path: root/board/m5271evb
2008-02-14Fix remaining CONFIG_COMMANDSJean-Christophe PLAGNIOL-VILLARD
update comments Fix coding style Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2007-09-15ColdFire: fix build error becasue of bad type of mii_init()Liew Tsi Chung-r5aahp
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
2007-08-16ColdFire: Update Freescale MCF52x2 platformsTsiChungLiew
2006-05-10Minor cleanup.LABEL_2006_05_10_1800Wolfgang Denk
2006-05-09Add M5271EVB board support.Marian Balakowicz
