path: root/board/mercury/mpq101
2011-03-27rename _end to __bss_end__Po-Yu Chuang
Currently, _end is used for end of BSS section. We want _end to mean end of u-boot image, so we rename _end to __bss_end__ first. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2011-01-26mpq101: initial support for Mercury Computer Systems MPQ101 boardAlex Dubov
Mpq101 is a RapidIO development board in AMC form factor, featuring MPC8548 processor, 512MB of hardwired DDR2 RAM, 128MB of hardwired NAND flash memory, real time clock and additional serial EEPROM on i2c bus (enabled). USB controller is available, but not presently enabled. Additional board information is available at: http://www.mc.com/products/boards/ensemble_mpq101_rapidio_powerquicc_iii.aspx Environment is configured to precede the actual u-boot image so that it's located at the beginning of flash erase block (made necessary by the recent changes to the embedded environment handling). This is achieved by means of custom ld script. Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
