As the board seems to be unmaintained for some time, lets remove
the support in mainline completely.
Cc: Peter De Schrijver <p2@mind.be>
8xx was left behind when fixing up powerpc linking
scripts to support -fpic.
Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
Currently, _end is used for end of BSS section. We want _end to mean
end of u-boot image, so we rename _end to __bss_end__ first.
Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
This commit adapts 4xx boards for partial linking with --gc-sections.
Cc: Stefan Roese <sr@denx.de>
Cc: Tirumala Marri <tmarri@apm.com>
Cc: David Updegraff <dave@cray.com>
Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
Cc: Dirk Eibach <eibach@gdsys.de>
Cc: Larry Johnson <lrj@acm.org>
Cc: Niklaus Giger <niklaus.giger@netstal.com>
Cc: Daniel Poirot <dan.poirot@windriver.com>
As discussed on the list, move "arch/ppc" to "arch/powerpc" to
better match the Linux directory structure.
Please note that this patch also changes the "ppc" target in
MAKEALL to "powerpc" to match this new infrastructure. But "ppc"
is kept as an alias for now, to not break compatibility with
scripts using this name.
Acked-by: Wolfgang Denk <wd@denx.de>
Acked-by: Detlev Zundel <dzu@denx.de>
Acked-by: Kim Phillips <kim.phillips@freescale.com>
Cc: Peter Tyser <ptyser@xes-inc.com>
Now that the other architecture-specific lib directories have been
moved out of the top-level directory there's not much reason to have the
'_generic' suffix on the common lib directory.
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk
This change is intended to clean up the top-level directory structure
and more closely mimic Linux's directory organization.
The following changes allow U-Boot to fully relocate from flash to
RAM:
- Remove linker scripts' .fixup sections from the .text section
- Add -mrelocatable to PLATFORM_RELFLAGS for all boards
- Define CONFIG_RELOC_FIXUP_WORKS for all boards
Previously, U-Boot would partially relocate, but statically initialized
pointers needed to be manually relocated.
A recent gcc added a new unaligned rodata section called '.rodata.str1.1',
which needs to be added the the linker script. Instead of just adding this
one section, we use a wildcard ".rodata*" to get all rodata linker section
gcc has now and might add in the future.
However, '*(.rodata*)' by itself will result in sub-optimal section
ordering. The sections will be sorted by object file, which causes extra
padding between the unaligned rodata.str.1.1 of one object file and the
aligned rodata of the next object file. This is easy to fix by using the
SORT_BY_ALIGNMENT command.
This patch has not be tested one most of the boards modified. Some boards
have a linker script that looks something like this:
*(.text)
. = ALIGN(16);
*(.rodata)
*(.rodata.str1.4)
*(.eh_frame)
I change this to:
*(.text)
. = ALIGN(16);
*(.eh_frame)
*(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*)))
This means the start of rodata will no longer be 16 bytes aligned.
However, the boundary between text and rodata/eh_frame is still aligned to
16 bytes, which is what I think the real purpose of the ALIGN call is.
Signed-off-by: Trent Piepho <xyzzy@speakeasy.org>
Most of the bss initialization loop increments 4 bytes
at a time. And the loop end is checked for an 'equal'
condition. Make the bss end address aligned by 4, so
that the loop will end as expected.
Signed-off-by: Selvamuthukumar <selva.muthukumar@e-coninfotech.com>
Also changed path in all linker scripts that reference this driver
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
The cross compiler is responsible for providing the correct libraries
and the logic to find the linking libraries.
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
With recent toolchain versions, some boards would not build because
or errors like this one (here for ocotea board when building with
ELDK 4.2 beta):
ppc_4xx-ld: section .bootpg [fffff000 -> fffff23b] overlaps section .bss [fffee900 -> fffff8ab]
For many boards, the .bss section is big enough that it wraps around
at the end of the address space (0xFFFFFFFF), so the problem will not
be visible unless you use a 64 bit tool chain for development. On
some boards however, changes to the code size (due to different
optimizations) we bail out with section overlaps like above.
The fix is to add the NOLOAD attribute to the .bss and .sbss
sections, telling the linker that .bss does not consume any space in
the image.
Change all linker scripts to reference the changed driver name 4xx_uart.o.
Note: In most cased all these explicit referencing of these object files
in the linker scripts is not neccessary. Only for manually embedded
environment into the U-Boot image, which is not done is most cases.
Pointed out by Gerhard Jaeger, 31 Aug 2005;
cf. http://sourceware.org/ml/binutils/2005-08/msg00412.html
now handling all 4xx cpu's.
Patch by Stefan Roese, 16 Aug 2005
- remove trailing white space, trailing empty lines, C++ comments, etc.
- split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c)
* Patches by Kenneth Johansson, 25 Jun 2003:
- major rework of command structure
(work done mostly by Michal Cendrowski and Joakim Kristiansen)
* Patch by Murray Jensen, 24 Jun 2003:
- make sure to use only U-boot provided header files
- fix problems with ".rodata.str1.4" section as used by GCC-3.x
