path: root/board/lpc2292sodimm
2008-07-02Cleanup: replace hard-wired $(AR) 'crv' settings by $(ARFLAGS)Wolfgang Denk
2007-09-15Fix cases where DECLARE_GLOBAL_DATA_PTR was not declared as globalWolfgang Denk
2007-05-09Remove the deleted files for the SMN42 patchPeter Pearse
2007-05-09New board SMN42 branchPeter Pearse
2007-02-12LPC2292: patch from Siemens.Gary Jennejohn
2007-01-30LPC2292 SODIMM port coding style cleanup.Wolfgang Denk
2007-01-24Add port for the lpc2292sodimm evaluation board from EmbeddedArtistsGary Jennejohn
