path: root/board/matrix_vision
2011-04-24powerpc, 8xx: Fix fallout from "Fixup all 8xx u-boot.lds scripts"Joakim Tjernlund
Two linker scripts for 8xx was missed. Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
2011-04-20powerpc, 8xx: Fixup all 8xx u-boot.lds scriptsJoakim Tjernlund
8xx was left behind when fixing up powerpc linking scripts to support -fpic. Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
2011-03-27rename _end to __bss_end__Po-Yu Chuang
Currently, _end is used for end of BSS section. We want _end to mean end of u-boot image, so we rename _end to __bss_end__ first. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2010-12-09Move LDSCRIPT definitions to board config files.Wolfgang Denk
Recent cleanup actions resulted in a number of config.mk files that contained only LDSCRIPT definitions. Move these into th respective board config files and remove the now empty config.mk files. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Cc: Detlev Zundel <dzu@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Andre Schwarz <andre.schwarz@matrix-vision.de> Cc: Peter De Schrijver <p2@mind.be> Acked-by: Detlev Zundel < dzu@denx.de> Acked-by: Andre Schwarz <andre.schwarz@matrix-vision.de> Acked-by: Heiko Schocher<hs@denx.de> Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu>
2010-11-275xxx: Cleanup for partial linking and --gc-sectionsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2010-10-18config.mk cleanup: drop "-I$(TOPDIR)/board" entriesWolfgang Denk
After the recent cleanups, a number of config.mk files consist only of a "PLATFORM_CPPFLAGS += -I$(TOPDIR)/board" entry whih is not needed. Remove such entries. In most cases, that means that the whole config.mk file can be removed. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-2383xx: Remove warmboot parameter from PCI init functionsPeter Tyser
This change lays the groundwork for the BOOTFLAG_* flags being removed. This change has the small affect of delaying 100ms on PCI initialization after a warm boot as opposed to the optimal 1ms on some boards. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> included the mpc8308_p1m board. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2010-05-15MVBLM7, MVSMR: fix Makefile (cleanup bootscript.img)Wolfgang Denk
Fix MVBLM7 and MVSMR Makefiles for correct out-of-tree building (create "bootscript.img" in build directory instead of source directory) and cleanup (remove "bootscript.img" when cleaning up). Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Andre Schwarz <andre.schwarz@matrix-vision.de>
2010-05-07mpc83xx/mvBLM7: add usb commands and cleanup.Andre Schwarz
Add USB commands. Rename autoscript to bootscript. Add automatic bootscript image generation to makefile. Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2010-05-04mvsmr: fix link errorAnatolij Gustschin
MVSMR board support doesn't link since recent rework of U-Boot directory structure. Fix it now. Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Andre Schwarz <andre.schwarz@matrix-vision.de> Acked-by: Andre Schwarz <andre.schwarz@matrix-vision.de> Fixed merge conflict Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-04-10Add initial support for Matrix Vision mvSMR board based on MPC5200B.Andre Schwarz
2009-12-085xxx, fdt: move fdt_fixup_memory() to cpu.c fileHeiko Schocher
u-boot updates, before starting Linux, the memory node in the DTS. As this is a "standard" feature, move this functionality to the cpu.c file for mpc5xxx and mpc512x processors. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-10-03fpga: Remove relocation fixupsPeter Tyser
PPC boards are the only users of the current FPGA code which is littered with manual relocation fixups. Now that proper relocation is supported for PPC boards, remove FPGA manual relocation. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-09-22Remove deprecated 'autoscr' command/variablesPeter Tyser
The more standard 'source' command provides identical functionality to the autoscr command. Environment variable names/values on the MVBC_P, MVBML7, kmeter1, mgcoge, and km8xx boards are updated to no longer refernce 'autoscr'. The 'autoscript' and 'autoscript_uname' environment variables are also removed. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Acked-by: Andre Schwarz <andre.schwarz@matrix-vision.de> Acked-by: Heiko Schocher <hs@denx.de>
2009-08-31Add common code dir for Matrix Vision boards.Andre Schwarz
This fixes current build failure. Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de> mvblm7.c: fix warning: implicit declaration of function 'mv_reset_environment' Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-08-28Use common code for Matrix Vision boardsAndré Schwarz
Clean up existing boards (mvBC-P/MPC5200 and mvBL-M7/MPC8343) by using common code. Signed-off-by: André Schwarz <andre.schwarz@matrix-vision.de>
2009-07-29Update Freescale copyrights to remove "All Rights Reserved"Kumar Gala
"All Rights Reserved" conflicts with the GPL. Signed-off-by: Kumar Gala <kumar.gala@freescale.com>
2008-09-24mpc83xx: spd_sdram: fix ddr sdram base address assignment bugAnton Vorontsov
The spd_dram code shifts the base address, then masks 20 bits, but forgets to shift the base address back. Fix this by just masking the base address correctly. Found this bug while trying to relocate a DDR memory at the base != 0. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-09-02Moved initialization of E1000 Ethernet controller to board_eth_init()Ben Warren
Affected boards: ap1000 mvbc_p PM854 Removed initialization of the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-02Moved initialization of MPC5xxx_FEC Ethernet driver to CPU directoryBen Warren
Modified board_eth_init() functions of boards that have this FEC in addition to other Ethernet controllers. Affected boards: bc3450 icecube mvbc_p o2dnt pm520 total5200 tq5200 Removed initialization of controller from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-08-25change mvBL-M7 default env and move to vendor subdirAndre Schwarz
fix mvBL-M7 config and move to matrix_vision subdir Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-08-21fix mvbc_p board build warningsAndre Schwarz
fix build warnings @ mvBC-P board by using correct types, i.e. change out_be32 to out_be16 and out_8 accordingly. Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de>
2008-08-06Fix merge problemsStefan Roese
2008-07-15mpc5xxx: Add MVBC_P board supportAndre Schwarz
The MVBC_P is a MPC5200B based camera system with Intel Gigabit ethernet controller (using e1000) and custom Altera Cyclone-II FPGA on PCI. Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
