path: root/board/lg
2018-05-30fastboot: Rename fb_set_reboot_flag to fastboot_set_reboot_flagAlex Kiernan
Rename fb_set_reboot_flag to fastboot_set_reboot_flag so it matches all other fastboot code in the global name space. Fix the guards around them so that they're dependent on FASTBOOT, not just USB_FUNCTION_FASTBOOT. Move the weak implementation of fastboot_set_reboot_flag to fb_common.c so we can call it from non-USB fastboot code. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-03-19ti: boot: Register the MMC controllers in SPL in the same way as in u-bootJean-Jacques Hiblot
To keep a consistent MMC device mapping in SPL and in u-boot, let's register the MMC controllers the same way in u-boot and in the SPL. In terms of boot time, it doesn't hurt to register more controllers than needed because the MMC device is initialized only prior being accessed for the first time. Having the same device mapping in SPL and u-boot allows us to use the environment in SPL whatever the MMC boot device. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2017-01-20serial, ns16550: bugfix: ns16550 fifo not enabledHeiko Schocher
commit: 65f83802b7a5b "serial: 16550: Add getfcr accessor" breaks u-boot commandline working with long commands sending to the board. Since the above patch, you have to setup the fcr register. For board/archs which enable OF_PLATDATA, the new field fcr in struct ns16550_platdata is not filled with a default value ... This leads in not setting up the uarts fifo, which ends in problems, when you send long commands to u-boots commandline. Detected this issue with automated tbot tests on am335x based shc board. The error does not popup, if you type commands. You need to copy&paste a long command to u-boots commandshell (or send a long command with tbot) Possible boards/plattforms with problems: ./arch/arm/cpu/arm926ejs/lpc32xx/devices.c ./arch/arm/mach-tegra/board.c ./board/overo/overo.c ./board/quipos/cairo/cairo.c ./board/logicpd/omap3som/omap3logic.c ./board/logicpd/zoom1/zoom1.c ./board/timll/devkit8000/devkit8000.c ./board/lg/sniper/sniper.c ./board/ti/beagle/beagle.c ./drivers/serial/serial_rockchip.c Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Tested-by: Adam Ford <aford173@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-04-01sniper: Change vendor name from lge to lg, matching devicetree vendor prefixPaul Kocialkowski
This moves the sniper board from the lge to lg, in order to match the devicetree vendor prefix already defined in the kernel. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
