path: root/board/motionpro
2008-10-21Cleanup: fix "MHz" spellingWolfgang Denk
2007-10-23Motion-PRO: Add setting of SDelay reg. to SDRAM controller configuration.Bartlomiej Sieka
Per AN3221 (MPC5200B SDRAM Initialization and Configuration), the SDelay register must be written a value of 0x00000004 as the first step of the SDRAM contorller configuration. Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2007-09-06Migrate 5xxx boards from CONFIG_OF_FLAT_TREE to CONFIG_OF_LIBFDTGrant Likely
Affects boards: icecube (lite5200), jupiter, motionpro, tqm5200 Tested on: lite5200b Note: the fixup functions have not been moved to a common place. This patch is targeted for immediate merging as in solves a build issue, but the final name/location of the fixups is still subject to debate. I propose to merge this now, and move the fixups in the next merge window to be usable by all targets. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-07-04Remove obsolete mpc5xxx linker scripts (1 of 3)Grant Likely
2007-05-28Merge with /home/tur/git/u-boot#motionproWolfgang Denk
2007-05-27Motion-PRO: Code cleanup, fix of a typo in OF_STDOUT_PATH.Bartlomiej Sieka
2007-05-27MPC5XXX, Motion-PRO: Fix PHY initialization problem.Bartlomiej Sieka
After being reset in mpc5xxx_fec_init_phy(), PHY goes into FX mode, in which networking does not function. This commit switches PHY to TX mode by clearing the FX_SEL bit of Mode Control Register. It also reverses commit 008861a2f3ef2c062744d733787c7e530a1b8761, i.e., a temporary workaround. Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com> Acked-by: Bartlomiej Sieka <tur@semihalf.com>
2007-05-27Motion-PRO: Add displaying of CPLD revision information during boot.Bartlomiej Sieka
Signed-off-by: Jan Wrobel <wrr@semihalf.com> Acked-by: Bartlomiej Sieka <tur@semihalf.com>
2007-05-27Motion-PRO: Add LED support.Bartlomiej Sieka
Signed-off-by: Jan Wrobel <wrr@semihalf.com> Signed-off-by: Marian Balakowicz <m8@semihalf.com> Acked-by: Bartlomiej Sieka <tur@semihalf.com>
2007-05-15Merge with /home/tur/git/u-boot#motionproWolfgang Denk
2007-05-08[Motion-PRO] Enable Flat Device Tree support and modify default environmentBartlomiej Sieka
to allow booting of FDT-expecting kernels.
2007-02-27Minor code cleanup.Wolfgang Denk
2007-02-09[Motion-PRO] Preliminary support for the Motion-PRO board.Bartlomiej Sieka
