mbus driver is initialized from arch_cpu_init() callback which is called
before relocation. This driver stores lot of functions and structure
pointers into global variables, so it is data position dependent.
Therefore after relocations all pointers are invalid and driver does not
work anymore as all pointers referes to the old memory, which overlaps with
CONFIG_SYS_LOAD_ADDR and ${loadaddr}.
For example U-Boot fuse command crashes if loadaddr memory is cleared or
rewritten by some image loaded by U-Boot load command.
mw.w ${loadaddr} 0x0 10000
fuse read 0 1 2
Fix this issue by removing of all mbus global variables in which are stored
pointers to structures or functions which changes during relocation. And
replace it by direct function calls (not via pointers). With this change
fuse command finally works.
Signed-off-by: Pali Rohár <pali@kernel.org>
Reviewed-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
Move this out of the common header and include it only where needed. In
a number of cases this requires adding "struct udevice;" to avoid adding
another large header or in other cases replacing / adding missing header
files that had been pulled in, very indirectly. Finally, we have a few
cases where we did not need to include <asm/global_data.h> at all, so
remove that include.
Move this uncommon header out of the common header.
This patch enables the PCIe port specific link capabilities configuration
for Armada XP. The weak function board_sat_r_get() was used to return
a common flag for PCIe Gen1 vs Gen2 capability for all PCIe ports. This
is now changed with this patch to return a bit per PCIe port (4 bits
in this case, bit 0 for PCIe port 0, etc).
The theadorable board uses this new feature to configure PCIe port 0
as Gen1 and all other PCIe ports as Gen2 capable. All other AXP boards
using this function are not changed in the configuration and still
configure all ports as PCIe Gen2.
This patch also removes the parameter "pex_mode" from
board_serdes_cfg_get() as this parameter was not used in any of the
implementations.
Cc: Phil Sutter <phil@nwl.cc>
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
Update this driver to support driver model. As all MVEBU boards using
this driver are converted with this patch, the non-driver-model code
can be removed completely. This is also the reason why this patch
is quite big and includes a) the driver change and b) the
platform change. As its not git-bisect save otherwise.
With this conversion, some parameters are now extracted from the
DT instread of using the config header defines. The supported
properties right now are:
PHY-mode ("phy-mode") and PHY-address ("reg").
The base addresses for the ethernet controllers can be removed from
the header files as well.
Please note that this patch also removes the E1000 network driver
from some MVEBU config headers. This is necessary, as with DM_ETH
configured and the e1000 driver enabled, the PCI driver also needs
to support DM. But the MVEBU PCI(e) driver still needs to get
ported to DM. When this is done, the E1000 driver can be enabled
again.
Cc: Luka Perkov <luka.perkov@sartura.hr>
Cc: Dirk Eibach <dirk.eibach@gdsys.cc>
With the upcoming addition of the Armada 38x SPL support, which is not
compatible to the Armada XP SERDES init code, we need to introduce a new
directory infrastructure. So lets move the AXP serdes init code into
a new directory. This way the A38x code can be added in a clean way.
Now that the mach-mvebu directory exists and is used by Armada XP we can
move the mvebu-common files into this directory as well.
Tested-by: Kevin Smith <kevin.smith@elecsyscorp.com>
Tested-by: Dirk Eibach <dirk.eibach@gdsys.cc>
This patch fixes the following compilation warning for maxbcm:
Building maxbcm board...
160075 6596 38240 204911 3206f ./u-boot
board/maxbcm/maxbcm.c: In function 'reset_phy':
board/maxbcm/maxbcm.c:68:6: warning: unused variable 'reg' [-Wunused-variable]
u16 reg;
board/maxbcm/maxbcm.c:66:6: warning: unused variable 'devadr' [-Wunused-variable]
u16 devadr = CONFIG_PHY_BASE_ADDR;
Additionally support Spansion SPI NOR flash is added. With larger SPI device
support via the CONFIG_SPI_FLASH_BAR define.
Reviewed-by: Luka Perkov <luka.perkov@sartura.hr>
This patch adds SPL support to the maxbcm MV78460 based board. Including
the fixed DDR configuratrion needed for the DDR training code. And the
the serdes PHY init code.
The maxBCM board is equipped with the Marvell Armada-XP MV78460 SoC. It
integrates an SPI NOR flash and an Marvell 88E6185 switch.
