This moves the sniper board from the lge to lg, in order to match the devicetree
vendor prefix already defined in the kernel.
Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
With the previous implementation, rebooting without registering a recognized
reboot mode (despite registering the magic) would end up with U-Boot checking
for a valid power-on reason, which might result in the device turning off (e.g.
with no USB cable attached and no buttons pressed).
This was designed to catch reboots that are actually intended to be power-off,
something that old Android kernels do, instead of properly turning the device
off using the TWL4030.
However, since this approach is not viable (breaks reboot in most cases), the
validity of the reboot mode magic is checked to detect a reboot and the 'o' char
is recognized to indicate that power-off is required. Still, that might be
overridden by the detection of usual power-on reasons, on purpose.
Reboot mode garbage is found on cold reset and might be seen as valid on the
next warm reset, thus it has to be cleared on cold reset.
There is no need to set the reboot mode to a particular value prior to reboot,
since valid values will have been caught and cleared earlier.
In addition, this breaks the reboot-bootloader fastboot call, by overriding the
required value for fastboot.
This switches reboot mode handling to a string-based interface, that allows more
flexibility to set a common interface with the next generations of OMAP devices.
This introduces some minor cleanups, regarding aspects such as board name, code
and headers organization as well as deprecated and missing config options.
There are various different boards with the same hardware sold as LG Optimus
Black, such as P970, P970g and KU5900. Since this port is functional for all
variants, it doesn't make sense to keep references to P970.
This cleans up the mux configuration a bit, setting mmc clock signals to input
enabled and specifying pull-down (0) when pull is not used.
Unify serial_omap, and use the generic binding.
Since there is a common function to grab the serial number from the die id bits,
it makes sense have one to parse that serial number and feed it to the serial
ATAG.
Now that we have a common prototype to grab the omap die id, functions to figure
out a serial number and usb ethernet address can use it directly.
Those also get an omap_die_id prefix for better consistency.
This replaces the previous get_dieid definition with omap_die_id, that matches
the common omap_die_id definition.
Using the twl4030 keypad allows booting directly into some special boot modes,
such as recovery or fastboot. the VOL+ key will trigger a boot to recovery while
the VOL- key will trigger a boot to fastboot.
The G (gesture) key remains unused at this point.
In most cases, userspace will attempt to power off the device with HALT instead
of POWER_OFF, which triggers a reset instead of a proper power off from the
TWL4030. Hence, it is up to the bootloader to actually turn the device off when
there is no reason to turn it on.
A reboot identified with the OMAP reboot mode bits set is acceptable, as well as
a power on reason from either the power button, USB or charger plug.
Other cases should trigger a power off. Note that for the U-Boot reset command
to take effect, we have to fill-in the OMAP reboot bits.
This adds support for resetting the device on a long press on the power button.
This adds support for the fastboot USB gadget, including flashing to the
internal MMC and reboot to bootloader or not.
[trini: Update to use Kconfig for MUSB]
Now that the serial number is correctly defined, we can pass it to the kernel
using the (legacy) ATAG method. It will be automatically passed via device-tree
when enabled.
The OMAP3 has some die-specific ID bits that we can use to give the device a
(more or less) unique serial number. This is particularly useful for e.g. USB.
This adds support for the omap3 reboot mode mechanism and exports the reboot
mode via an environment variable, that is used in the boot command to make it
possible to boot from the recovery partition.
The LG Optimus Black (P970) codename sniper is a smartphone that was designed
and manufactured by LG Electronics (LGE) and released back in 2011.
It is using an OMAP3630 SoC GP version, which allows running U-Boot and the
U-Boot SPL from the ground up. This port is aimed at running an Android version
such as Replicant, the fully free Android distribution. However, support for
upstream Linux with device-tree and common GNU/Linux distros boot commands
could be added in the future.
For more information about the journey to freeing this device, please read the
series of blog posts at:
http://code.paulk.fr/article20/a-hacker-s-journey-freeing-a-phone-from-the-ground-up-first-part
[trini: Add CONFIG_OF_SUPPORT]
