path: root/board/lg
2021-09-07arm: Disable ATAGs supportTom Rini
With the exceptions of ds109, ds414, icnova-a20-swac, nokia_rx51 and stemmy, disable ATAG support. A large number of platforms had enabled support but never supported a kernel so old as to require it. Further, some platforms are old enough to support both, but are well supported by devicetree booting, and have been for a number of years. This is because some of the ATAGs related functions have been re-used to provide the same kind of information, but for devicetree or just generally to inform the user. When needed still, rename these functions to get_board_revision() instead, to avoid conflicts. In other cases, these functions were simply unused, so drop them. Cc: Andre Przywara <andre.przywara@arm.com> Cc: Jagan Teki <jagan@amarulasolutions.com> Cc: Phil Sutter <phil@nwl.cc> Cc: Stefan Bosch <stefan_b@posteo.net> Signed-off-by: Tom Rini <trini@konsulko.com>
2021-07-07sniper: Add build guards around MUSB support codeTom Rini
If MUSB support is disabled, these parts of the code will fail to build. Cc: Paul Kocialkowski <contact@paulk.fr> Signed-off-by: Tom Rini <trini@konsulko.com>
2021-02-02common: Drop asm/global_data.h from common headerSimon Glass
Move this out of the common header and include it only where needed. In a number of cases this requires adding "struct udevice;" to avoid adding another large header or in other cases replacing / adding missing header files that had been pulled in, very indirectly. Finally, we have a few cases where we did not need to include <asm/global_data.h> at all, so remove that include. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2021-01-05dm: Rename U_BOOT_DEVICE() to U_BOOT_DRVINFO()Simon Glass
The current macro is a misnomer since it does not declare a device directly. Instead, it declares driver_info record which U-Boot uses at runtime to create a device. The distinction seems somewhat minor most of the time, but is becomes quite confusing when we actually want to declare a device, with of-platdata. We are left trying to distinguish between a device which isn't actually device, and a device that is (perhaps an 'instance'?) It seems better to rename this macro to describe what it actually is. The macros is not widely used, since boards should use devicetree to declare devices. Rename it to U_BOOT_DRVINFO(), which indicates clearly that this is declaring a new driver_info record, not a device. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-12-13dm: treewide: Rename ..._platdata variables to just ..._platSimon Glass
Try to maintain some consistency between these variables by using _plat as a suffix for them. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-12-13dm: treewide: Rename 'platdata' variables to just 'plat'Simon Glass
We use 'priv' for private data but often use 'platdata' for platform data. We can't really use 'pdata' since that is ambiguous (it could mean private or platform data). Rename some of the latter variables to end with 'plat' for consistency. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-09-01fastboot: Extend fastboot_set_reboot_flag with reboot reasonRoman Kovalivskyi
Extend fastboot_set_reboot_flag arguments with reboot reason so that it could handle different reboot cases in future. Signed-off-by: Roman Kovalivskyi <roman.kovalivskyi@globallogic.com>
2020-07-17treewide: convert bd_t to struct bd_info by coccinelleMasahiro Yamada
The Linux coding style guide (Documentation/process/coding-style.rst) clearly says: It's a **mistake** to use typedef for structures and pointers. Besides, using typedef for structures is annoying when you try to make headers self-contained. Let's say you have the following function declaration in a header: void foo(bd_t *bd); This is not self-contained since bd_t is not defined. To tell the compiler what 'bd_t' is, you need to include <asm/u-boot.h> #include <asm/u-boot.h> void foo(bd_t *bd); Then, the include direcective pulls in more bloat needlessly. If you use 'struct bd_info' instead, it is enough to put a forward declaration as follows: struct bd_info; void foo(struct bd_info *bd); Right, typedef'ing bd_t is a mistake. I used coccinelle to generate this commit. The semantic patch that makes this change is as follows: <smpl> @@ typedef bd_t; @@ -bd_t +struct bd_info </smpl> Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
2020-05-18common: Drop init.h from common headerSimon Glass
Move this uncommon header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-08-11env: Move env_set() to env.hSimon Glass
Move env_set() over to the new header file. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2018-05-30fastboot: Rename fb_set_reboot_flag to fastboot_set_reboot_flagAlex Kiernan
Rename fb_set_reboot_flag to fastboot_set_reboot_flag so it matches all other fastboot code in the global name space. Fix the guards around them so that they're dependent on FASTBOOT, not just USB_FUNCTION_FASTBOOT. Move the weak implementation of fastboot_set_reboot_flag to fb_common.c so we can call it from non-USB fastboot code. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-03-19ti: boot: Register the MMC controllers in SPL in the same way as in u-bootJean-Jacques Hiblot
To keep a consistent MMC device mapping in SPL and in u-boot, let's register the MMC controllers the same way in u-boot and in the SPL. In terms of boot time, it doesn't hurt to register more controllers than needed because the MMC device is initialized only prior being accessed for the first time. Having the same device mapping in SPL and u-boot allows us to use the environment in SPL whatever the MMC boot device. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2017-01-20serial, ns16550: bugfix: ns16550 fifo not enabledHeiko Schocher
commit: 65f83802b7a5b "serial: 16550: Add getfcr accessor" breaks u-boot commandline working with long commands sending to the board. Since the above patch, you have to setup the fcr register. For board/archs which enable OF_PLATDATA, the new field fcr in struct ns16550_platdata is not filled with a default value ... This leads in not setting up the uarts fifo, which ends in problems, when you send long commands to u-boots commandline. Detected this issue with automated tbot tests on am335x based shc board. The error does not popup, if you type commands. You need to copy&paste a long command to u-boots commandshell (or send a long command with tbot) Possible boards/plattforms with problems: ./arch/arm/cpu/arm926ejs/lpc32xx/devices.c ./arch/arm/mach-tegra/board.c ./board/overo/overo.c ./board/quipos/cairo/cairo.c ./board/logicpd/omap3som/omap3logic.c ./board/logicpd/zoom1/zoom1.c ./board/timll/devkit8000/devkit8000.c ./board/lg/sniper/sniper.c ./board/ti/beagle/beagle.c ./drivers/serial/serial_rockchip.c Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Tested-by: Adam Ford <aford173@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-04-01sniper: Change vendor name from lge to lg, matching devicetree vendor prefixPaul Kocialkowski
This moves the sniper board from the lge to lg, in order to match the devicetree vendor prefix already defined in the kernel. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
