path: root/board/mbx8xx/mbx8xx.c
2011-11-07board/mbx8xx/mbx8xx.c: Fix GCC 4.6 build warningsWolfgang Denk
Fix: mbx8xx.c: In function 'mbx_init': mbx8xx.c:127:15: warning: variable 'refclock' set but not used [-Wunused-but-set-variable] mbx8xx.c: In function 'board_get_cpufreq': mbx8xx.c:231:2: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing] mbx8xx.c: In function 'get_reffreq': mbx8xx.c:242:2: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing] Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-03-27ppc: cleanup compiler errors/warningsHeiko Schocher
Current u-boot top of tree builds with warnings/errors for the following boards: ads5121 cpci5200 mecp5200 v38b IAD210 MBX MBX860T NX823 RPXClassic debris PN62 following patch solves this. Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2009-03-20boards: move board_get_enetaddr() into board-specific initMike Frysinger
The environment is the canonical storage location of the mac address, so we're killing off the global data location and moving everything to querying the env directly. Rather than have the common ppc code have board-specific hooks, move the board_get_enetaddr() function into the board-specific init functions. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
