path: root/board/mbx8xx
2014-04-18powerpc: remove MBX and MBX860T boards supportMasahiro Yamada
Enough time has passed since these boards were moved to Orphan. Remove. - Remove board/mbx8xx/* - Remove include/configs/{MBX.h,MBX860T.h} - Clean-up if defined(CONFIG_MBX) - Move the entries from boards.cfg to doc/README.scrapyard Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-04-02replace last __bss_end__ occurrences with __bss_endAlbert ARIBAUD
Simon Glass' commit 3929fb0a141530551b3fce15ee08629f80d5ef2a, which changed all occurrences of __bss__end__ into __bss_end, left behind some untouched __bss_end__ occurrences in all 33 u-boot.lds.debug files, in board/mousse/u-boot.lds.ram and in board/mousse/u-boot.lds.rom. These are replaced here. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-03-18Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Albert's rework of the linker scripts conflicted with Simon's making everyone use __bss_end. We also had a minor conflict over README.scrapyard being added to in mainline and enhanced in u-boot-arm/master with proper formatting. Conflicts: arch/arm/cpu/ixp/u-boot.lds arch/arm/cpu/u-boot.lds arch/arm/lib/Makefile board/actux1/u-boot.lds board/actux2/u-boot.lds board/actux3/u-boot.lds board/dvlhost/u-boot.lds board/freescale/mx31ads/u-boot.lds doc/README.scrapyard include/configs/tegra-common.h Build tested for all of ARM and run-time tested on am335x_evm. Signed-off-by: Tom Rini <trini@ti.com>
2013-03-15Replace __bss_end__ with __bss_endSimon Glass
Note this is a tree-wide change affecting multiple architectures. At present we use __bss_start, but mostly __bss_end__. This seems inconsistent and in a number of places __bss_end is used instead. Change to use __bss_end for the BSS end symbol throughout U-Boot. This makes it possible to use the asm-generic/sections.h file on all archs. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-12Refactor linker-generated arraysAlbert ARIBAUD
Refactor linker-generated array code so that symbols which were previously linker-generated are now compiler- generated. This causes relocation records of type R_ARM_ABS32 to become R_ARM_RELATIVE, which makes code which uses LGA able to run before relocation as well as after. Note: this affects more than ARM targets, as linker- lists span possibly all target architectures, notably PowerPC. Conflicts: arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds arch/arm/cpu/armv7/omap-common/u-boot-spl.lds board/ait/cam_enc_4xx/u-boot-spl.lds board/davinci/da8xxevm/u-boot-spl-da850evm.lds board/davinci/da8xxevm/u-boot-spl-hawk.lds board/vpac270/u-boot-spl.lds Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2012-10-22common: Discard the __u_boot_cmd sectionMarek Vasut
The command declaration now uses the new LG-array method to generate list of commands. Thus the __u_boot_cmd section is now superseded and redundant and therefore can be removed. Also, remove externed symbols associated with this section from include/command.h . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-22common: Add .u_boot_list into all linker filesMarek Vasut
Add section for the linker-generated lists into all possible linker files, so that everyone can easily use these lists. This is mostly a mechanical adjustment. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-07-29doc: cleanup - move board READMEs into respective board directoriesWolfgang Denk
Also drop a few files referring to no longer / not yet supported boards. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Stefan Roese <sr@denx.de> Cc: Kim Phillips <kim.phillips@freescale.com> Cc: Andy Fleming <afleming@gmail.com> Cc: Jason Jin <jason.jin@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
2011-11-07board/mbx8xx/mbx8xx.c: Fix GCC 4.6 build warningsWolfgang Denk
Fix: mbx8xx.c: In function 'mbx_init': mbx8xx.c:127:15: warning: variable 'refclock' set but not used [-Wunused-but-set-variable] mbx8xx.c: In function 'board_get_cpufreq': mbx8xx.c:231:2: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing] mbx8xx.c: In function 'get_reffreq': mbx8xx.c:242:2: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing] Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-11-07board/mbx8xx/pcmcia.c: Fix GCC 4.6 build warningsWolfgang Denk
Fix: pcmcia.c: In function 'pcmcia_hardware_enable': pcmcia.c:83:25: warning: variable 'sysp' set but not used [-Wunused-but-set-variable] pcmcia.c:81:21: warning: variable 'cp' set but not used [-Wunused-but-set-variable] pcmcia.c:80:20: warning: variable 'immap' set but not used [-Wunused-but-set-variable] Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-04-20powerpc, 8xx: Fixup all 8xx u-boot.lds scriptsJoakim Tjernlund
8xx was left behind when fixing up powerpc linking scripts to support -fpic. Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
2011-03-27rename _end to __bss_end__Po-Yu Chuang
Currently, _end is used for end of BSS section. We want _end to mean end of u-boot image, so we rename _end to __bss_end__ first. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2010-11-278xx: Cleanup for partial linking and --gc-sectionsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2010-09-19Remove HMI10 board supportWolfgang Denk
Recent changes caused that the HMI10 board now is included in the boards built by MAKEALL, which revealed that compilation for this board has been broken for a long time: ps2ser.c: In function 'ps2ser_init': ps2ser.c:155: error: 'UART_LCR' undeclared (first use in this function) ps2ser.c:155: error: (Each undeclared identifier is reported only once ps2ser.c:155: error: for each function it appears in.) ps2ser.c:156: error: 'UART_DLL' undeclared (first use in this function) ps2ser.c:157: error: 'UART_DLM' undeclared (first use in this function) ps2ser.c:159: error: 'UART_IER' undeclared (first use in this function) ps2ser.c:160: error: 'UART_MCR' undeclared (first use in this function) ps2ser.c:161: error: 'UART_FCR' undeclared (first use in this function) ps2ser.c:162: error: 'UART_FCR_ENABLE_FIFO' undeclared (first use in this function) ps2ser.c:166: error: 'UART_LSR' undeclared (first use in this function) ps2ser.c: In function 'ps2ser_putc': ps2ser.c:198: error: 'UART_LSR' undeclared (first use in this function) ps2ser.c:200: error: 'UART_TX' undeclared (first use in this function) ps2ser.c: In function 'ps2ser_getc_hw': ps2ser.c:224: error: 'UART_LSR' undeclared (first use in this function) ps2ser.c:225: error: 'UART_RX' undeclared (first use in this function) ps2ser.c: In function 'ps2ser_interrupt': ps2ser.c:293: error: 'UART_IIR' undeclared (first use in this function) The board is orphaned, and AFAICT has reached EOL. Drop support for it. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-13Move lib_$ARCH directories to arch/$ARCH/libPeter Tyser
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk This change is intended to clean up the top-level directory structure and more closely mimic Linux's directory organization. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-10-03ppc: Enable full relocation to RAMPeter Tyser
The following changes allow U-Boot to fully relocate from flash to RAM: - Remove linker scripts' .fixup sections from the .text section - Add -mrelocatable to PLATFORM_RELFLAGS for all boards - Define CONFIG_RELOC_FIXUP_WORKS for all boards Previously, U-Boot would partially relocate, but statically initialized pointers needed to be manually relocated. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-03-27ppc: cleanup compiler errors/warningsHeiko Schocher
Current u-boot top of tree builds with warnings/errors for the following boards: ads5121 cpci5200 mecp5200 v38b IAD210 MBX MBX860T NX823 RPXClassic debris PN62 following patch solves this. Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2009-03-20boards: move board_get_enetaddr() into board-specific initMike Frysinger
The environment is the canonical storage location of the mac address, so we're killing off the global data location and moving everything to querying the env directly. Rather than have the common ppc code have board-specific hooks, move the board_get_enetaddr() function into the board-specific init functions. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2007-07-09board/[m-p]*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04board/[k-z]*: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2006-07-10Major PCMCIA Cleanup to make code better readable and maintainable.Wolfgang Denk
Notes: - Board-dependend code for RPXLITE and RPXCLASSIC-based boards placed to the drivers/rpx_pmcia.c file to avoid duplication. Same for TQM8xx-based boards (drivers/tqm8xx_pmcia.c). - drivers/i82365.c has been split into two parts located at board/atc/ti113x.c and board/cpc45/pd67290.c (ATC and CPC45 are the only boards using CONFIG_82365). - Changes were tested for clean build and *very* *few* boards.
2001-04-28Initial revisionwdenk
