path: root/board/logicpd
2015-08-05usb: musb-new: CONFIG_MUSB prefix replacement with CONFIG_USB_MUSBPaul Kocialkowski
USB-related options are usually prefixed with CONFIG_USB and platform-specific adaptation for the MUSB controller already have a CONFIG_USB_MUSB prefix, so this switches all MUSB-related options to a CONFIG_USB_MUSB prefix, for consistency. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2015-03-24remove unnecessary version.h includesRob Herring
Various files are needlessly rebuilt every time due to the version and build time changing. As version.h is not actually needed, remove the include. Signed-off-by: Rob Herring <robh@kernel.org> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Stefano Babic <sbabic@denx.de> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Marek Vasut <marex@denx.de> Cc: Tom Warren <twarren@nvidia.com> Cc: Michal Simek <monstr@monstr.eu> Cc: Macpaul Lin <macpaul@andestech.com> Cc: Wolfgang Denk <wd@denx.de> Cc: York Sun <yorksun@freescale.com> Cc: Stefan Roese <sr@denx.de> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Cc: Simon Glass <sjg@chromium.org> Cc: Philippe Reynes <tremyfr@yahoo.fr> Cc: Eric Jarrige <eric.jarrige@armadeus.org> Cc: "David Müller" <d.mueller@elsoft.ch> Cc: Phil Edworthy <phil.edworthy@renesas.com> Cc: Robert Baldyga <r.baldyga@samsung.com> Cc: Torsten Koschorrek <koschorrek@synertronixx.de> Cc: Anatolij Gustschin <agust@denx.de> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Reviewed-by: Łukasz Majewski <l.majewski@samsung.com>
2014-12-04omap_hsmmc: Board-specific TWL4030 MMC power initializationsPaul Kocialkowski
Boards using the TWL4030 regulator may not all use the LDOs the same way (e.g. MMC2 power can be controlled by another LDO than VMMC2). This delegates TWL4030 MMC power initializations to board-specific functions, that may still call twl4030_power_mmc_init for the default behavior. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@ti.com> [trini: Fix omap3_evm warning, add twl4030.h] Signed-off-by: Tom Rini <trini@ti.com>
2014-10-29kconfig: arm: introduce symbol for ARM CPUsGeorges Savoundararadj
This commit introduces a Kconfig symbol for each ARM CPU: CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136, CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100. Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected for CPU_ARM1176 and CPU_V7. For each target, the corresponding CPU is selected and the definition of SYS_CPU in the corresponding Kconfig file is removed. Also, it removes redundant "string" type in some Kconfig files. Signed-off-by: Georges Savoundararadj <savoundg@gmail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-10-27Merge branch 'master' of git://git.denx.de/u-boot-tiTom Rini
2014-10-23dm: omap3: Move to driver model for GPIO and serialSimon Glass
Adjust the configuration for the am33xx boards, including beagleboard, to use driver model. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Tom Rini <trini@ti.com>
2014-10-23omap3/am33xx: mux: fix several checkpatch issuesIgor Grinberg
Fix the following checkpatch issues: CHECK: No space is necessary after a cast \#39: FILE: arch/arm/include/asm/arch-am33xx/mux.h:39: +#define PAD_CTRL_BASE 0x800 +#define OFFSET(x) (unsigned int) (&((struct pad_signals *) \ CHECK: Avoid CamelCase: <CONTROL_PADCONF_JTAG_nTRST> \#284: FILE: arch/arm/include/asm/arch-omap3/mux.h:284: +#define CONTROL_PADCONF_JTAG_nTRST 0x0A1C ERROR: space required after that ',' (ctx:VxV) \#446: FILE: arch/arm/include/asm/arch-omap3/mux.h:446: +#define MUX_VAL(OFFSET,VALUE)\ ^ Cc: Raphael Assenat <raph@8d.com> Cc: Ilya Yanok <yanok@emcraft.com> Cc: Vaibhav Hiremath <hvaibhav@ti.com> Cc: Peter Barada <peter.barada@logicpd.com> Cc: Grazvydas Ignotas <notasas@gmail.com> Cc: Stefan Roese <sr@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Nishanth Menon <nm@ti.com> Cc: Tom Rini <trini@ti.com> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Stefan Roese <sr@denx.de>
2014-09-24MAINTAINERS: comment out blank M: fieldMasahiro Yamada
Since commit ddaf5c8f3030050fcd356a1e49e3ee8f8f52c6d4 (patman: RunPipe() should not pipe stdout/stderr unless asked), Patman spits lots of "Invalid MAINTAINERS address: '-'" error messages for patches with global changes. It takes too long for Patman to process them. Anyway, "M: -" does not carry any important information. Rather, it is just like a place holder in case of assigning a new board maintainer. Let's comment out. This commit can be reproduced by the following command: find . -name MAINTAINERS | xargs sed -i -e '/^M:[[:blank:]]*-$/s/^/#/' Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-08-30omap3: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the OMAP3 board select menu to omap3/Kconfig. Move also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="omap3 Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-04-17omap3: zoom1: switch to generic ti_omap3_common config headerNishanth Menon
ti_omap3_common contains a lot of common header definitions that help reduce the size of the zoom1 config file. So, use the generic header and customize as needed for the platform (example: no spl). Signed-off-by: Nishanth Menon <nm@ti.com>
2014-04-17OMAP3: zoom1: enable LAN9211Nishanth Menon
Zoom1 was wrongly setup for LAN91C96. Fix it by enabling LAN9211. Signed-off-by: Nishanth Menon <nm@ti.com>
2014-04-17OMAP3: zoom1: Configure GPMC for EthernetNishanth Menon
zoom1 uses LAN9211 configured over GPMC Chip Select 1. Signed-off-by: Nishanth Menon <nm@ti.com>
2014-01-07TI:omap3: Drop omap3_zoom2Tom Rini
The omap3_zoom2 board has not been updated for a correct CONFIG_SYS_HZ and Tom Rix's email has long been bouncing. Signed-off-by: Tom Rini <trini@ti.com>
2013-12-12am3517_evm: activate Ethernet PHYYegor Yefremov
Pin 30 is connected to PHY's RESET# signal, so it must be put to high. Otherwise PHY won't be found via MDIO interface. Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com>
2013-11-13i2c, omap24xx: convert driver to new mutlibus/mutliadapter frameworkHeiko Schocher
- add omap24xx driver to new multibus/multiadpater support - adapted all config files, which uses this driver Tested on the am335x based siemens boards rut, dxr2 and pxm2 posted here: http://patchwork.ozlabs.org/patch/263211/ Signed-off-by: Heiko Schocher <hs@denx.de> Tested-by: Tom Rini <trini@ti.com> Cc: Lars Poeschel <poeschel@lemonage.de> Cc: Steve Sakoman <sakoman@gmail.com> Cc: Thomas Weber <weber@corscience.de> Cc: Tom Rix <Tom.Rix@windriver.com> Cc: Grazvydas Ignotas <notasas@gmail.com> Cc: Enric Balletbo i Serra <eballetbo@iseebcn.com> Cc: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Ilya Yanok <yanok@emcraft.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Nishanth Menon <nm@ti.com> Cc: Pali Rohár <pali.rohar@gmail.com> Cc: Peter Barada <peter.barada@logicpd.com> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Michael Jones <michael.jones@matrix-vision.de> Cc: Raphael Assenat <raph@8d.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Stefano Babic <sbabic@denx.de>
2013-10-14Coding Style cleanup: remove trailing empty linesWolfgang Denk
2013-03-08omap_hsmmc: add driver check for write protectionNikita Kiryanov
Add check for write protection in omap mmc driver. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-08omap_hsmmc: implement driver check for card detectionNikita Kiryanov
Implement driver check for card detection. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2012-11-20am3517_evm: switch to musb-newIlya Yanok
Use new musb framework instead of the old one on AM3517_EVM. Signed-off-by: Ilya Yanok <ilya.yanok@cogentembedded.com>
2012-10-15mx31: Fix PDR0_CSI_PODFBenoît Thébaudeau
The CSI PODF bit-field used by the previous code for the i.MX31 CCM PDR0 register is actually composed of two bit-fields: one pre-divider and one post-divider. This patch fixes the CCM access macros and the code using them accordingly. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de>
2012-10-15serial: zoom2: Remove zoom2 serial prototypes from serial.hMarek Vasut
Remove the prototypes for zoom2_serial_deviceN from serial.h . This can't be done right away, as they are referenced from the zoom2 config file. Therefore, adjust the code so the config file only specifies number of the port. Then, replace the simple return in default_serial_console() with a switch across possible values, which returns the zoom2_serial_deviceN . With such adjustment in place, the exported prototypes in serial.h can be safely removed. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com>
2012-10-15serial: Properly spell out the structure member names of serial_driverMarek Vasut
Properly spell out the whole structure member names when an initialized varible is instantiated from the struct serial_driver. In case the structure definition for struct serial_driver undergoes reordering, there will be no impact on variables defined based on this structure. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: C Nauman <cnauman@diagraph.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Michal Simek <monstr@monstr.eu>
2012-10-15COMMON: Use __stringify() instead of rest of implementationsMarek Vasut
Fix up the rest of implementations of __stringify(). Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de>
2012-09-01imx27lite: update with gpio api change (v4)trem
Signed-off-by: Philippe Reynes <tremyfr@yahoo.fr> Acked-by: Stefano Babic <sbabic@denx.de>
2012-05-15omap3: Introduce weak misc_init_rTom Rini
Introduce a __weak misc_init_r function that just runs dieid_num_r(). Remove misc_init_r from cm_t35, mcx, omap3_logic and mt_ventoux as this was all they did for misc_init_r. Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Ilya Yanok <yanok@emcraft.com> Cc: Peter Barada <peter.barada@logicpd.com> Cc: Stefano Babic <sbabic@denx.de> Signed-off-by: Tom Rini <trini@ti.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2012-05-15ARM:OMAP+:MMC: Add parameters to MMC initJonathan Solnit
Add parameters to the OMAP MMC initialization function so the board can mask host capabilities and set the maximum clock frequency. While the OMAP supports a certain set of MMC host capabilities, individual boards may be more restricted and the OMAP may need to be configured to match the board. The PRG_SDMMC1_SPEEDCTRL bit in the OMAP3 is an example. Signed-off-by: Jonathan Solnit <jsolnit@gmail.com>
2012-02-12omap3logic: Add missing GPMC pinmux for LAN92xx accessPeter Barada
The initial checkin dropped pinmux setup for GPMC pins A6-A10, D0-D7 and NCS1/2 necessary to access LAN92xx on Logic OMAP35x/DM37x modules. Signed-off-by: Peter Barada <peter.barada@logicpd.com>
2012-01-16ARMV7: Add support For Logic OMAP35x/DM37x modulesPeter Barada
This patch adds basic support for OMAP35x/DM37x SOM LV/Torpedo reference boards. It assumes U-boot is loaded to SDRAM with the help of another small bootloader (x-load) running from SRAM. Signed-off-by: Peter Barada <peter.barada@logicpd.com> Cc: Tom Rini <tom.rini@gmail.com> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2011-12-06AM3517: Add SPL supportTom Rini
The only change of note is that we move from 0x80008000 to 0x80100000 for CONFIG_SYS_TEXT_BASE Cc: Vaibhav Hiremath <hvaibhav@ti.com> Signed-off-by: Tom Rini <trini@ti.com>
2011-12-06AM3517: move AM3517 specific mux defines to generic headerIlya Yanok
AM3517 specific CONTROL_PADCONF_* defines moved from board-specific files to <asm/arch-omap3/mux.h> Signed-off-by: Ilya Yanok <yanok@emcraft.com>
2011-10-27omap: Don't use gpio_free to change direction to inputJoe Hershberger
gpio_free() should not have the side effect of setting the line to input since this prevents the gpio command from being able to set a line as output. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-10-27imx: fix coding styleFabio Estevam
Fix checkpatch warning and errors in several i.MX related files. While at it also address a checkpatch warning at arch/arm/cpu/armv7/mx5/soc.c regarding the usage of extern in a C file. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-10-27mx31: provide readable WEIM CS accessorHelmut Raiger
setup_weimcs() and some macros are added to support the setup for i.MX31 WEIM chip selects. As a compromise between verbosity and readability an ASCII-art'ish bit comment is used instead of bitfields. All i.MX31 boards have been patched to use this approach using a helper program to verify the changes. Signed-off-by: Helmut Raiger <helmut.raiger@hale.at> Acked-by: Stefano Babic <sbabic@denx.de>
2011-09-30imx31_litekit: Place machine ID into board configFabio Estevam
Let common code set the machine ID. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-09-30imx31_litekit: Remove dram_init_banksize()Fabio Estevam
As only one RAM bank is used we can rely on the code from arch/arm/lib/board.c Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-09-13led: remove camel casing of led identifiers globallyJason Kridner
Result of running the following command to address Wolfgang's comment about camel case: for file in `find . | grep '\.[chS]$'`; do perl -i -pe 's/(green|yellow|red|blue)_LED_(on|off)/$1_led_$2/g' $file; done Discussion: http://patchwork.ozlabs.org/patch/84988/ Signed-off-by: Jason Kridner <jkridner@beagleboard.org> Signed-off-by: Joel A Fernandes <agnel.joel@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-13omap: gpio: Adapt board files to use generic APISanjeev Premi
This patch contains updates the sources in the board files to use the generic API. Signed-off-by: Sanjeev Premi <premi@ti.com>
2011-09-07Makefile : fix generation of cpu related asm-offsets.hStefano Babic
commit 0edf8b5b2fa0d210ebc4d6da0fd1aceeb7e44e47 breaks building on a different directory with the O= parameter. The patch wil fix this issue, generating always asm-offsets.h before the other targets. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Matthias Weisser <weisserm@arcor.de> CC: Wolfgang Denk <wd@denx.de>
2011-09-04OMAP3: Zoom2: Use generic MMC driverTom Rini
Switch from the legacy omap3 mmc driver to the new generic omap hsmmc driver. This patch is based on the work done for Beagle, etc. Signed-off-by: Tom Rini <trini@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04OMAP3: Zoom1: Use generic MMC driverTom Rini
2011-09-04am3517evm: Use generic MMC driverVaibhav Hiremath
Switch from the legacy mmc driver to the new generic mmc driver. This patch is based on similar patch for beagle[1]. [1] http://git.denx.de/?p=u-boot.git;a=commitdiff_plain;h=0cd31144240 Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com> Signed-off-by: Sanjeev Premi <premi@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-07-26serial: drop useless ctlr fieldMike Frysinger
The multi serial support has a "ctlr" field which almost no one uses, but everyone is forced to set to useless strings. So punt it. Funny enough, the only code that actually reads this field (the mpc8xx driver) has a typo where it meant to look for the SCC driver. Fix it while converting the check to use the name field. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Heiko Schocher <hs@denx.de> CC: Anatolij Gustschin <agust@denx.de> CC: Tom Rix <Tom.Rix@windriver.com> CC: Minkyu Kang <mk7.kang@samsung.com> CC: Craig Nauman <cnauman@diagraph.com> CC: Marek Vasut <marek.vasut@gmail.com> CC: Prafulla Wadaskar <prafulla@marvell.com> CC: Mahavir Jain <mjain@marvell.com>
2011-07-26serial: push default_serial_console to driversMike Frysinger
Rather than sticking arch/board/driver specific logic in the common serial code, push it all out to the respective drivers. The serial drivers declare these funcs weak so that boards can still override things with their own definition. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Heiko Schocher <hs@denx.de> CC: Anatolij Gustschin <agust@denx.de> CC: Tom Rix <Tom.Rix@windriver.com> CC: Minkyu Kang <mk7.kang@samsung.com> CC: Craig Nauman <cnauman@diagraph.com> CC: Prafulla Wadaskar <prafulla@marvell.com> CC: Mahavir Jain <mjain@marvell.com> Tested-by: Minkyu Kang <mk7.kang@samsung.com>
2011-07-17Remove volatile qualifier in get_ram_size() callsAlbert ARIBAUD
Checkpatch.pl complains about the volatile qualifier in calls to get_ram_size(). Remove this qualifier in the prototype and in the calls where it is useless, and leave it only in the function body where it is needed. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
