path: root/board/lwmon5
2008-07-10ppc4xx: Fix printf format warnings now visible with the updated format checkStefan Roese
This patch fixes ppc4xx related printf format warning. Those warnings are now visible since patch dc4b0b38d4aadf08826f6c31270f1eecd27964fd [Fix printf errors.] by Andrew Klossner has been applied. Thanks, this is really helpful. Signed-off-by: Stefan Roese <sr@denx.de>
2008-06-03ppc4xx: Remove implementations of testdram()Stefan Roese
This patch removes the used testdram() implementations of the board that are maintained by myself. Signed-off-by: Stefan Roese <sr@denx.de>
2008-04-29ppc4xx: Change ECC initialization on lwmon5 to use clean_dcache_range()Stefan Roese
As it seems the "old" ECC initialization routine by using dflush() didn't write all lines in the dcache back to memory on lwmon5. This could lead to ECC error upon Linux booting. This patch changes the program_ecc() routine to now use clean_dcache_range() instead of dflush(). clean_dcache_range() uses dcbst which is exactly what we want in this case. Since dflush() is known is cause problems, this routine will be removed completely and replaced by clean_dcache_range() with an additional patch. Signed-off-by: Stefan Roese <sr@denx.de>
2008-04-25Merge branch 'master' of /home/wd/git/u-boot/lwmon5Wolfgang Denk
Conflicts: common/cmd_bootm.c common/cmd_log.c include/common.h post/board/lwmon5/Makefile post/board/lwmon5/dsp.c post/board/lwmon5/dspic.c post/board/lwmon5/fpga.c post/board/lwmon5/gdc.c post/board/lwmon5/sysmon.c post/board/lwmon5/watchdog.c Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-04-22lwmon5 watchdog: limit trigger rateYuri Tikhonov
Limit the rate of h/w watch-dog triggering on the LWMON5 board by the CONFIG_WD_MAX_RATE value. Note that an earlier version of this patch which used microseconds instead of ticks dis not work. The problem was that we used usec2ticks() to convert microseconds into ticks. usec2ticks() uses get_tbclk(), which in turn calls get_sys_info(). It turns out that this function does a lot of prolonged operations (like divisions) which take too much time so we do not trigger the watchdog in time, and it resets the system. Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-03-27ppc4xx: Enable ECC on LWMON5Stefan Roese
Since all ECC related problems seem to be resolved on LWMON5, this patch now enables ECC support. We have to write the ECC bytes by zeroing and flushing in smaller steps, since the whole 256MByte takes too long for the external watchdog. Signed-off-by: Stefan Roese <sr@denx.de>
2008-03-18Fix backlight in the lwmon5 POST.Yuri Tikhonov
Backlight was switched on even when temperature was too low. Signed-off-by: Dmitry Rakhchev <rda@emcraft.com> Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-03-18Add support for the lwmon5 board reset via GPIO58.Yuri Tikhonov
2008-03-18The patch adds new POST tests for the Lwmon5 board. These are:Yuri Tikhonov
* External Watchdog test; * dsPIC tests; * FPGA test; * GDC test; * Sysmon tests. Signed-off-by: Dmitry Rakhchev <rda@emcraft.com> Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
Backlight was switcehd on even when temperature was too low. Signed-off-by: Dmitry Rakhchev <rda@emcraft.com> Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-03-18The patch adds new POST tests for the Lwmon5 board.Yuri Tikhonov
These are: * External Watchdog test; * dsPIC tests; * FPGA test; * GDC test; * Sysmon tests. Signed-off-by: Dmitry Rakhchev <rda@emcraft.com> Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-01-11ppc4xx: Rework Lime support for lwmon5Anatolij Gustschin
Rework Lime support for lwmon5 using new video driver Signed-off-by: Anatolij Gustschin <agust@denx.de>
2008-01-09Merge branch 'lwmon5-no-ocm'Stefan Roese
2008-01-09ppc4xx: Change LWMON5 to not use OCM for init-ram and POST anymoreStefan Roese
This patch configures the LWMON5 port to use d-cache as init-ram and the unused GPT0_COMP6 as POST WORD storage. Signed-off-by: Stefan Roese <sr@denx.de>
2008-01-04PPC4xx: Remove sdram.h from board/lwmon5Larry Johnson
These definitions are now in "include/ppc440.h". Signed-off-by: Larry Johnson <lrj@acm.org>
2008-01-04PPC4xx: Use common code for LWMON5 board SDRAM supportLarry Johnson
This patch also modifies the functionality of the code so that the data-eye search is now done with with the cache disabled. Signed-off-by: Larry Johnson <lrj@acm.org>
2007-12-27Add definitions for 440EPx/GRx SDRAM controller to ppc440.hLarry Johnson
This patch adds the Denali SDRAM controller definitions to "ppc440.h". It also fixes two typos in the definitions, so the board-specific "sdram.h" files containing these definitions are also fixed to avoid compiler warnings. Signed-off-by: Larry Johnson <lrj@acm.org>
2007-12-11Merge commit 'u-boot/master' into for-1.3.1Stefan Roese
Conflicts: drivers/rtc/Makefile
2007-11-13ppc4xx: lwmon5: Change PHY reset sequence for PHY MDIO address latchingStefan Roese
2007-10-31ppc4xx: Consolidate some of the 405 and 440 macros/structs into 4xxStefan Roese
This patch moves some common 4xx macros and the PPC405_SYS_INFO/ PPC440_SYS_INFO structure into the common ppc4xx.h header. Lot's of other macros are good candidates to be consolidated this way in the future. Signed-off-by: Stefan Roese <sr@denx.de>
2007-08-23ppc4xx: Add support for 2nd I2C EEPROM on lwmon5 boardStefan Roese
This patch adds support for the 2nd EEPROM (AT24C128) on the lwmon5 board. Now the "eeprom" command can be used to read/write from/to this device. Additionally a new command was added "eepromwp" to en-/disable the write-protect of this 2nd EEPROM. The 1st EEPROM is not affected by this write-protect command. Signed-off-by: Stefan Roese <sr@denx.de>
2007-08-21Merge with /home/stefan/git/u-boot/u-boot-ppc4xxStefan Roese
2007-08-21ppc4xx: Add matrix kbd support to lwmon5 board (440EPx based)Stefan Roese
This patch adds support for the matrix keyboard on the lwmon5 board. Since the implementation in the dsPCI is kind of compatible with the "old" lwmon board, most of the code is copied from the lwmon board directory. Signed-off-by: Stefan Roese <sr@denx.de>
2007-08-18lib_ppc: make board_add_ram_info weakKim Phillips
platforms wishing to display RAM diagnostics in addition to size, can do so, on one line, in their own board_add_ram_info() implementation. this consequently eliminates CONFIG_ADD_RAM_INFO. Thanks to Stefan for the hint. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-07-31ppc4xx: Update 440EPx lwmon5 board supportStefan Roese
- Clear ECC status regs after ECC POST test - Set dcbz for ECC generation with caches enabled as default - Code cleanup Signed-off-by: Stefan Roese <sr@denx.de>
2007-07-26ppc4xx: lwmon5: Update Lime initializationAnatolij Gustschin
Change Lime SDRAM initialization to now support 100MHz and 133MHz (if enabled). Also the framebuffer is initialized to display a blue rectangle with a white border. Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2007-07-24ppc4xx: lwmon5: Support for 128 MByte NOR FLASH addedStefan Roese
The used Intel NOR FLASH chips have internally two dies, and are now treated as two seperate chips. Signed-off-by: Stefan Roese <sr@denx.de>
2007-07-24ppc4xx: Fix lwmon5 interrupt controller setup (polarity, trigger...)Stefan Roese
As suggested by Hakan Eryigit, here an updated setup for the lwmon5 interrupt controller. Signed-off-by: Stefan Roese <sr@denx.de>
2007-07-20POST: Add ECC POST for the lwmon5 boardPavel Kolesnikov
This patch adds ECC Post test for the Lwmon5 board based on PPC440EPx to U-Boot. Signed-off-by: Pavel Kolesnikov <concord@emcraft.com> Acked-by: Yuri Tikhonov <yur@emcraft.com> Acked-by: Stefan Roese <sr@denx.de>
2007-07-16ppc4xx: Code cleanupStefan Roese
2007-07-04ppc4xx: Update lwmon5 boardStefan Roese
- Add optional ECC generation routine to preserve existing RAM values. This is needed for the Linux log-buffer support - Add optional DDR2 setup with CL=4 - GPIO50 not used anymore - Lime register setup added Signed-off-by: Stefan Roese <sr@denx.de>
2007-06-25ppc4xx: Add pci_pre_init() for 405 boardsStefan Roese
This patch removes the CFG_PCI_PRE_INIT option completely, since it's not needed anymore with the patch from Matthias Fuchs with the "weak" pci_pre_init() implementation. Signed-off-by: Stefan Roese <sr@denx.de>
2007-06-20Coding style cleanup. Refresh CHANGELOG.Wolfgang Denk
2007-06-15[ppc4xx] Add initial lwmon5 board supportStefan Roese
This patch adds initial support for the Liebherr lwmon5 board euqipped with an AMCC 440EPx PowerPC. Signed-off-by: Stefan Roese <sr@denx.de>
