path: root/board/mpc8349itx
2007-07-04Remove obsolete mpc83xx linker scriptsGrant Likely
2007-05-01Fix memory initialization on MPC8349E-mITXTimur Tabi
Define CFG_DDR_SDRAM_CLK_CNTL for the MPC8349E-mITX and MPC8349E-mITX-GP. This allows ddr->sdram_clk_cntl to be properly initialized. This is necessary on some ITX boards, notably those with a revision 3.1 CPU. Also change spd_sdram() in cpu/mpc83xx/spd_sdram.c to not write anything into ddr->sdram_clk_cntl if CFG_DDR_SDRAM_CLK_CNTL is not defined. Signed-off-by: Timur Tabi <timur@freescale.com> Acked-by: Michael Benedict <MBenedict@twacs.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-03-02mpc83xx: Add support for the MPC8349E-mITX-GPTimur Tabi
Add support for the MPC8349E-mITX-GP, a stripped-down version of the MPC8349E-mITX. Bonus features include support for low-boot (BMS bit in HRCW is 0) for the ITX and a README for the ITX and the ITX-GP. Signed-off-by: Timur Tabi <timur@freescale.com>
2007-03-02mpc83xx: Delete sdram_init() for MPC8349E-mITXTimur Tabi
There is no SDRAM on any of the 8349 ITX variants, so function sdram_init() never does anything. This patch deletes it. Signed-off-by: Timur Tabi <timur@freescale.com>
2007-03-02mpc83xx: Remove a redundant semicolon in mpc8349itx.cSam Song
A redundant semicolon existed in mpc8349itx.c should be removed. Signed-off-by: Sam Song <samsongshu@yahoo.com.cn>
2006-11-28mpc83xx: Miscellaneous code style fixesTimur Tabi
Implement various code style fixes and similar changes. Signed-off-by: Timur Tabi <timur@freescale.com>
2006-11-03mpc83xx: Update 83xx to use fsl_i2c.cTimur Tabi
Update the 83xx tree to use I2C support in drivers/fsl_i2c.c. Delete cpu/mpc83xx/i2c.c, include/asm-ppc/i2c.h, and all references to those files. Added multiple I2C bus support to fsl_i2c.c. Signed-off-by: Timur Tabi <timur@freescale.com>
2006-11-03mpc83xx: Replace CFG_IMMRBAR with CFG_IMMRTimur Tabi
Replace all instances of CFG_IMMRBAR with CFG_IMMR, so that the 83xx tree matches the other 8xxx trees. Signed-off-by: Timur Tabi <timur@freescale.com>
2006-11-03mpc83xx: add OF_FLAT_TREE bits to 83xx boardsKim Phillips
add ft_pci_setup, OF_CPU, OF_SOC, OF_TBCLK, and STDOUT_PATH configuration bits to mpc8349emds, mpc8349itx, and mpc8360emds board code. redo environment to use bootm with the fdtaddr for booting ARCH=powerpc kernels by default, and provide default fdtaddr values.
2006-11-03mpc83xx: Fix dual I2C support for the MPC8349ITX, MPC8349EMDS, TQM834x, and ↵Timur Tabi
MPC8360EMDS This patch also adds an improved I2C set_speed(), which handles all clock frequencies. Signed-off-by: Timur Tabi <timur@freescale.com>
2006-11-03mpc83xx: Fix PCI, USB, bootargs for MPC8349E-mITXTimur Tabi
PREREQUISITE PATCHES: * This patch can only be applied after the following patches have been applied: 1) DNX#2006092142000015 "Add support for the MPC8349E-mITX 1/2" 2) DNX#2006092142000024 "Add support for the MPC8349E-mITX 2/2" CHANGELOG: * For the 8349E-mITX, fix some size values in pci_init_board(), enable the clock for the 2nd USB board (Linux kernel will hang otherwise), and fix the CONFIG_BOOTARGS macro. Signed-off-by: Timur Tabi <timur@freescale.com>
2006-11-03mpc83xx: Add support for the MPC8349E-mITXTimur Tabi
PREREQUISITE PATCHES: * This patch can only be applied after the following patches have been applied: 1) DNX#2006090742000024 "Add support for multiple I2C buses" 2) DNX#2006090742000033 "Multi-bus I2C implementation of MPC834x" 3) DNX#2006091242000041 "Additional MPC8349 support for multibus i2c" 4) DNX#2006091242000078 "Add support for variable flash memory sizes on 83xx systems" 5) DNX#2006091242000069 "Add support for Errata DDR6 on MPC 834x systems" CHANGELOG: * Add support for the Freescale MPC8349E-mITX reference design platform. The second TSEC (Vitesse 7385 switch) is not supported at this time. Signed-off-by: Timur Tabi <timur@freescale.com>
