path: root/board/miromico/hammerhead
2011-05-18hammerhead: move CONFIG_SYS_TEXT_BASE to headerAndreas Bießmann
Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
2011-05-18avr32: use single linker scriptAndreas Bießmann
This patch move the atstk100x linker script to $(CPUDIR) and delete other pure copies of this file in each board directory. Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
2011-05-18avr32/config.mk: simplify PLATFORM_RELFLAGSAndreas Bießmann
This patch removes PLATFORM_RELFLAGS from board specific config.mk files and define them in arch specific config.mk file. Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
2011-05-18avr32: fix linkingAndreas Bießmann
This patch fixes following error: ---8<--- avr32-linux-ld: --gc-sections and -r may not be used together --->8--- Since 8aba9dceebb14144e07d19593111ee3a999c37fc all avr32 boards are broken due to linking error as seen above. Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
2011-05-18avr32: fixup definitions to ATMEL_BASE_xxxAndreas Bießmann
2011-05-18avr32: rename memory-map.h -> hardware.hAndreas Bießmann
2011-03-27rename _end to __bss_end__Po-Yu Chuang
Currently, _end is used for end of BSS section. We want _end to mean end of u-boot image, so we rename _end to __bss_end__ first. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2010-09-03avr32: Add simple paging supportHaavard Skinnemoen
Use the MMU hardware to set up 1:1 mappings between physical and virtual addresses. This allows us to bypass the cache when accessing the flash without having to do any physical-to-virtual address mapping in the CFI driver. The virtual memory mappings are defined at compile time through a sorted array of virtual memory range objects. When a TLB miss exception happens, the exception handler does a binary search through the array until it finds a matching entry and loads it into the TLB. The u-boot image itself is covered by a fixed TLB entry which is never replaced. This makes the 'saveenv' command work again on ATNGW100 and other boards using the CFI driver, hopefully without breaking any rules. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2010-09-03avr32: Use uncached() macro to get an address for SDRAM initHaavard Skinnemoen
The paging system which is required to set up caching properties has not yet been initialized when the SDRAM is initialized. So when the map_physmem() function is converted to return the physical address unchanged, the SDRAM initialization will break on some boards. The avr32-specific uncached() macro will return an address which will always cause uncached accessed to be made. Since this happens in the board code, using avr32-specific features should be ok, and will allow the SDRAM initialization to keep working. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2009-03-23Merge branch 'mimc200'Haavard Skinnemoen
2008-12-17Merge branch 'fixes' into cleanupsHaavard Skinnemoen
Conflicts: board/atmel/atngw100/atngw100.c board/atmel/atstk1000/atstk1000.c cpu/at32ap/at32ap700x/gpio.c include/asm-avr32/arch-at32ap700x/clk.h include/configs/atngw100.h include/configs/atstk1002.h include/configs/atstk1003.h include/configs/atstk1004.h include/configs/atstk1006.h include/configs/favr-32-ezkit.h include/configs/hammerhead.h include/configs/mimc200.h
2008-09-02Introduce netdev.h header file and remove externsBen Warren
This addresses all drivers whose initializers have already been moved to board_eth_init()/cpu_eth_init(). Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-01avr32: use board_early_init_r instead of board_init_infoHaavard Skinnemoen
Replace the avr32-specific board_init_info hook by the standard board_early_init_r hook and make it optional. board_early_init_r() runs somewhat earlier than board_init_info used to do, but this isn't a problem for any of the in-tree boards. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-09-01avr32: Use board_postclk_init instead of gclk_initHaavard Skinnemoen
Replace the avr32-specific gclk_init() board hook with the standard board_postclk_init() hook which is supposed to run at the same point during initialization. Provide a dummy weak alias for boards not implementing this hook. The cost of this is: - 2 bytes for the dummy function (retal 0) - 2 bytes for each unnecessary function call (short rcall) which is a pretty small price to pay for avoiding lots of #ifdef clutter. In this particular case, all boards probably end up slightly smaller because we avoid the conditional checking if the gclk_init symbol is NULL. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-09-01hammerhead: Use gclk helper functionsHaavard Skinnemoen
Use the new gclk helper functions to set up the PHY clock instead of accessing the PM registers directly. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-09-01avr32: refactor the portmux/gpio codeHaavard Skinnemoen
- Separate the portmux configuration functionality from the GPIO pin control API. - Separate the controller-specific code from the chip-specific code. - Allow "ganged" port configuration (multiple pins at once). - Add more flexibility to the "canned" peripheral select functions: - Allow using more than 23 address bits, more chip selects, as well as NAND- and CF-specific pins. - Make the MACB SPEED pin optional, and choose between MII/RMII using a parameter instead of an #ifdef. - Make it possible to use other MMC slots than slot 0, and support different MMC/SDCard data bus widths. - Use more reasonable pull-up defaults; floating pins may consume a lot of power. - Get rid of some custom portmux code from the mimc200 board code. The old gpio/portmux API couldn't really handle its requirements, but the new one can. - Add documentation. The end result is slightly smaller code for all boards. Which isn't really the point, but at least it isn't any larger. This has been verified on ATSTK1002 and ATNGW100. I'd appreciate if the board maintainers could help me test this on their boards. In particular, the mimc200 port has lost a lot of code, so I'm hoping Mark can help me out. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Cc: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Cc: Mark Jackson <mpfj@mimc.co.uk> Cc: Alex Raimondi <alex.raimondi@miromico.ch> Cc: Julien May <julien.may@miromico.ch> Changes since v1: * Enable pullup on NWAIT * Add missing include to portmux-pio.h * Rename CONFIG_PIO2 -> CONFIG_PORTMUX_PIO to match docs
2008-07-30Add support for the hammerhead (AVR32) boardJulien May
The Hammerhead platform is built around a AVR32 32-bit microcontroller from Atmel. It offers versatile peripherals, such as ethernet, usb device, usb host etc. The board also incooperates a power supply and is a Power over Ethernet (PoE) Powered Device (PD). Additonally, a Cyclone III FPGA from Altera is integrated on the board. The FPGA is mapped into the 32-bit AVR memory bus. The FPGA offers two DDR2 SDRAM interfaces, which will cover even the most exceptional need of memory bandwidth. Together with the onboard video decoder the board is ready for video processing. For more information see: http:///www.miromico.com/hammerhead Signed-off-by: Julien May <mailinglist@miromico.ch> [haavard.skinnemoen@atmel.com: various small fixes and adaptions] Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
