path: root/board/micronas/vct/u-boot.lds
2011-05-10MIPS: Introduce --gc-sections for MIPSDaniel Schwierzeck
All architectures but MIPS are using --gc-sections on final linking. This patch introduces that feature for MIPS to reduce the memory and flash footprint. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Thomas Lange <thomas@corelatus.se> Cc: Vlad Lungu <vlad.lungu@windriver.com> Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2009-01-27MIPS: Add VCT board series support (Part 2/3)Stefan Roese
