path: root/board/laird
2017-11-29board: laird: add WB50N CPU moduleBen Whitten
This board is based on the Atmel sama5d3 eval boards. Supporting the following features: - Boot from NAND Flash - Ethernet - FIT - SPL Signed-off-by: Ben Whitten <ben.whitten@lairdtech.com> Signed-off-by: Dan Kephart <dan.kephart@lairdtech.com>
2017-11-29board: laird: add WB45N CPU moduleBen Whitten
This board is based on the Atmel 9x5 eval board. Supporting the following features: - Boot from NAND Flash - Ethernet - FIT - SPL Signed-off-by: Ben Whitten <ben.whitten@lairdtech.com> Signed-off-by: Dan Kephart <dan.kephart@lairdtech.com>
