path: root/board/lwmon5/u-boot.lds
2007-06-15[ppc4xx] Add initial lwmon5 board supportStefan Roese
This patch adds initial support for the Liebherr lwmon5 board euqipped with an AMCC 440EPx PowerPC. Signed-off-by: Stefan Roese <sr@denx.de>
