path: root/board/logodl
2005-04-02Prepare for SoC rework of ARM code:wdenk
- rename CONFIG_BOOTBINFUNC into CONFIG_INIT_CRITICAL - rename memsetup into lowlevel_init (function name and source files)
2004-02-08Patch by Anders Larsen, 09 Jan 2004:wdenk
ARM memory layout fixes: the abort-stack is now set up in the correct RAM area, and the BSS is zeroed out as it should be. Furthermore, the magic variables 'armboot_end' and 'armboot_end_data' of the linker scripts are replaced by '__bss_start' and '_end', resp., which is a further step to eliminate unnecessary differences between the implementation of the CPU architectures.
2003-09-18* Patches by Anders Larsen, 17 Sep 2003:wdenk
- fix spelling errors - set GD_FLG_DEVINIT flag only after device function pointers are valid - Allow CFG_ALT_MEMTEST on systems where address zero isn't writeable - enable 3.rd UART (ST-UART) on PXA(XScale) CPUs - trigger watchdog while waiting in serial driver
2003-06-26* Patches by Robert Schwebel, 26 Jun 2003:U-Boot-0_4_0wdenk
- logdl - csb226 - innokom * Patch by Pantelis Antoniou, 25 Jun 2003: update NetVia with V2 board support
2003-06-19Patches by Robert Schwebel, 14 Jun 2003:wdenk
- add support for Logotronic DL datalogger board - cleanup serial line after kermit binary download - add debugX macro (debug level support) - update mach-types.h to latest arm.linux.org.uk master list.
