path: root/board/mikrotik
2020-08-06arm: mvebu: crs3xx-98dx3236: Add a maintainerLuka Kovacic
Add Luka Perkov to CRS3xx-98DX3236 MAINTAINERS. Signed-off-by: Luka Kovacic <luka.kovacic@sartura.hr> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Jakov Petrina <jakov.petrina@sartura.hr> Reviewed-by: Stefan Roese <sr@denx.de>
2020-08-06arm: mvebu: Add CRS328-4C-20S-4S boardLuka Kovacic
MikroTik CRS328-4C-20S-4S board has a switch chip with an integrated Marvell Prestera 98DX3236 CPU. This commit includes two board variants, namely the factory default one and a Bit variant. The Bit board variant has a bigger Macronix flash. Add basic U-Boot, UART and SPI flash support. Signed-off-by: Luka Kovacic <luka.kovacic@sartura.hr> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Jakov Petrina <jakov.petrina@sartura.hr> Reviewed-by: Stefan Roese <sr@denx.de>
2020-08-06arm: mvebu: Add CRS326-24G-2S boardLuka Kovacic
MikroTik CRS326-24G-2S board has a switch chip with an integrated Marvell Prestera 98DX3236 CPU. This commit includes two board variants, namely the factory default one and a Bit variant. The Bit board variant has a bigger Macronix flash. Add basic U-Boot, UART and SPI flash support. Signed-off-by: Luka Kovacic <luka.kovacic@sartura.hr> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Jakov Petrina <jakov.petrina@sartura.hr> Reviewed-by: Stefan Roese <sr@denx.de>
2020-08-06arm: mvebu: Add CRS305-1G-4S Bit boardLuka Kovacic
MikroTik CRS305-1G-4S Bit board has a switch chip with an integrated Marvell Prestera 98DX3236 CPU. The Bit board variant is added, which has a bigger Macronix flash. Add basic U-Boot, UART and Winbond SPI flash support. Signed-off-by: Luka Kovacic <luka.kovacic@sartura.hr> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Jakov Petrina <jakov.petrina@sartura.hr> Reviewed-by: Stefan Roese <sr@denx.de>
2020-05-27arm: mvebu: Convert CRS305-1G-4S board to CRS3xx-98DX3236Luka Kovacic
Convert the CRS305-1G-4S board to CRS3xx-98DX3236 to enable easier implementation of new CRS3xx series boards, based on Marvell Prestera 98DX3236. Signed-off-by: Luka Kovacic <luka.kovacic@sartura.hr> Reviewed-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Jakov Petrina <jakov.petrina@sartura.hr>
2020-05-18common: Drop linux/bitops.h from common headerSimon Glass
Move this uncommon header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop init.h from common headerSimon Glass
2019-10-29arm: mvebu: Avoid generating kwbimage.cfg in the source treeBin Meng
At present some boards generate kwbimage.cfg in the source tree during the build. This breaks buildman testing on some systems where the source tree is read-only. Update makefile rules to generate it in the build tree instead. Note some other boards have the kwbimage.cfg file written in advance, hence we need check if the file exists in the build tree first, otherwise we fall back to one in the source tree. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-05-09arm: mvebu: Add CRS305-1G-4S boardLuka Kovacic
CRS305-1G-4S has a switch chip with an integrated CPU (98DX3236) and like some of the other similar boards requires bin_hdr. bin_hdr (DDR3 init stage) is currently retrieved from the stock bootloader and compiled into the kwb image. Adds support for U-Boot, enable UART, SPI, Winbond SPI flash chip support and writing env to SPI flash. Signed-off-by: Luka Kovacic <me@lukakovacic.xyz> Reviewed-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
