path: root/board/m5282evb
2007-10-25ColdFire 5282: Fix external flash boot and return dramsizeTsiChungLiew
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
2007-09-15ColdFire: fix build error becasue of bad type of mii_init()Liew Tsi Chung-r5aahp
2007-08-16ColdFire: Update Freescale MCF52x2 platformsTsiChungLiew
2006-05-09Fixes for gcc 3.4 based m68k toolchain,Marian Balakowicz
based on patch by Jate Sujjavanich.
2006-03-11More GCC 4.x code cleanupWolfgang Denk
2004-02-12* Some code cleanupwdenk
* Patch by Josef Baumgartner, 10 Feb 2004: Fixes for Coldfire port * Patch by Brad Kemp, 11 Feb 2004: Fix CFI flash driver problems
2003-12-08* Patch by Bernhard Kuhn, 28 Nov 2003:wdenk
add support for Coldfire CPU add support for Motorola M5272C3 and M5282EVB boards
