pl showed 2 errors and 3 warnings. The 2 errors were both due to a non-UTF8 character in David M?ller's name: ERROR: Invalid UTF-8, patch and commit message should be encoded in UTF-8 #489: FILE: include/asm-arm/arch-s3c24x0/s3c2410.h:3: + * David M?ller ELSOFT AG Switzerland. d.mueller@elsoft.ch As David's name correctly contains a non-UTF8 character I haven't fixed these errors. The 3 warnings were all because of the use of 'volatile' in s3c24x0.h: WARNING: Use of volatile is usually wrong: see Documentation/volatile-considered-harmful.txt #673: FILE: include/asm-arm/arch-s3c24x0/s3c24x0.h:35: +typedef volatile u8 S3C24X0_REG8; +typedef volatile u16 S3C24X0_REG16; +typedef volatile u32 S3C24X0_REG32; I'll fix these errors in another patch. Tested by running MAKEALL for ARM8 targets and ensuring there were no new errors or warnings. Signed-off-by: Kevin Morfitt <kevin.morfitt@fearnside-systems.co.uk> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2009-11-02ppc4xx: Remove board specific linker scripts from most PPC4xx boardsStefan Roese
All these linker scripts can be removed since the new common ppc4xx linker script should be able to handle all of those boards. Please test and report problems. Thanks. Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-02ppc4xx: Fix problems in some ppc4xx board MakefilesStefan Roese
Some 4xx Makefiles didn't add $(SOBJ) to their board library. This was no till now problem, since those boards included this object (init.o most of the time) directly from their linker scripts. This patch clean this up, so that all objects are now collected in the board library. This is in preparation for the upcoming PPC4xx linker script consolidation. Signed-off-by: Stefan Roese <sr@denx.de>
2009-10-13Clean-up of s3c24x0 drivers excluding nand driverkevin.morfitt@fearnside-systems.co.uk
This patch re-formats the arm920t s3c24x0 driver files, excluding the nand driver, in preparation for changes to add support for the Embest SBC2440-II Board. The changes are as follows: - re-indent the code using Lindent - make sure register layouts are defined using a C struct - replace the upper-case typedef'ed C struct names with lower case non-typedef'ed ones - make sure registers are accessed using the proper accessor functions - run checkpatch.pl and fix any error reports It assumes the following patch has been applied first: - [U-Boot][PATCH-ARM] CONFIG_SYS_HZ fix for ARM902T S3C24X0 Boards, 05/09/2009 - patches 1/4 and 2/4 of this series Tested on an Embest SBC2440-II Board with local u-boot patches as I don't have any s3c2400 or s3c2410 boards but need this patch applying before I can submit patches for the SBC2440-II Board. Also, temporarily modified sbc2410x, smdk2400, smdk2410 and trab configs to use the mtd nand driver (which isn't used by any board at the moment), ran MAKEALL for all ARM9 targets and no new warnings or errors were found. Signed-off-by: Kevin Morfitt <kevin.morfitt@fearnside-systems.co.uk> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2009-10-03mpl: Remove memory test relocation fixupsPeter Tyser
2009-10-03ppc: Remove pci config table pointer relocation fixupsPeter Tyser
2009-10-03ppc: Enable full relocation to RAMPeter Tyser
The following changes allow U-Boot to fully relocate from flash to RAM: - Remove linker scripts' .fixup sections from the .text section - Add -mrelocatable to PLATFORM_RELFLAGS for all boards - Define CONFIG_RELOC_FIXUP_WORKS for all boards Previously, U-Boot would partially relocate, but statically initialized pointers needed to be manually relocated. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-09-28ppc4xx: Convert PPC4xx SDRAM defines from lower case to upper caseStefan Roese
The latest PPC4xx register cleanup patch missed some SDRAM defines. This patch now changes lower case UIC defines to upper case. Also some names are changed to match the naming in the IBM/AMCC users manuals (e.g. mem_mcopt1 -> SDRAM0_CFG). Signed-off-by: Stefan Roese <sr@denx.de>
2009-09-28ppc4xx: Convert PPC4xx UIC defines from lower case to upper caseStefan Roese
The latest PPC4xx register cleanup patch missed the UIC defines. This patch now changes lower case UIC defines to upper case. Signed-off-by: Stefan Roese <sr@denx.de>
2009-09-11ppc4xx: Big cleanup of PPC4xx definesStefan Roese
This patch cleans up multiple issues of the 4xx register (mostly DCR, SDR, CPR, etc) definitions: - Change lower case defines to upper case (plb4_acr -> PLB4_ACR) - Change the defines to better match the names from the user's manuals (e.g. cprpllc -> CPR0_PLLC) - Removal of some unused defines Please test this patch intensive on your PPC4xx platform. Even though I tried not to break anything and tested successfully on multiple 4xx AMCC platforms, testing on custom platforms is recommended. Signed-off-by: Stefan Roese <sr@denx.de>
2009-08-25Convert CS8900 Ethernet driver to CONFIG_NET_MULTI APIBen Warren
All in-tree boards that use this controller have CONFIG_NET_MULTI added Also: - changed CONFIG_DRIVER_CS8900 to CONFIG_CS8900 - changed CS8900_BASE to CONFIG_CS8900_BASE - changed CS8900_BUS?? to CONFIG_CS8900_BUS?? - cleaned up line lengths - modified VCMA9 command function that accesses the device - removed MAC address initialization from lib_arm/board.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Tested-by: Wolfgang Denk <wd@denx.de> Acked-by: Wolfgang Denk <wd@denx.de>
2009-08-09Dual-license IBM code contributionsJosh Boyer
It was brought to our attention that U-Boot contains code derived from the IBM OpenBIOS source code originally provided with some of the older PowerPC 4xx development boards. As a result, the original license of this code has been carried in the various files for a number of years in the U-Boot project. IBM is dual-licensing the IBM code contributions already present in U-Boot under either the terms of the GNU General Public License version 2, or the original code license already present. Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2009-07-24ppc4xx: Replace 4xx lowercase SPR referencesMatthias Fuchs
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
2009-07-19PATI board: fix compiler warningsWolfgang Denk
Fix these: pati.c: In function 'checkboard': pati.c:358: warning: pointer targets in passing argument 2 of 'getenv_r' differ in signedness ../common/flash.c: In function 'write_word': ../common/flash.c:824: warning: dereferencing type-punned pointer will break strict-aliasing rules cmd_pati.c: In function 'do_pati': cmd_pati.c:279: warning: 'value' may be used uninitialized in this function Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-19mpl: printing current stdio devices cleanupJean-Christophe PLAGNIOL-VILLARD
Currently the mpl boards duplicate the code to print the current devices from common/console.c; use stdio_print_current_devices() instead Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Edited commit message. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-18MIP405T: fix compile problemWolfgang Denk
The "stdio/device: rework function naming convention" patch (commit 52cb4d4f) broke the MIP405T board; this patch fixes it. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-18stdio/device: rework function naming conventionJean-Christophe PLAGNIOL-VILLARD
So far the console API uses the following naming convention: ======Extract====== typedef struct device_t; int device_register (device_t * dev); int devices_init (void); int device_deregister(char *devname); struct list_head* device_get_list(void); device_t* device_get_by_name(char* name); device_t* device_clone(device_t *dev); ======= which is too generic and confusing. Instead of using device_XX and device_t we change this into stdio_XX and stdio_dev This will also allow to add later a generic device mechanism in order to have support for multiple devices and driver instances. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Edited commit message. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-06-12arm: unify linker scriptJean-Christophe PLAGNIOL-VILLARD
all arm boards except a few use the same cpu linker script so move it to cpu/$(CPU) that could be overwrite in following order SOC BOARD via the corresponding config.mk Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-05-15Fix e-mail address of Gary Jennejohn.Detlev Zundel
Signed-off-by: Detlev Zundel <dzu@denx.de>
2009-03-29VCMA9: fix compile errorsWolfgang Denk
Fix these: cmd_vcma9.c:82: warning: implicit declaration of function 'eth_getenv_enetaddr' cmd_vcma9.c:89: error: 'enetaddr' undeclared (first use in this function) Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-03-20boards: get mac address from environmentMike Frysinger
The boards that get converted here to use the environment for the mac address rather than global data: debris mgcoge mgsuvd muas3001 netstal pn62 sixnet vcma9 xilinx (the ones that use xilinx_enet) Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com> CC: Sangmoon Kim <dogoil@etinsys.com> CC: Heiko Schocher <hs@denx.de> CC: David Mueller <d.mueller@elsoft.ch> CC: Niklaus Giger <niklaus.giger@netstal.com> CC: Wolfgang Grandegger <wg@denx.de> CC: Dave Ellis <DGE@sixnetio.com> CC: Ricardo Ribalda <ricardo.ribalda@uam.es>
