path: root/board/logicpd
2009-10-28Coding Style cleanup; update CHANGELOG, prepare -rc1v2009.11-rc1Wolfgang Denk
2009-10-24TI OMAP3: make gpmc_config as constNishanth Menon
gpmc_config should not be a variant as it is board specific hence make it a const parameter Fixes issues identified by Dirk: - build issue for zoom2 - warnings for all other OMAP3 platforms using nand/onenand etc Signed-off-by: Nishanth Menon <nm@ti.com>
2009-10-18Zoom2 Fix serial gpmc setupTom Rix
The offset to the chip select is incorrect. The change 187af954cf7958c24efcf0fd62289bbdb4f1f24e, omap3: embedd gpmc_cs into gpmc config struct introduced a problem with the serial gpmc setup. This patch reverts the chip select to its previous value. The symptoms of this problem are that the Zoom2 currently hangs. This was run tested on Zoom2. Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-10-13OMAP3: Clean up whitespace in mux configsOlof Johansson
Switch from space-based indentation to tab-based in mux configs, as pointed out by WD at: http://lists.denx.de/pipermail/u-boot/2009-September/061241.html Nothing but whitespace changes in this patch (diff -w gives no output). Signed-off-by: Olof Johansson <olof@lixom.net>
2009-09-05arm: move Logicpd's boards to board/logicpd/Jean-Christophe PLAGNIOL-VILLARD
2009-09-01imx27lite: add support for imx27lite board from LogicPDIlya Yanok
This patch adds support for i.MX27-LITEKIT development board from LogicPD. This board uses i.MX27 SoC and has 2MB NOR flash, 64MB NAND flash, FEC ethernet controller integrated into i.MX27. Signed-off-by: Ilya Yanok <yanok@emcraft.com> Acked-by: Wolfgang Denk <wd@denx.de>
