path: root/board/mpc8308_p1m/Makefile
2010-09-23mpc8308_p1m: support for MPC8308 P1M boardIlya Yanok
This patch provides support for MPC8308 P1M board with the following set of features: Dual UART is supported NOR flash is supported Both TSEC Ethernet controllers are supported PCI Express initialization is supported Both I2C controllers are supported Signed-off-by: Ilya Yanok <yanok@emcraft.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
