path: root/board/lego/ev3
2018-06-05ARM: legoev3: update boot script to load uEnv.txt and .dtbDavid Lechner
This updates the LEGO MINDSTORMS EV3 boot script to try loading a uEnv.txt file and a da850-lego-ev3.dtb device tree during boot. Signed-off-by: David Lechner <david@lechnology.com>
2018-06-05ARM: legoev3: disable networkingDavid Lechner
This disables networking related items in the config. The EV3 does not have any networking hardware, so this is wasted space. Signed-off-by: David Lechner <david@lechnology.com>
2018-06-05ARM: legoev3: Move UART enable to early initDavid Lechner
This moves the UART init for LEGO MINDSTORMS EV3 to board_early_init_f(). Some console messages were not being printed because the UART was not enabled until later in the init process. Signed-off-by: David Lechner <david@lechnology.com>
2018-06-05ARM: legoev3: increase flash image sizesDavid Lechner
This increases the kernel image to 4M and the rootfs image to 10M. It is getting hard to get a kernel image to fit in 3M. Signed-off-by: David Lechner <david@lechnology.com>
2017-06-05arm: Include asm/setup.h explictlySimon Glass
Include this header where needed so we do not need to rely on common.h. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-05arm: Add explicit include of <asm/mach-types.h>Simon Glass
Rather than relying on common.h to provide this include, which is going away at some point, include it explicitly in each file. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-04-06Remove various unused interrupt related codeTom Rini
With d53ecad92f06 some unused interrupt related code was removed. However all of these options are currently unused. Rather than migrate some of these options to Kconfig we just remove the code in question. The only related code changes here are that in some cases we use CONFIG_STACKSIZE in non-IRQ related context. In these cases we rename and move the value local to the code in question. Fixes: d53ecad92f06 ("Merge branch 'master' of git://git.denx.de/u-boot-sunxi") Signed-off-by: Tom Rini <trini@konsulko.com>
2017-01-11mmc: move more driver config options to KconfigMasahiro Yamada
Move (and rename) the following CONFIG options to Kconfig: CONFIG_DAVINCI_MMC (renamed to CONFIG_MMC_DAVINCI) CONFIG_OMAP_HSMMC (renamed to CONFIG_MMC_OMAP_HS) CONFIG_MXC_MMC (renamed to CONFIG_MMC_MXC) CONFIG_MXS_MMC (renamed to CONFIG_MMC_MXS) CONFIG_TEGRA_MMC (renamed to CONFIG_MMC_SDHCI_TEGRA) CONFIG_SUNXI_MMC (renamed to CONFIG_MMC_SUNXI) They are the same option names as used in Linux. This commit was created as follows: [1] Rename the options with the following command: find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e ' s/CONFIG_DAVINCI_MMC/CONFIG_MMC_DAVINCI/g s/CONFIG_OMAP_HSMMC/CONFIG_MMC_OMAP_HS/g s/CONFIG_MXC_MMC/CONFIG_MMC_MXC/g s/CONFIG_MXS_MMC/CONFIG_MMC_MXS/g s/CONFIG_TEGRA_MMC/CONFIG_MMC_SDHCI_TEGRA/g s/CONFIG_SUNXI_MMC/CONFIG_MMC_SUNXI/g ' [2] Commit the changes [3] Create entries in driver/mmc/Kconfig. (copied from Linux) [4] Move the options with the following command tools/moveconfig.py -y -r HEAD \ MMC_DAVINCI MMC_OMAP_HS MMC_MXC MMC_MXS MMC_SDHCI_TEGRA MMC_SUNXI [5] Sort and align drivers/mmc/Makefile for readability Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Marek Vasut <marex@denx.de>
2016-03-14arm: Add support for LEGO MINDSTORMS EV3David Lechner
This is based on the davinci da850evm. It can boot from either the on-board 16MB flash or from a microSD card. It also reads board information from an I2C EEPROM. The EV3 itself initally boots from write-protected EEPROM, so no u-boot SPL is needed. Signed-off-by: David Lechner <david@lechnology.com> Reviewed-by: Tom Rini <trini@konsulko.com>
