path: root/board/mpc8308_p1m
2019-05-21mpc83xx: Get rid of CONFIG_SYS_DDR_SDRAM_BASEMario Six
CONFIG_SYS_DDR_SDRAM_BASE is set to the same value as CONFIG_SYS_SDRAM_BASE on all existing boards. Just use CONFIG_SYS_SDRAM_BASE instead. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-04-27Remove unnecessary instances of DECLARE_GLOBAL_DATA_PTRTom Rini
We have a large number of places where while we historically referenced gd in the code we no longer do, as well as cases where the code added that line "just in case" during development and never dropped it. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-03-05libfdt: move headers to <linux/libfdt.h> and <linux/libfdt_env.h>Masahiro Yamada
Thomas reported U-Boot failed to build host tools if libfdt-devel package is installed because tools include libfdt headers from /usr/include/ instead of using internal ones. This commit moves the header code: include/libfdt.h -> include/linux/libfdt.h include/libfdt_env.h -> include/linux/libfdt_env.h and replaces include directives: #include <libfdt.h> -> #include <linux/libfdt.h> #include <libfdt_env.h> -> #include <linux/libfdt_env.h> Reported-by: Thomas Petazzoni <thomas.petazzoni@bootlin.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-04-13board_f: Rename initdram() to dram_init()Simon Glass
This allows us to use the same DRAM init function on all archs. Add a dummy function for arc, which does not use DRAM init here. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Dummy function on nios2] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-05board_f: Drop return value from initdram()Simon Glass
At present we cannot use this function as an init sequence call without a wrapper, since it returns the RAM size. Adjust it to set the RAM size in global_data instead, and return 0 on success. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de>
2017-04-05board_f: Drop board_type parameter from initdram()Simon Glass
It looks like only cm5200 and tqm8xx use this feature, so we don't really need it in generic code. Drop it and have the users access gd->board_type directly. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de>
2016-09-27usb: fsl: Rename fdt_fixup_dr_usbSriram Dash
The function fdt_fixup_dr_usb is specific to fsl/nxp. So, make the function name explicit and rename fdt_fixup_dr_usb into fsl_fdt_fixup_dr_usb. Signed-off-by: Sriram Dash <sriram.dash@nxp.com>
2014-11-21fdt: Allow ft_board_setup() to report failureSimon Glass
This function can fail if the device tree runs out of space. Rather than silently booting with an incomplete device tree, allow the failure to be detected. Unfortunately this involves changing a lot of places in the code. I have not changed behvaiour to return an error where one is not currently returned, to avoid unexpected breakage. Eventually it would be nice to allow boards to register functions to be called to update the device tree. This would avoid all the many functions to do this. However it's not clear yet if this should be done using driver model or with a linker list. This work is left for later. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de>
2010-09-2383xx: Remove warmboot parameter from PCI init functionsPeter Tyser
This change lays the groundwork for the BOOTFLAG_* flags being removed. This change has the small affect of delaying 100ms on PCI initialization after a warm boot as opposed to the optimal 1ms on some boards. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> included the mpc8308_p1m board. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2010-09-23mpc8308_p1m: support for MPC8308 P1M boardIlya Yanok
This patch provides support for MPC8308 P1M board with the following set of features: Dual UART is supported NOR flash is supported Both TSEC Ethernet controllers are supported PCI Express initialization is supported Both I2C controllers are supported Signed-off-by: Ilya Yanok <yanok@emcraft.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
