path: root/board/laird/wb50n
2020-07-17treewide: convert bd_t to struct bd_info by coccinelleMasahiro Yamada
The Linux coding style guide (Documentation/process/coding-style.rst) clearly says: It's a **mistake** to use typedef for structures and pointers. Besides, using typedef for structures is annoying when you try to make headers self-contained. Let's say you have the following function declaration in a header: void foo(bd_t *bd); This is not self-contained since bd_t is not defined. To tell the compiler what 'bd_t' is, you need to include <asm/u-boot.h> #include <asm/u-boot.h> void foo(bd_t *bd); Then, the include direcective pulls in more bloat needlessly. If you use 'struct bd_info' instead, it is enough to put a forward declaration as follows: struct bd_info; void foo(struct bd_info *bd); Right, typedef'ing bd_t is a mistake. I used coccinelle to generate this commit. The semantic patch that makes this change is as follows: <smpl> @@ typedef bd_t; @@ -bd_t +struct bd_info </smpl> Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
2019-12-02common: Move some board functions out of common.hSimon Glass
A number of board function belong in init.h with the others. Move them. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-10-08ARM: at91: Rename sama5_sfr.h to at91_sfr.hTudor Ambarus
The Special Function Registers (SFR) are present in sam9x5 and sam9x60 too, rename sama5_sfr to at91_sfr.h. Signed-off-by: Tudor Ambarus <tudor.ambarus@microchip.com>
2019-10-08board: laird: wb50n: use configure_ddrcfg_input_buffersEugen Hristev
Replace code with new function configure_ddrcfg_input_buffers from SFR mach driver. Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
2019-08-11env: Move env_set() to env.hSimon Glass
Move env_set() over to the new header file. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-11-29board: laird: add WB50N CPU moduleBen Whitten
This board is based on the Atmel sama5d3 eval boards. Supporting the following features: - Boot from NAND Flash - Ethernet - FIT - SPL Signed-off-by: Ben Whitten <ben.whitten@lairdtech.com> Signed-off-by: Dan Kephart <dan.kephart@lairdtech.com>
