2003-04-27 | * LWMON extensions: | wdenk | |
- Splashscreen support - modem support - sysmon support - temperature dependend enabling of LCD * Allow booting from old "PPCBoot" disk partitions * Add support for TQM8255 Board / MPC8255 CPU | |||
2003-01-11 | * Restrict baudrate settings on LWMON to higher speedsLABEL_2003_01_11_1050 | wdenk | |
when watchdog is on * Update baudrate in bd_info when it gets changed * Add watchdog trigger points while waiting for serial port (so far only 8xx -- needed on LWMON with 100ms watchdog) * Improve command line tool to access the U-Boot's environment (figuration of the utility, using a config file) | |||
2002-11-02 | Initial revision | wdenk | |
2002-10-11 | Initial revision | wdenk | |
2002-07-20 | Initial revision | wdenk | |
2001-04-28 | Initial revision | wdenk | |
2001-03-29 | Initial revision | wdenk | |
