path: root/board/mgsuvd
2008-03-08mgsuvd: update board configurationHeiko Schocher
initialize the UPIOx controller. Signed-off-by: Heiko Schocher <hs@denx.de>
2008-02-22Fix device tree for mgsuvd board.Heiko Schocher
Rename the "scc" node in "ethernet" for the mgsuvd board. Signed-off-by: Heiko Schocher <hs@denx.de>
2008-01-12Added support for the mgsuvd board from keymile.Heiko Schocher
