Before this commit, weak symbols were not overridden by non-weak symbols
found in archive libraries when linking with recent versions of
binutils. As stated in the System V ABI, "the link editor does not
extract archive members to resolve undefined weak symbols".
This commit changes all Makefiles to use partial linking (ld -r) instead
of creating library archives, which forces all symbols to participate in
linking, allowing non-weak symbols to override weak symbols as intended.
This approach is also used by Linux, from which the gmake function
cmd_link_o_target (defined in config.mk and used in all Makefiles) is
inspired.
The name of each former library archive is preserved except for
extensions which change from ".a" to ".o". This commit updates
references accordingly where needed, in particular in some linker
scripts.
This commit reveals board configurations that exclude some features but
include source files that depend these disabled features in the build,
resulting in undefined symbols. Known such cases include:
- disabling CMD_NET but not CMD_NFS;
- enabling CONFIG_OF_LIBFDT but not CONFIG_QE.
Signed-off-by: Sebastien Carlier <sebastien.carlier@gmail.com>
The change is currently needed to be able to remove the board
configuration scripting from the top level Makefile and replace it by
a simple, table driven script.
Moving this configuration setting into the "CONFIG_*" name space is
also desirable because it is needed if we ever should move forward to
a Kconfig driven configuration system.
The appropriate include/asm-$ARCH directory should already by symlinked
to include/asm so using the whole "asm-$ARCH" path is unnecessary.
This change should also allow us to move the include/asm-$ARCH
directories into their appropriate lib/$ARCH/ directories.
* add's at91_emac (AT91RM9200) network driver (NET_MULTI api)
* enable driver with CONFIG_DRIVER_AT91EMAC
* generic PHY initialization
* modify AT91RM9200 boards to use NET_MULTI driver
* the drivers has been tested with LXT971 Phy and DM9161 Phy at
MII and RMII interface
Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
all arm boards except a few use the same cpu linker script
so move it to cpu/$(CPU)
that could be overwrite in following order
SOC
BOARD
via the corresponding config.mk
actually the timer init use the interrupt_init as init callback
which make the interrupt and timer implementation difficult to follow
so now rename it as int timer_init(void) and use interrupt_init for interrupt
btw also remane the corresponding file to the functionnality implemented
as ixp arch implement two timer - one based on interrupt - so all the timer
related code is moved to timer.c
Signed-off-by: Detlev Zundel <dzu@denx.de>
A recent gcc added a new unaligned rodata section called '.rodata.str1.1',
which needs to be added the the linker script. Instead of just adding this
one section, we use a wildcard ".rodata*" to get all rodata linker section
gcc has now and might add in the future.
However, '*(.rodata*)' by itself will result in sub-optimal section
ordering. The sections will be sorted by object file, which causes extra
padding between the unaligned rodata.str.1.1 of one object file and the
aligned rodata of the next object file. This is easy to fix by using the
SORT_BY_ALIGNMENT command.
This patch has not be tested one most of the boards modified. Some boards
have a linker script that looks something like this:
*(.text)
. = ALIGN(16);
*(.rodata)
*(.rodata.str1.4)
*(.eh_frame)
I change this to:
*(.text)
. = ALIGN(16);
*(.eh_frame)
*(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*)))
This means the start of rodata will no longer be 16 bytes aligned.
However, the boundary between text and rodata/eh_frame is still aligned to
16 bytes, which is what I think the real purpose of the ALIGN call is.
Signed-off-by: Trent Piepho <xyzzy@speakeasy.org>
The environment is the canonical storage location of the mac address, so
we're killing off the global data location and moving everything to
querying the env directly.
Rather than have common ppc code call a board-specific function like
load_sernum_ethaddr(), have each board call it in its own board-specific
misc_init_r() function.
The boards that get converted here are:
- kup4k/kup4x
- pcs440ep
- tqm8xx
CC: Ben Warren <biggerbadderben@gmail.com>
CC: Stefan Roese <sr@denx.de>
Most of the bss initialization loop increments 4 bytes
at a time. And the loop end is checked for an 'equal'
condition. Make the bss end address aligned by 4, so
that the loop will end as expected.
Signed-off-by: Selvamuthukumar <selva.muthukumar@e-coninfotech.com>
This fixes a naming bug for at91rm9200 lowlevel init code:
NOR boot flash is on chipselect 0, not chipselect 2. This
makes code use the register name from chip datasheets.
Kimmo Leppala / Sysart and
Timo Tuunainen / Sysart
