path: root/board/micronas
2009-09-28MIPS: VCT: Remove read_spareram referenceShinya Kuribayashi
The commit ecad289fc6bd9d89ef4d5093cc7b6fd712fd0d29 (OneNAND: Remove unused read_spareram and add unlock_all as kernel does) forgot to remove a local reference to read_spareram in board/micronas/vct/ebi_onenand.c, which causes the following build failure when configured with OneNAND: ebi_onenand.c: In function 'onenand_board_init': ebi_onenand.c:196: error: 'struct onenand_chip' has no member named 'read_spareram' make[1]: *** [ebi_onenand.o] Error 1 make[1]: *** Waiting for unfinished jobs.... make: *** [board/micronas/vct/libvct.a] Error 2 Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com> Acked-by: Stefan Roese <sr@denx.de> Cc: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-07-22Convert SMC911X Ethernet driver to CONFIG_NET_MULTI APIBen Warren
All in-tree boards that use this controller have CONFIG_NET_MULTI added Also: - changed CONFIG_DRIVER_SMC911X* to CONFIG_SMC911X* - cleaned up line lengths - modified all boards that override weak function in this driver - added Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Tested-by: Mike Frysinger <vapier@gentoo.org>
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-01-27MIPS: Add VCT board series support (Part 3/3)Stefan Roese
2009-01-27MIPS: Add VCT board series support (Part 2/3)Stefan Roese
2009-01-27MIPS: Add VCT board series support (Part 1/3)Stefan Roese
