Modifications are based on the linux kernel approach and
support two use cases:
1) Add O= to the make command line
'make O=/tmp/build all'
2) Set environement variable BUILD_DIR to point to the desired location
'export BUILD_DIR=/tmp/build'
'make'
The second approach can also be used with a MAKEALL script
'./MAKEALL'
Command line 'O=' setting overrides BUILD_DIR environent variable.
When none of the above methods is used the local build is performed and
the object files are placed in the source directory.
Patch by Anders Larsen, 29 Apr 2005
* Fix problems introduced by Patch by Steven Scholz, 02 Mar 2005
(8e2be51de8dd03c1ce4d06cbb18ad06133d47cd5)
Patch by Eric Benard, 07 Apr 2005
