path: root/board/microchip/pic32mzda/pic32mzda.c
2016-06-19clk: convert API to match reset/mailbox styleStephen Warren
The following changes are made to the clock API: * The concept of "clocks" and "peripheral clocks" are unified; each clock provider now implements a single set of clocks. This provides a simpler conceptual interface to clients, and better aligns with device tree clock bindings. * Clocks are now identified with a single "struct clk", rather than requiring clients to store the clock provider device and clock identity values separately. For simple clock consumers, this isolates clients from internal details of the clock API. * clk.h is split so it only contains the client/consumer API, whereas clk-uclass.h contains the provider API. This aligns with the recently added reset and mailbox APIs. * clk_ops .of_xlate(), .request(), and .free() are added so providers can customize these operations if needed. This also aligns with the recently added reset and mailbox APIs. * clk_disable() is added. * All users of the current clock APIs are updated. * Sandbox clock tests are updated to exercise clock lookup via DT, and clock enable/disable. * rkclk_get_clk() is removed and replaced with standard APIs. Buildman shows no clock-related errors for any board for which buildman can download a toolchain. test/py passes for sandbox (which invokes the dm clk test amongst others). Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-02-01board: Add Microchip PIC32MZ[DA]-Starter-Kit board.Purna Chandra Mandal
This adds support for Microchip PIC32MZ[DA] StarterKit board based on a PIC32MZ[DA] family of microcontroller. Signed-off-by: Purna Chandra Mandal <purna.mandal@microchip.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
