path: root/board/logodl
2009-10-04Convert SMC91111 Ethernet driver to CONFIG_NET_MULTI APIBen Warren
All in-tree boards that use this controller have CONFIG_NET_MULTI added Also: - changed CONFIG_DRIVER_SMC91111 to CONFIG_SMC91111 - cleaned up line lengths - modified all boards that override weak function in this driver - modified all eeprom standalone apps to work with new driver - updated blackfin standalone EEPROM app after testing Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-12arm: unify linker scriptJean-Christophe PLAGNIOL-VILLARD
all arm boards except a few use the same cpu linker script so move it to cpu/$(CPU) that could be overwrite in following order SOC BOARD via the corresponding config.mk Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2007-06-22[PCS440EP] upgrade the PCS440EP board:Heiko Schocher
- Show on the Status LEDs, some States of the board. - Get the MAC addresses from the EEProm - use PREBOOT - use the CF on the board. - check the U-Boot image in the Flash with a SHA1 checksum. - use dynamic TLB entries generation for the SDRAM Signed-off-by: Heiko Schocher <hs@denx.de>
2005-04-02Prepare for SoC rework of ARM code:wdenk
- rename CONFIG_BOOTBINFUNC into CONFIG_INIT_CRITICAL - rename memsetup into lowlevel_init (function name and source files)
2004-02-08Patch by Anders Larsen, 09 Jan 2004:wdenk
ARM memory layout fixes: the abort-stack is now set up in the correct RAM area, and the BSS is zeroed out as it should be. Furthermore, the magic variables 'armboot_end' and 'armboot_end_data' of the linker scripts are replaced by '__bss_start' and '_end', resp., which is a further step to eliminate unnecessary differences between the implementation of the CPU architectures.
2003-09-18* Patches by Anders Larsen, 17 Sep 2003:wdenk
- fix spelling errors - set GD_FLG_DEVINIT flag only after device function pointers are valid - Allow CFG_ALT_MEMTEST on systems where address zero isn't writeable - enable 3.rd UART (ST-UART) on PXA(XScale) CPUs - trigger watchdog while waiting in serial driver
2003-06-26* Patches by Robert Schwebel, 26 Jun 2003:U-Boot-0_4_0wdenk
- logdl - csb226 - innokom * Patch by Pantelis Antoniou, 25 Jun 2003: update NetVia with V2 board support
2003-06-19Patches by Robert Schwebel, 14 Jun 2003:wdenk
- add support for Logotronic DL datalogger board - cleanup serial line after kermit binary download - add debugX macro (debug level support) - update mach-types.h to latest arm.linux.org.uk master list.
