The top level Makefile does not do any recursion into subdirs when
cleaning, so these clean/distclean targets in random arch/board dirs
never get used. Punt them all.
MAKEALL didn't report any errors related to this that I could see.
Fix compiler warning:
cmd_fpga.c:318: warning: passing argument 3 of 'fit_image_get_data'
from incompatible pointer type
Adding the needed 'const' here entails a whole bunch of additonal
changes all over the FPGA code.
Cc: Andre Schwarz <andre.schwarz@matrix-vision.de>
Cc: Murray Jensen <Murray.Jensen@csiro.au>
Acked-by: Andre Schwarz<andre.schwarz@matrix-vision.de>
Doesn't make sense to provide this function to boards which defined
CONFIG_ENV_IS_NOWHERE. Such a board gets a linking error because
common/env_nowhere.c doesn't define saveenv().
Signed-off-by: Michael Jones <michael.jones@matrix-vision.de>
Includes board config file, documentation, maintainer and boards.cfg
entries, and board specific files in vendor dir.
Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de>
Two linker scripts for 8xx was missed.
Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
8xx was left behind when fixing up powerpc linking
scripts to support -fpic.
Currently, _end is used for end of BSS section. We want _end to mean
end of u-boot image, so we rename _end to __bss_end__ first.
Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
Recent cleanup actions resulted in a number of config.mk files that
contained only LDSCRIPT definitions. Move these into th respective
board config files and remove the now empty config.mk files.
Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
Cc: Detlev Zundel <dzu@denx.de>
Cc: Peter De Schrijver <p2@mind.be>
Acked-by: Detlev Zundel < dzu@denx.de>
Acked-by: Andre Schwarz <andre.schwarz@matrix-vision.de>
Acked-by: Heiko Schocher<hs@denx.de>
Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu>
Before this commit, weak symbols were not overridden by non-weak symbols
found in archive libraries when linking with recent versions of
binutils. As stated in the System V ABI, "the link editor does not
extract archive members to resolve undefined weak symbols".
This commit changes all Makefiles to use partial linking (ld -r) instead
of creating library archives, which forces all symbols to participate in
linking, allowing non-weak symbols to override weak symbols as intended.
This approach is also used by Linux, from which the gmake function
cmd_link_o_target (defined in config.mk and used in all Makefiles) is
inspired.
The name of each former library archive is preserved except for
extensions which change from ".a" to ".o". This commit updates
references accordingly where needed, in particular in some linker
scripts.
This commit reveals board configurations that exclude some features but
include source files that depend these disabled features in the build,
resulting in undefined symbols. Known such cases include:
- disabling CMD_NET but not CMD_NFS;
- enabling CONFIG_OF_LIBFDT but not CONFIG_QE.
Signed-off-by: Sebastien Carlier <sebastien.carlier@gmail.com>
After the recent cleanups, a number of config.mk files consist only of
a "PLATFORM_CPPFLAGS += -I$(TOPDIR)/board" entry whih is not needed.
Remove such entries. In most cases, that means that the whole
config.mk file can be removed.
Clean up Makefile, and drop a lot of the config.mk files on the way.
We now also automatically pick all boards that are listed in
boards.cfg (and with all configurations), so we can drop the redundant
entries from MAKEALL to avoid building these twice.
The change is currently needed to be able to remove the board
configuration scripting from the top level Makefile and replace it by
a simple, table driven script.
Moving this configuration setting into the "CONFIG_*" name space is
also desirable because it is needed if we ever should move forward to
a Kconfig driven configuration system.
This change lays the groundwork for the BOOTFLAG_* flags being removed.
This change has the small affect of delaying 100ms on PCI initialization
after a warm boot as opposed to the optimal 1ms on some boards.
included the mpc8308_p1m board.
Fix MVBLM7 and MVSMR Makefiles for correct out-of-tree building
(create "bootscript.img" in build directory instead of source
directory) and cleanup (remove "bootscript.img" when cleaning up).
Add USB commands.
Rename autoscript to bootscript.
Add automatic bootscript image generation to makefile.
MVSMR board support doesn't link since recent rework
of U-Boot directory structure. Fix it now.
Fixed merge conflict
As discussed on the list, move "arch/ppc" to "arch/powerpc" to
better match the Linux directory structure.
Please note that this patch also changes the "ppc" target in
MAKEALL to "powerpc" to match this new infrastructure. But "ppc"
is kept as an alias for now, to not break compatibility with
scripts using this name.
Acked-by: Wolfgang Denk <wd@denx.de>
Acked-by: Detlev Zundel <dzu@denx.de>
Acked-by: Kim Phillips <kim.phillips@freescale.com>
Cc: Peter Tyser <ptyser@xes-inc.com>
u-boot updates, before starting Linux, the memory node in the
DTS. As this is a "standard" feature, move this functionality
to the cpu.c file for mpc5xxx and mpc512x processors.
PPC boards are the only users of the current FPGA code which is littered
with manual relocation fixups. Now that proper relocation is supported
for PPC boards, remove FPGA manual relocation.
The more standard 'source' command provides identical functionality to
the autoscr command.
Environment variable names/values on the MVBC_P, MVBML7, kmeter1,
mgcoge, and km8xx boards are updated to no longer refernce 'autoscr'.
The 'autoscript' and 'autoscript_uname' environment variables are
also removed.
Acked-by: Heiko Schocher <hs@denx.de>
This fixes current build failure.
mvblm7.c: fix warning: implicit declaration of function
'mv_reset_environment'
Clean up existing boards (mvBC-P/MPC5200 and mvBL-M7/MPC8343) by
using common code.
Signed-off-by: André Schwarz <andre.schwarz@matrix-vision.de>
"All Rights Reserved" conflicts with the GPL.
Signed-off-by: Kumar Gala <kumar.gala@freescale.com>
The spd_dram code shifts the base address, then masks 20 bits, but
forgets to shift the base address back. Fix this by just masking the
base address correctly.
Found this bug while trying to relocate a DDR memory at the base != 0.
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
Affected boards:
ap1000
mvbc_p
PM854
Removed initialization of the driver from net/eth.c
Modified board_eth_init() functions of boards that have this FEC in addition
to other Ethernet controllers.
Affected boards:
bc3450
icecube
mvbc_p
o2dnt
pm520
total5200
tq5200
Removed initialization of controller from net/eth.c
fix mvBL-M7 config and move to matrix_vision subdir
fix build warnings @ mvBC-P board by using correct types, i.e. change
out_be32 to out_be16 and out_8 accordingly.
The MVBC_P is a MPC5200B based camera system with Intel Gigabit ethernet
controller (using e1000) and custom Altera Cyclone-II FPGA on PCI.
