path: root/board/logicpd
2011-04-27IMX: MX31: Cleanup include files and drop nasty #ifdef in driversStefano Babic
As exception among the i.MX processors, the i.MX31 has headers without general names (mx31-regs.h, mx31.h instead of imx-regs.h and clock.h). This requires several nasty #ifdef in the drivers to include the correct header. The patch cleans up the driver and renames the header files as for the other i.MX processors. Signed-off-by: Stefano Babic <sbabic@denx.de>
2010-12-21Move DECLARE_GLOBAL_DATA_PTR to file scopeJohn Rigby
It can be optimised out by the compiler otherwise resulting in obscure errors like a board not booting. This has been documented in README since 2006 when these were first fixed up for GCC 4.x. Signed-off-by: John Rigby <john.rigby@linaro.org> Fix some additional places. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-By: Albert ARIBAUD <albert.aribaud@free.fr>
2010-11-30OMAP3: Zoom2: Fix ARM relocation supportDirk Behme
Signed-off-by: Dirk Behme <dirk.behme@googlemail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-30OMAP3: Zoom1: Fix ARM relocation supportDirk Behme
2010-11-29AM3517:Fix for ARM Relocation supportVaibhav Hiremath
Also change the CONFIG_SYS_TEXT_BASE to 0x80008000, required with relocation support. This is the load address for primary boot loader (x-loader). Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-10-19Merge branch 'elf_reloc'Wolfgang Denk
Conflicts: arch/arm/include/asm/config.h board/LaCie/edminiv2/config.mk board/karo/tx25/config.mk board/logicpd/imx27lite/config.mk doc/README.arm-relocation Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-10-19Merge branch 'master' of git://git.denx.de/u-boot-imxWolfgang Denk
Conflicts: board/logicpd/imx31_litekit/config.mk boards.cfg Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-10-19i.MX31: Fix Litekit board to use new ARM relocation support.Magnus Lilja
Tested on hardware. Boots Linux nicely. Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com>
2010-10-13arm926ejs, magnesium: add support for ELF relocationsHeiko Schocher
2010-09-19ARM: implement relocation for ARM926Heiko Schocher
Change the implementation for arm926 to relocate the code to an arbitrary address in RAM. Adapt the TX25 (i.MX25), magnesium board to test the changes. On the tx25 board TEXT_BASE is set to the final relocation address to prevent one more copying of u-boot code when relocating. More info see: doc/README.arm-relocation da850 board: Tested-by: Ben Gardiner <bengardiner@nanometrics.ca> Portions of this work were supported by funding from the CE Linux Forum. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Ben Gardiner <bengardiner@nanometrics.ca>
2010-07-05ARM: Rename arch/arm/cpu/arm_cortexa8 to armv7Steve Sakoman
The purpose of this patch is to prepare for adding the OMAP4 architecture, which is Cortex A9 Cortex A8 and A9 both belong to the armv7 architecture, hence the name change. The two architectures are similar enough that substantial code can be shared. Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-06-08AM35x: Add support for AM3517EVMVaibhav Hiremath
This patch adds basic support for the AM3517EVM. It includes: - Board files (.c and .h) - Default configuration file - Updates for Makefile Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com> Signed-off-by: Sanjeev Premi <premi@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-04-30arm, i.mx27: add support for magnesium board from projectiondesignHeiko Schocher
This patch adds support for the magnesium board from projectiondesign. This board uses i.MX27 SoC and has 8MB NOR flash, 128MB NAND flash, FEC ethernet controller integrated into i.MX27. As this port is based on the imx27lite port, common config options are collected in include/configs/imx27lite-common.h Signed-off-by: Heiko Schocher <hs@denx.de>
2010-04-24serial: struct serial_device: add uninit() entry for driversAnatolij Gustschin
Subsequent patch extends mpc512x serial driver to support multiple PSC ports. The driver will provide an uninit() function to stop the serial controller and to disable the controller's clock. Adding uninit() entry to struct serial_device allows disabling the serial controller after usage of a stdio serial device. This patch adds uninit() entry to the struct serial_device and fixes initialization of this structure in the code accordingly. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2010-04-13arm: Move cpu/$CPU to arch/arm/cpu/$CPUPeter Tyser
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2010-01-04TWL4030: make LEDs selectable for twl4030_led_init()Grazvydas Ignotas
Not all boards have both LEDs hooked, so enabling both on boards with single LED will just waste power. Make it possible to choose LEDs by adding argument to twl4030_led_init(). Using this turn on only LEDB for pandora, leave both LEDs on for all other boards, as it was before this patch. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
2009-12-21Merge branch 'master' of git://git.denx.de/u-boot-usbWolfgang Denk
2009-12-20OMAP3 zoom2 Use usbtty if the debug board is not connected.Tom Rix
The preferred serial output comes from the debug board. When the debug board is disconnected, fall back on using usbtty from the usb connector on the Zoom2 board. This shows up as /dev/ttyACM0 in a linux host. Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-12-14Net: Clean up LAN91C96 SupportBen Warren
A previous Commit converted the LAN91C96 Ethernet driver to using the CONFIG_NET_MULTI API, but did not include full board support. This patch finishes the job. Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-10-28Coding Style cleanup; update CHANGELOG, prepare -rc1v2009.11-rc1Wolfgang Denk
2009-10-24TI OMAP3: make gpmc_config as constNishanth Menon
gpmc_config should not be a variant as it is board specific hence make it a const parameter Fixes issues identified by Dirk: - build issue for zoom2 - warnings for all other OMAP3 platforms using nand/onenand etc Signed-off-by: Nishanth Menon <nm@ti.com>
2009-10-18Zoom2 Fix serial gpmc setupTom Rix
The offset to the chip select is incorrect. The change 187af954cf7958c24efcf0fd62289bbdb4f1f24e, omap3: embedd gpmc_cs into gpmc config struct introduced a problem with the serial gpmc setup. This patch reverts the chip select to its previous value. The symptoms of this problem are that the Zoom2 currently hangs. This was run tested on Zoom2. Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-10-13OMAP3: Clean up whitespace in mux configsOlof Johansson
Switch from space-based indentation to tab-based in mux configs, as pointed out by WD at: http://lists.denx.de/pipermail/u-boot/2009-September/061241.html Nothing but whitespace changes in this patch (diff -w gives no output). Signed-off-by: Olof Johansson <olof@lixom.net>
2009-09-05arm: move Logicpd's boards to board/logicpd/Jean-Christophe PLAGNIOL-VILLARD
2009-09-01imx27lite: add support for imx27lite board from LogicPDIlya Yanok
This patch adds support for i.MX27-LITEKIT development board from LogicPD. This board uses i.MX27 SoC and has 2MB NOR flash, 64MB NAND flash, FEC ethernet controller integrated into i.MX27. Signed-off-by: Ilya Yanok <yanok@emcraft.com> Acked-by: Wolfgang Denk <wd@denx.de>
