path: root/board/logicpd
2023-01-20global: Finish CONFIG -> CFG migrationTom Rini
At this point, the remaining places where we have a symbol that is defined as CONFIG_... are in fairly odd locations. While as much dead code has been removed as possible, some of these locations are simply less obvious at first. In other cases, this code is used, but was defined in such a way as to have been missed by earlier checks. Perform a rename of all such remaining symbols to be CFG_... rather than CONFIG_... Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2022-08-04Audit <flash.h> inclusionTom Rini
A large number of files include <flash.h> as it used to be how various SPI flash related functions were found, or for other reasons entirely. In order to migrate some further CONFIG symbols to Kconfig we need to not include flash.h in cases where we don't have a NOR flash of some sort enabled. Furthermore, in cases where we are in common code and it doesn't make sense to try and further refactor the code itself in to new files we need to guard this inclusion. Signed-off-by: Tom Rini <trini@konsulko.com>
2022-03-10ARM: am3517_evm: Remove hard-coded pin muxingAdam Ford
With updated device trees now supporting pinmuxing for USB, ethernet, MMC, and other peripherals necessary to start MLO and U-Boot, the hard-coded pinmux options can be removed since they are now handed by DM and only muxed when the respective peripheral needs it. Signed-off-by: Adam Ford <aford173@gmail.com> Tested-by: Derald D. Woods <woods.technical@gmail.com>
2022-03-10ARM: omap3_logic: Remove hard-coded USB muxingAdam Ford
With recent fixes to USB pinmuxing in the device trees, there is no need to hard-code the pinmuxing in this table. It is all handled in DM now. Signed-off-by: Adam Ford <aford173@gmail.com>
2022-03-10ARM: am3517-evm: Remove more non-DM legacy ethernet reset codeAdam Ford
The ethernet controller is DM compliant, and the device tree defines it. There is no need to manually handle pulling the ethernet out of reset. Signed-off-by: Adam Ford <aford173@gmail.com> Tested-by: Derald D. Woods <woods.technical@gmail.com>
2021-10-11ARM: omap3_logic: Cleanup usage of MUX_VALAdam Ford
The macro called MUX_VAL generates a writel instruction with semicolon at the end. This table was written to use semicolons, however one was missed: MUX_VAL(CP(SYS_BOOT2), (IEN | PTD | DIS | M4)) /* GPIO_4 */ Since the extra semicolon is unnecessary with the use of the macro, remove all of them, and cleanup whitespace. Reviewed-by: Wolfgang Denk <wd@denx.de> Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Adam Ford <aford173@gmail.com>
2021-09-30WS cleanup: remove SPACE(s) followed by TABWolfgang Denk
2021-09-30WS cleanup: remove trailing empty linesWolfgang Denk
2021-02-02common: Drop asm/global_data.h from common headerSimon Glass
Move this out of the common header and include it only where needed. In a number of cases this requires adding "struct udevice;" to avoid adding another large header or in other cases replacing / adding missing header files that had been pulled in, very indirectly. Finally, we have a few cases where we did not need to include <asm/global_data.h> at all, so remove that include. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2020-07-17treewide: convert bd_t to struct bd_info by coccinelleMasahiro Yamada
The Linux coding style guide (Documentation/process/coding-style.rst) clearly says: It's a **mistake** to use typedef for structures and pointers. Besides, using typedef for structures is annoying when you try to make headers self-contained. Let's say you have the following function declaration in a header: void foo(bd_t *bd); This is not self-contained since bd_t is not defined. To tell the compiler what 'bd_t' is, you need to include <asm/u-boot.h> #include <asm/u-boot.h> void foo(bd_t *bd); Then, the include direcective pulls in more bloat needlessly. If you use 'struct bd_info' instead, it is enough to put a forward declaration as follows: struct bd_info; void foo(struct bd_info *bd); Right, typedef'ing bd_t is a mistake. I used coccinelle to generate this commit. The semantic patch that makes this change is as follows: <smpl> @@ typedef bd_t; @@ -bd_t +struct bd_info </smpl> Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
2020-07-09logicpd: Drop omap3 zoom1Jagan Teki
OF_CONTROL, DM_SPI and other driver model migration deadlines are expired for this board. Drop it. Cc: Nishanth Menon <nm@ti.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2020-06-02imx: Remove ARCH= references from documentationTom Rini
When building U-Boot we select the architecture via Kconfig and not ARCH being passed in via the environment or make cmdline. Cc: Adam Ford <aford173@gmail.com> Cc: Vanessa Maegima <vanessa.maegima@nxp.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Igor Opaniuk <igor.opaniuk@toradex.com> Cc: Manivannan Sadhasivam <manivannan.sadhasivam@linaro.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2020-05-25Merge tag 'ti-v2020.07-rc3' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-ti - Enable DM_ETH on omap3_logic board - Enable Caches in SPL for K3 platforms - Enable backup boot mode support for J721E - Update the DDR timings for AM654 EVM - Add automated tests for RX-51
2020-05-19ARM: omap3_logic boards: Convert to DM_ETHAdam Ford
With the converstion of SMC911x to DM, this can facilitate the omap3 boards from LogicPD (now called Beacon EmbeddedWorks) to be converted. There isn't a clean solution to doing this in phases, so the boards are all being done together to avoid breaking functionality. Because the GPMC bus hasn't been converted, the -u-boot.dtsi node needs to show the address of the ethernet controller for each board. The board file, which is common betwen the OMAP35 and DM37 SOM LV and Torpedo boards, can remove the manual ethernet initialization, but it still needs to register the address and GPMC configuration for the Ethernet controller which is now being moved around to board_late_init(). Lastly, this patch updates the various config files to add the reference for DM_ETH and remove the SMC address, which is now fetched from the newly created device tree nodes. Signed-off-by: Adam Ford <aford173@gmail.com>
2020-05-18common: Drop init.h from common headerSimon Glass
Move this uncommon header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop net.h from common headerSimon Glass
Move this header out of the common header. Network support is used in quite a few places but it still does not warrant blanket inclusion. Note that this net.h header itself has quite a lot in it. It could be split into the driver-mode support, functions, structures, checksumming, etc. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-12-27ARM: imx6q_logic: Cleanup boot sequence checkAdam Ford
The board_boot_order() function currenly assumes that the boot source is MMC/eMMC, but this isn't true for the NAND devices. This patch cleans up board_boot_order() to check for NAND, SD, ESD, MMC or EMMC. Anything beyond these are not supported, so it will default back to the serial downloader if any of those devices are not available. Fixes: 9fb50c68daa6 ("ARM: imx6q_logic: Fix MMC2 booting") Signed-off-by: Adam Ford <aford173@gmail.com>
2019-12-02common: Move some board functions out of common.hSimon Glass
A number of board function belong in init.h with the others. Move them. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-12-02common: Move serial functions out of common.hSimon Glass
These functions belong in serial.h so move them over. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-11-07ARM: omap3_logic: Power on MMC when setting up PMICAdam Ford
The PMIC enables power to the MMC card by default, but depending on the state it was left when restarted, it's possible the MMC may be powered down. This patch patch explicitly tells the twl4030 to power the MMC. Signed-off-by: Adam Ford <aford173@gmail.com>
2019-10-13ARM: imx6q_logic: Remove legacy pinmuxing code from board file.Adam Ford
With the OCRAM expanded to 256KB and the SPL_PINCTRL enabled with -u-boot.dtsi entries to include the pinmuxing in SPL, the manual code setting up the pinmux can go away. This patch removes the legacy pinmuxing code from the board file. Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Fabio Estevam <festevam@gmail.com>
2019-10-08ARM: imx6q_logic: Fix MMC2 bootingAdam Ford
With the reverting of a previous change to spl_boot_device, this board needs a new solution to determining if we're booting from MMC1 or MMC2. This patch creates board_boot_order function which overrides the standard, and returns not only MMC1, or MMC2, but also can fall back to NAND or the serial downloader should other boot options fail. Signed-off-by: Adam Ford <aford173@gmail.com>
2019-10-08ARM: imx6q_logic: Enable DM_SERIALAdam Ford
In order to call preloader_console_init from board_init_f when DM_SERIAL is enabled, it neesd to call spl_early_init() to get early access to DM and device tree. This patch calls spl_early_init just before preloader_console_init() and enables DM_SERIAL and SPL_DM_SERIAL. Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Fabio Estevam <festevam@gmail.com>
2019-10-08ARM: imx6qlogic: Cleanup board_init_fAdam Ford
Per the workflow found in crt0.S, we don't need to clear BSS in board_init_f nor do we need to call board_init_r since that will be done for us from main when we return from board_init_f. This patch removes the unneeded function calls from board_init_f. Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Fabio Estevam <festevam@gmail.com>
2019-10-04ARM: dts: imx6q-logicpd: Add missing imx6q-logicpd-u-boot for SPLAdam Ford
The SPL device tree is missing the entires for gpio1, uart1, usdhc1 and usdhc2. This creates the missing imx6q-logicpd-u-boot.dtsi file which will enable these functions so SPL can properly setup UART, detect microSD card, and startup. Fixes: 8f4691e31a18 ("ARM: imx6q_logic: With SPL_OF_CONTROL enabled, remove MMC init") Signed-off-by: Adam Ford <aford173@gmail.com>
2019-08-11env: Drop environment.h header file where not neededSimon Glass
This header file is now only used by files that access internal environment features. Drop it from various places where it is not needed. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2019-08-11env: Move env_set() to env.hSimon Glass
Move env_set() over to the new header file. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2019-07-27Merge branch '2019-07-26-ti-imports'Tom Rini
- Bring in the rest of the J271E platform - Various OMAP3/AM3517, DA850 fixes
2019-07-27ARM: am3517_evm: Fix pin muxing to enable EHCI Host in the futureAdam Ford
This patch enables the pinmuxing to support gpio_57 for phy reset and fixes the pinmuxing for the ECHI tranceiver. The clocks don't appear to by fully enabled yet, so OMAP-EHCI on am3517 is still not yet working, but we're one step closer. Signed-off-by: Adam Ford <aford173@gmail.com>
2019-07-27ARM: omap3_logic: Enable OMAP EHCI support for SOM-LV BoardsAdam Ford
The SOM-LV boards support the OMAP EHCI driver using port 2. With the driver updated to support device tree, this patch sets the corresponding pin muxing for the tranceiver as well as the reset pin. Signed-off-by: Adam Ford <aford173@gmail.com>
2019-07-27Merge tag 'u-boot-imx-20190719' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-imx u-boot-imx-20190719 - CCF for i.MX6 - nandbcb command to write SPL into NAND - Switch to DM (i.MX28) - Boards: Toradex, engicam, DH - Fixes for i.MX8 - Fixes for i.MX7ULP Travis: https://travis-ci.org/sbabic/u-boot-imx/builds/561147504
2019-07-26ARM: am3517-evm: Remove non-DM legacy codeAdam Ford
With both SPL and U-Boot now supporting DM, we can start removing legacy code. This patch removes the legacy MMC initalization and legacy I2C initialization since both are now available via DM and device tree. Signed-off-by: Adam Ford <aford173@gmail.com>
2019-07-26ARM: am3517-evm: Remove manual ethernet reset codeAdam Ford
The reset line going to the ethernet controller is controlled by a global reset controlling multiple peripherals. There is no need to manually invoke the reset. Signed-off-by: Adam Ford <aford173@gmail.com>
2019-07-25net: davinci_emac: convert to using the driver modelBartosz Golaszewski
Now that we removed all legacy boards selecting TI_EMAC we can completely convert the driver code to using the driver model. This patch also updates all remaining users of davinci_emac. Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com> Tested-by: Adam Ford <aford173@gmail.com> #am3517-evm & da850-evm Reviewed-by: Ramon Fried <rfried.dev@gmail.com>
2019-07-19ARM: imx6q_logic: With SPL_OF_CONTROL enabled, remove MMC initAdam Ford
Since the board uses SPL_OF_CONTROL now, we don't need to explicitly initialize the MMC driver, but we still need to pinmux the corresponding pins. This patch removes the initialization code and leave just the muxing behind. Signed-off-by: Adam Ford <aford173@gmail.com>
2019-06-23Convert to use fsl_esdhc_imx for i.MX platformsYangbo Lu
Converted to use fsl_esdhc_imx for i.MX platforms. Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com> Tested-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com> Reviewed-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Martyn Welch <martyn.welch@collabora.com> Acked-by: Jason Liu <Jason.hui.liu@nxp.com>
2019-06-11ARM: imx6logic: Stop overwriting fdt_file if manually setAdam Ford
The board file uses the processor type to determine what dtb file is set. Unfortunately, if the user wants to manually set this, it get gets overwritten upon boot. This patch adds a check to see if the value is already set and only changes it if the value is empty. Signed-off-by: Adam Ford <aford173@gmail.com>
2019-04-12ARM: am3517_evm: Add spl_start_uboot for Falcon ModeAdam Ford
When booting the am3517-evm, the following message appears: SPL: Please implement spl_start_uboot() for your board SPL: Direct Linux boot not active! This patch implements spl_start_uboot to clear this message and allow device to know if it should boot U-Boot or kernel. Fixes: 1c6b6f383a41 ("ARM: am3517_evm: Enable Falcon Mode") Signed-off-by: Adam Ford <aford173@gmail.com>
2019-02-19ARM: omap3_logic: Enable SPL booting device treeAdam Ford
With the generic omap3-u-boot.dtsi file available, this patch increased the memory of the various incarnations of the omap3_logic board, and points their respective u-boot.dtsi files to the newly created generic one, and removes the PLATDATA from the board file. These are all done at once because the're all utilizing the same omap3logic.c board file. Signed-off-by: Adam Ford <aford173@gmail.com>
2019-02-15ARM: imx6q_logic: Correct phy fixup for broken ethernetAdam Ford
The Ethernet has been broken for some time. This patch unifies this board with a few others that use a similar approach to enabling phy. This fixes ar8031 Ethernet controller so it works. Signed-off-by: Adam Ford <aford173@gmail.com>
2019-01-28ARM: imx6q_logic: Enable Falcon Mode and fatwriteAdam Ford
This patch enables Falcon Mode by default and updates the README file to show instructions on how to run from the micro SD card or eMMC. This patch also enables fatwrite to help assist with writing the 'args' to the microSD card. Signed-off-by: Adam Ford <aford173@gmail.com>
2019-01-28ARM: DTS: imx6q-logicpd: Update DTS/DTSI filesAdam Ford
The i.MX6 SOM and development kits have undergone significant updates and changes over the past few months. This re-sync's the U-Boot with Logic PD's BSP. Signed-off-by: Adam Ford <aford173@gmail.com>
2019-01-28imx6q_logic: Enable MMC booting from SPLAdam Ford
The MMC booting wasn't previously fitting into the codespace. This patch enables MMC booting from the baseboard by reducing some DM overhead during SPL. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-12-12ARM: omap3logic: Remove legacy USB code in favor of DM_USBAdam Ford
With the defconfig options enabling DM_USB, the legacy code can be removed. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-10-22ARM: omap3_logic: Add NOR Flash Support for SOM-LVAdam Ford
The DM37 and OMAP35 SOM-LV SOM-LV products both support a NOR flash part connected to CS2 in addition to the NAND part on CS0. This patch setups the GPMC timings for the MT28 NOR Flash and enables the CFI-Flash driver now that the CFI stuff is in Kconfig Signed-off-by: Adam Ford <aford173@gmail.com>
2018-10-22ARM: omap3logic: Fix MMC nameAdam Ford
In my haste to migrate SPL to DM, I copied the wrong name. While it really doesn't matter, I'd prefer the name to match the board, so am335x_mmc0 is now called omap3_logic_mmc0 Signed-off-by: Adam Ford <aford173@gmail.com>
2018-10-22ARM: omap3logic: Specify DM serial driver as omap_serialAdam Ford
With the new omap_serial driver, this patch uses this instead from the former ns16550_serial driver. Even though the omap_serial driver is essentially the same. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-10-22ARM: omap3logic: Encapsulate the MUSB functions in check for DMAdam Ford
With the DM_USB working for USB host features, encapsulate the USB gadget initialization in a precomiler check. If DM is enabled, we don't need to manually initialize the MUSB driver. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-10-22ARM: omap3_logic.c: Optimize DDR timings based on OMAP35 or 36/37Adam Ford
The default timings are assumming an OMAP36 / AM37 / DM37, but the OMAP35 controller is a bit slower, so DDR may operate out of spec when under stress. This patch checks the processor type and sets the DDR timings according to processor type. Fixes: 5ad4212ce0d5 ("ARM: DTS: Add Logic PD OMAP35/DM37 SOM-LV and OMAP35 Torpedo") Signed-off-by: Adam Ford <aford173@gmail.com>
2018-10-06ARM: LogicPD: omap3logic: Remove Torpedo/SOM-LV autodectionAdam Ford
With there now being four device tree files, and 4 separate defconfig files, the code necessary to determine which board is being used is no longer necessary as the corresponding pin-muxing and board names are determined by the device tree. Signed-off-by: Adam Ford <aford173@gmail.com>
