path: root/board/mini-box/picosam9g45
2016-02-18board: atmel: clean up peripheral clock codeWenyou Yang
Due to introducing the new peripheral clock handle functions, use these functions to reduce duplicated code. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Tested-by: Heiko Schocher <hs@denx.de> [Rebased on current master, fixup for at91rm9200ek] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2016-02-02arm: at91/spl: mpddrc: add struct atmel_mpddrc_configWenyou Yang
Add struct atmel_mpddrc_config to accommodate the mpddrc register configurations, not using the mpddrc register map structure, struct atmel_mpddrc, in order to increase readability and reduce run-time memory use. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-08-21arm: at91: add support for mini-box picosam9g45 boardErik van Luijk
Bootlog: U-Boot SPL 2015.10-rc1-00452-g96a7ed1 (Aug 17 2015 - 10:32:21) mci: setting clock 258000 Hz, block size 512 mci: setting clock 258000 Hz, block size 512 mci: setting clock 258000 Hz, block size 512 mci: setting clock 33024000 Hz, block size 512 reading u-boot.img reading u-boot.img U-Boot 2015.10-rc1-00452-g96a7ed1 (Aug 17 2015 - 10:32:21 +0000) CPU: AT91SAM9G45 Crystal frequency: 12 MHz CPU clock : 400 MHz Master clock : 133.333 MHz Watchdog enabled DRAM: 256 MiB WARNING: Caches not enabled MMC: mci: 0 mci: setting clock 260416 Hz, block size 512 mci: setting clock 260416 Hz, block size 512 mci: setting clock 260416 Hz, block size 512 mci: setting clock 33333333 Hz, block size 512 reading uboot.env In: serial Out: serial Err: serial Net: macb0 Error: macb0 address not set. Hit any key to stop autoboot: 0 U-Boot> Signed-off-by: Erik van Luijk <evanluijk@interact.nl> [add 'picosam9g45_defconfig' to MAINTAINERS] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
