path: root/board/logicpd
2018-09-11ARM: am3517_evm: Disable DM_I2C_COMPATAdam Ford
DM_I2C_COMPAT is somehow being enabled outside of Kconfig, so this explicitly undefines it in the header file, and brackets the I2C initialization around an #ifdef to not manually initialize the I2C controller when the DM_I2C is enabled. Signed-off-by: Adam Ford <aford173@gmail.com> Tested-by: Derald D. Woods <woods.technical@gmail.com>
2018-09-11ARM: omap3_logic_defconfig: Convert to DM_SPLAdam Ford
The OF_CONTROL and OF_PLATDATA are not really useful without DM. This patch supports DM_SPL, but it requires manual references both Serial and MMC. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-07-24ARM: AM3517-EVM: Update MaintainerAdam Ford
The previous e-mail pointing to Vaibhav Hiremath <hvaibhav@ti.com> is bouncing and has for some time. This updates it to myself and I work for Logic PD the manufacturer of the AM3517-SOM and EVM Signed-off-by: Adam Ford <aford173@gmail.com>
2018-07-23imx: i.mx6q: imx6q_logic: Migrate to SPL and enable SDPAdam Ford
Since the vast majority of i.MX6 boards are migrating to SPL, this patch converts im6q_logic to SPL and enables the SDP for loading SPL and u-boot.img over USB. The Falcon mode only supports NAND flash as of now due to limited space/RAM, but all i.MX6D/Q SOM's from Logic PD have internal NAND from which to boot. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-06-13ARM: am3517_evm: Enable SPL_OF_CONTROL and SPL_OF_PLATDATAAdam Ford
The SPL doesn't have much room, so in order to support OF_CONTROL in SPL, we need the extra functionality of SPL_OF_PLATDATA. Adding these features allows us to remove a small part of code without losing the serial port during SPL. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-04-08net: Move enetaddr env access code to env config instead of net configAlex Kiernan
In order that we can use eth_env_* even when CONFIG_NET isn't set, move these functions to environment code from net code. This fixes failures such as: board/ti/am335x/built-in.o: In function `board_late_init': board/ti/am335x/board.c:752: undefined reference to `eth_env_set_enetaddr' u-boot/board/ti/am335x/board.c:766: undefined reference to `eth_env_set_enetaddr' which caters for use cases such as: commit f411b5cca48f ("board: am335x: Always set eth/eth1addr environment variable") when Ethernet is required in Linux, but not U-Boot. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
2018-01-28omap3_logic: Clean up I2C pin muxing.Adam Ford
The SOM has external pull-up resistors, so let's turn these off. It was helping reduce some errors when running I2C1 @ 2.6MHz. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-01-22ARM: omap3_logic: Enable SPL_OF_CONTROL and SPL_OF_PLATDATAAdam Ford
2017-12-12ARM: omap3_logic: Enable NAND unlocking during Falcon modeAdam Ford
Falcon mode was already working with SD card. This enables the unlocking of NAND to allow the NAND read & write. This also expands the README file based on the am335x describing how to setup Falcon mode. Signed-off-by: Adam Ford <aford173@gmail.com>
2017-12-12ARM: omap3_logic: Unlock NAND automatically in U-BootAdam Ford
The Micron Flash is locked by default. This will automaticlly unlock so manually unlocking is unnecessary in U-Boot. Signed-off-by: Adam Ford <aford173@gmail.com>
2017-12-04mtd: nand: Rename nand.h into rawnand.hMasahiro Yamada
This header was renamed to rawnand.h in Linux. The following is the corresponding commit in Linux. commit d4092d76a4a4e57b65910899948a83cc8646c5a5 Author: Boris Brezillon <boris.brezillon@free-electrons.com> Date: Fri Aug 4 17:29:10 2017 +0200 mtd: nand: Rename nand.h into rawnand.h We are planning to share more code between different NAND based devices (SPI NAND, OneNAND and raw NANDs), but before doing that we need to move the existing include/linux/mtd/nand.h file into include/linux/mtd/rawnand.h so we can later create a nand.h header containing all common structure and function prototypes. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-11-17omap3: omap3_logic: Move pinmuxing to header fileAdam Ford
To keep the board file smaller and clean, let's move the pinmux to the header file. Signed-off-by: Adam Ford <aford173@gmail.com>
2017-10-12imx: Include <input.h> header fileDiego Dorta
When building with W=1 errors like the one below is seen: board/freescale/mx6sabresd/mx6sabresd.c:546:5: warning: no previous prototype for ‘overwrite_console’ [-Wmissing-prototypes] int overwrite_console(void) Fix the build warnings by including <input.h>. Signed-off-by: Diego Dorta <diego.dorta@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-09-29ARM: omap3: am3517-evm: Add device tree and DM supportAdam Ford
With the device tree ported from Linux 4.13, this enables Driver Model and Device Tree support for the am3517-evm Signed-off-by: Adam Ford <aford173@gmail.com> Tested-by: Derald D. Woods <woods.technical@gmail.com>
2017-09-13omap3: omap3_logic: Finish enabling fastboot on MUSBAdam Ford
Either the USB and Fastboot were never finished, or somehow it got lost. This puts enough hooks back into omap3logic to enable fastboot and hopefully prepare it for Kconfig conversion. Signed-off-by: Adam Ford <aford173@gmail.com>
2017-09-12omap3: am3517_evm: Enable TI_COMMON_CMD_OPTIONAdam Ford
Enable TI_COMMON_CMD_OPTIONS and remove similar options from the defconfig. Updated with savedefconfig. Signed-off-by: Adam Ford <aford173@gmail.com> Tested-by: Derald D. Woods <woods.technical@gmail.com>
2017-08-16env: Rename eth_getenv_enetaddr() to eth_env_get_enetaddr()Simon Glass
Rename this function for consistency with env_get(). Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename eth_setenv_enetaddr() to eth_env_set_enetaddr()Simon Glass
Rename this function for consistency with env_set(). Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-11OMAP3: omap3logic: Fix DDR Pin MuxAdam Ford
The 512 MB DDR version of SOM's use CS0 and CS1. CS1 is not correctly setup in the pin muxing. This causes erratic behavior on suspend/resume This fix has been tested on both 256 and 512 MB DDR versions. Signed-off-by: Adam Ford <aford173@gmail.com>
2017-08-09Configs: Migrate CONFIG_SYS_I2C_OMAP34XX to CONFIG_SYS_I2C_OMAP24XXAdam Ford
The driver is for all boards 24XX and up, so let's eliminate the extra option called CONFIG_SYS_I2C_OMAP34XX since the driver checks for CONFIG_OMAP34XX we don't need CONFIG_SYS_I2C_OMAP34XX. Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de>
Change is consistent with other SOCs and it is in preparation for adding SOMs. SOC's related files are moved from cpu/ to mach-imx/<SOC>. This change is also coherent with the structure in kernel. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Fabio Estevam <fabio.estevam@nxp.com> CC: Akshay Bhat <akshaybhat@timesys.com> CC: Ken Lin <Ken.Lin@advantech.com.tw> CC: Marek Vasut <marek.vasut@gmail.com> CC: Heiko Schocher <hs@denx.de> CC: "Sébastien Szymanski" <sebastien.szymanski@armadeus.com> CC: Christian Gmeiner <christian.gmeiner@gmail.com> CC: Stefan Roese <sr@denx.de> CC: Patrick Bruenn <p.bruenn@beckhoff.com> CC: Troy Kisky <troy.kisky@boundarydevices.com> CC: Nikita Kiryanov <nikita@compulab.co.il> CC: Otavio Salvador <otavio@ossystems.com.br> CC: "Eric Bénard" <eric@eukrea.com> CC: Jagan Teki <jagan@amarulasolutions.com> CC: Ye Li <ye.li@nxp.com> CC: Peng Fan <peng.fan@nxp.com> CC: Adrian Alonso <adrian.alonso@nxp.com> CC: Alison Wang <b18965@freescale.com> CC: Tim Harvey <tharvey@gateworks.com> CC: Martin Donnelly <martin.donnelly@ge.com> CC: Marcin Niestroj <m.niestroj@grinn-global.com> CC: Lukasz Majewski <lukma@denx.de> CC: Adam Ford <aford173@gmail.com> CC: "Albert ARIBAUD (3ADEV)" <albert.aribaud@3adev.fr> CC: Boris Brezillon <boris.brezillon@free-electrons.com> CC: Soeren Moch <smoch@web.de> CC: Richard Hu <richard.hu@technexion.com> CC: Wig Cheng <wig.cheng@technexion.com> CC: Vanessa Maegima <vanessa.maegima@nxp.com> CC: Max Krummenacher <max.krummenacher@toradex.com> CC: Stefan Agner <stefan.agner@toradex.com> CC: Markus Niebel <Markus.Niebel@tq-group.com> CC: Breno Lima <breno.lima@nxp.com> CC: Francesco Montefoschi <francesco.montefoschi@udoo.org> CC: Jaehoon Chung <jh80.chung@samsung.com> CC: Scott Wood <oss@buserror.net> CC: Joe Hershberger <joe.hershberger@ni.com> CC: Anatolij Gustschin <agust@denx.de> CC: Simon Glass <sjg@chromium.org> CC: "Andrew F. Davis" <afd@ti.com> CC: "Łukasz Majewski" <l.majewski@samsung.com> CC: Patrice Chotard <patrice.chotard@st.com> CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Hans de Goede <hdegoede@redhat.com> CC: Masahiro Yamada <yamada.masahiro@socionext.com> CC: Stephen Warren <swarren@nvidia.com> CC: Andre Przywara <andre.przywara@arm.com> CC: "Álvaro Fernández Rojas" <noltari@gmail.com> CC: York Sun <york.sun@nxp.com> CC: Xiaoliang Yang <xiaoliang.yang@nxp.com> CC: Chen-Yu Tsai <wens@csie.org> CC: George McCollister <george.mccollister@gmail.com> CC: Sven Ebenfeld <sven.ebenfeld@gmail.com> CC: Filip Brozovic <fbrozovic@gmail.com> CC: Petr Kulhavy <brain@jikos.cz> CC: Eric Nelson <eric@nelint.com> CC: Bai Ping <ping.bai@nxp.com> CC: Anson Huang <Anson.Huang@nxp.com> CC: Sanchayan Maity <maitysanchayan@gmail.com> CC: Lokesh Vutla <lokeshvutla@ti.com> CC: Patrick Delaunay <patrick.delaunay@st.com> CC: Gary Bisson <gary.bisson@boundarydevices.com> CC: Alexander Graf <agraf@suse.de> CC: u-boot@lists.denx.de Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2017-05-16Merge branch 'master' of git://git.denx.de/u-boot-mmcTom Rini
- Add #undef CONFIG_DM_MMC_OPS to omap3_logic in the SPL build case, to match other TI platforms in the same situation. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-15omap3: omap3_logic: switch to using TI_COMMON_CMD_OPTIONAdam Ford
Enable TI_COMMON_CMD_OPTIONS and remove similar options from the defconfig. Updated with savedefconfig CMD_USB isn't enabled yet. I have some testing to do with musb. Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-05-15mmc: replace CONFIG_GENERIC_MMC with CONFIG_MMCMasahiro Yamada
Now CONFIG_GENERIC_MMC and CONFIG_MMC match for all defconfig. We do not need two options for the same feature. Deprecate the former. This commit was generated with the sed script 's/GENERIC_MMC/MMC/' and manual fixup of drivers/mmc/Kconfig. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-05-09omap3_logic: Add Device Tree Support and more DM driversAdam Ford
This patch also removes all the excessive code for NS16550 intiailization as the device tree can do that now. This also adds DM_I2C and DM_MMC since the overlying drivers have the built-in support already. The corresponding include/config/omap3_logic.h also reduced in size due to the new device tree support. Signed-off-by: Adam Ford <aford173@gmail.com> Changes in V2: Retain Auto-detect ability between SOM-LV and Torpedo Split this off from the device sub submissions
2017-04-12imx: i.mx6q: add the initial support for LogicPD i.MX6Q SOMAdam Ford
Logic PD has an i.MX6Q system on module (SOM) with a development kit. The SOM has a built-in microSD socket, DDR and NAND flash. The development kit has an SMSC Ethernet PHY, serial debug port and a variety of peripherals. This have been verified to boot the i.MX6Q version over either SD on the development kit or NAND built into the SOM. Items in the dtsi file are specific to the SOM itself. Items in the dts file are in the baseboard. Future versions of the SOM will come out supporting the same basebord and potentially future base boards will come out supporting the same SOM. Signed-off-by: Adam Ford <aford173@gmail.com>
2017-03-19ti: boot: Register the MMC controllers in SPL in the same way as in u-bootJean-Jacques Hiblot
To keep a consistent MMC device mapping in SPL and in u-boot, let's register the MMC controllers the same way in u-boot and in the SPL. In terms of boot time, it doesn't hurt to register more controllers than needed because the MMC device is initialized only prior being accessed for the first time. Having the same device mapping in SPL and u-boot allows us to use the environment in SPL whatever the MMC boot device. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2017-01-20serial, ns16550: bugfix: ns16550 fifo not enabledHeiko Schocher
commit: 65f83802b7a5b "serial: 16550: Add getfcr accessor" breaks u-boot commandline working with long commands sending to the board. Since the above patch, you have to setup the fcr register. For board/archs which enable OF_PLATDATA, the new field fcr in struct ns16550_platdata is not filled with a default value ... This leads in not setting up the uarts fifo, which ends in problems, when you send long commands to u-boots commandline. Detected this issue with automated tbot tests on am335x based shc board. The error does not popup, if you type commands. You need to copy&paste a long command to u-boots commandshell (or send a long command with tbot) Possible boards/plattforms with problems: ./arch/arm/cpu/arm926ejs/lpc32xx/devices.c ./arch/arm/mach-tegra/board.c ./board/overo/overo.c ./board/quipos/cairo/cairo.c ./board/logicpd/omap3som/omap3logic.c ./board/logicpd/zoom1/zoom1.c ./board/timll/devkit8000/devkit8000.c ./board/lg/sniper/sniper.c ./board/ti/beagle/beagle.c ./drivers/serial/serial_rockchip.c Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Tested-by: Adam Ford <aford173@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-14omap3_logic: Rework MACH_TYPE and fdtfile logicTom Rini
The MACH_TYPE values for the omap37xx based platforms are no longer officially valid, so we must not set and pass them. In order to not reference them but still be able to set the default fdtfile based on the board detection logic we need to combine the two steps into one. Cc: Adam Ford <aford173@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Adam Ford <aford173@gmail.com>
2016-10-31omap3logic: Fix Auto detect Logic PD ModelsAdam Ford
The autodetect feature doesn't allow users to specify the device tree. This fix will make it only autodetect if 'fdtimage' is not defined. Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-06omap3logic: Fix PBIAS BugAdam Ford
The PBIAS fixing is done in the MMC driver, and doing it in the the board file conflicts with the driver causing intermittent hangs on reboot. Remove this from the board file and let the driver do it. Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-07-22armv7: make gpmc_cfg constLadislav Michl
Signed-off-by: Ladislav Michl <ladis@linux-mips.org> [trini: Adapt am33xx, duovero, omap_zoom1] Signed-off-by: Tom Rini <trini@konsulko.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2016-03-14ARM: Various: Future-proof serial platdataAdam Ford
A few boards still use ns16550_platdata structures, but assume the structure is going to be in a specific order. By explicitly naming each entry, this should also help 'future-proof' in the event the structure changes. Tested on the Logic PD Torpedo + Wireless. I only changed a handful of devices that used the same syntax as the Logic board. Appologies if I missed one or stepped on toes. Thanks to Derald Woods and Alexander Graf. Signed-off-by: Adam Ford <aford173@gmail.com> V6: Add fix to arch/arm/cpu/armv7/am33xx/board.c V5: Add fix to arch/arm/cpu/arm926ejs/lpc32xx/devices.c V4: Fix subject heading V3: Remove reg_offset out in all the structs. It was reverted out, and and if it did exist, it would get initialized to 0 by default. V2: I hastily copy-pasted the boards without looking at the UART number. This addresses 3 boards that use UART3 and not UART1. Reviewed-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-02-24OMAP3SOM BOARD: Auto detect Logic PD ModelsAdam Ford
Logic PD makes four different system on modules. This patch will auto detect the board type and identify the corresponding device tree image. V2: Added 'default:' case to switch statement Since board_late_init() is defined as int, we now return 0 Signed-off-by: Derald Woods <woods.technical@gmail.com> Signed-off-by: Adam Ford <aford173@gmail.com>
2016-02-15OMAP3LOGIC: Update maintainerAdam Ford
I will take this over from Peter Barada, since I work with it daily at Logic PD. Signed-off-by: Adam Ford <aford173@gmail.com> Acked-by: Peter Barada <peter.barada@logicpd.com>
2016-02-08OMAP3: omap3_logic: Enable Android FastbootAdam Ford
Android Fastboot requires USB. The TWL4030 PMIC on omap3_logic handles USB traffic. This patch sets up the USB gadget and Android Fastboot to match what is done in the omap3_beagle project. Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-02-08OMAP3: Enable SPL on omap3_logicAdam Ford
Previously, Omap3_logic assumed X-loader was present. With this patch, we can finally replace X-loader with an MLO generated by U-Boot. This requires ECC to be setup to match the Linux Kernel and the PBIAS confgured for the SD card. Signed-off-by: Derald D. Woods <woods.technical@gmail.com> Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-02-08ARM: omap3_logic: Fix pin muxingAdam Ford
Enhance pin muxing to enable more board features and reduce power based on Tony's device tree work. Signed-off-by: Adam Ford <aford173@gmail.com>
2015-11-21ns16550: unify serial_omapThomas Chou
Unify serial_omap, and use the generic binding. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-10-22omap-common: Common function to display die id, replacing omap3-specific versionPaul Kocialkowski
This introduces omap_die_id_display to display the full die id. There is no need to store it in an environment variable, that no boot script is using anyway. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-09-11arm: Remove mx31_litekit boardSimon Glass
This board has not been converted to generic board by the deadline. Remove it. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-11arm: Remove imx27lite, imx27_litekit and magnesium boardsSimon Glass
These boards have not been converted to generic board by the deadline. Remove them. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-02Convert omap3_logic to ti_omap3_common.hAdam Ford
Convert to using the common config files. Signed-off-by: Adam Ford <adam.ford@logicpd.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-08-05usb: musb-new: CONFIG_MUSB prefix replacement with CONFIG_USB_MUSBPaul Kocialkowski
USB-related options are usually prefixed with CONFIG_USB and platform-specific adaptation for the MUSB controller already have a CONFIG_USB_MUSB prefix, so this switches all MUSB-related options to a CONFIG_USB_MUSB prefix, for consistency. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2015-03-24remove unnecessary version.h includesRob Herring
Various files are needlessly rebuilt every time due to the version and build time changing. As version.h is not actually needed, remove the include. Signed-off-by: Rob Herring <robh@kernel.org> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Stefano Babic <sbabic@denx.de> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Marek Vasut <marex@denx.de> Cc: Tom Warren <twarren@nvidia.com> Cc: Michal Simek <monstr@monstr.eu> Cc: Macpaul Lin <macpaul@andestech.com> Cc: Wolfgang Denk <wd@denx.de> Cc: York Sun <yorksun@freescale.com> Cc: Stefan Roese <sr@denx.de> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Cc: Simon Glass <sjg@chromium.org> Cc: Philippe Reynes <tremyfr@yahoo.fr> Cc: Eric Jarrige <eric.jarrige@armadeus.org> Cc: "David Müller" <d.mueller@elsoft.ch> Cc: Phil Edworthy <phil.edworthy@renesas.com> Cc: Robert Baldyga <r.baldyga@samsung.com> Cc: Torsten Koschorrek <koschorrek@synertronixx.de> Cc: Anatolij Gustschin <agust@denx.de> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Reviewed-by: Łukasz Majewski <l.majewski@samsung.com>
2014-12-04omap_hsmmc: Board-specific TWL4030 MMC power initializationsPaul Kocialkowski
Boards using the TWL4030 regulator may not all use the LDOs the same way (e.g. MMC2 power can be controlled by another LDO than VMMC2). This delegates TWL4030 MMC power initializations to board-specific functions, that may still call twl4030_power_mmc_init for the default behavior. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@ti.com> [trini: Fix omap3_evm warning, add twl4030.h] Signed-off-by: Tom Rini <trini@ti.com>
