path: root/board/m501sk
2009-01-06m501sk: move to the common memory setupJean-Christophe PLAGNIOL-VILLARD
2009-01-06at91rm9200: rename lowlevel init value to CONFIG_SYS_Jean-Christophe PLAGNIOL-VILLARD
2008-07-02Cleanup: replace hard-wired $(AR) 'crv' settings by $(ARFLAGS)Wolfgang Denk
2008-03-30use correct at91rm9200 register name in m501sk boardJean-Christophe PLAGNIOL-VILLARD
This fixes a naming bug for at91rm9200 lowlevel init code: NOR boot flash is on chipselect 0, not chipselect 2. This makes code use the register name from chip datasheets. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-03-09m501sk: Fix out of tree buildingWolfgang Denk
2008-02-14Support for Artila M-501 starter kitTimo Tuunainen
Kimmo Leppala / Sysart and Timo Tuunainen / Sysart
