path: root/board/matrix_vision/mvblm7
2008-09-24mpc83xx: spd_sdram: fix ddr sdram base address assignment bugAnton Vorontsov
The spd_dram code shifts the base address, then masks 20 bits, but forgets to shift the base address back. Fix this by just masking the base address correctly. Found this bug while trying to relocate a DDR memory at the base != 0. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-08-25change mvBL-M7 default env and move to vendor subdirAndre Schwarz
fix mvBL-M7 config and move to matrix_vision subdir Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
