path: root/board/logicpd/omap3som/Kconfig
2017-05-15omap3: omap3_logic: switch to using TI_COMMON_CMD_OPTIONAdam Ford
Enable TI_COMMON_CMD_OPTIONS and remove similar options from the defconfig. Updated with savedefconfig CMD_USB isn't enabled yet. I have some testing to do with musb. Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2014-08-30omap3: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the OMAP3 board select menu to omap3/Kconfig. Move also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="omap3 Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Tom Rini <trini@ti.com>
