path: root/board/l+g
2020-07-17treewide: convert bd_t to struct bd_info by coccinelleMasahiro Yamada
The Linux coding style guide (Documentation/process/coding-style.rst) clearly says: It's a **mistake** to use typedef for structures and pointers. Besides, using typedef for structures is annoying when you try to make headers self-contained. Let's say you have the following function declaration in a header: void foo(bd_t *bd); This is not self-contained since bd_t is not defined. To tell the compiler what 'bd_t' is, you need to include <asm/u-boot.h> #include <asm/u-boot.h> void foo(bd_t *bd); Then, the include direcective pulls in more bloat needlessly. If you use 'struct bd_info' instead, it is enough to put a forward declaration as follows: struct bd_info; void foo(struct bd_info *bd); Right, typedef'ing bd_t is a mistake. I used coccinelle to generate this commit. The semantic patch that makes this change is as follows: <smpl> @@ typedef bd_t; @@ -bd_t +struct bd_info </smpl> Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
2020-06-29spi: Convert CONFIG_DM_SPI* to CONFIG_$(SPL_TPL_)DM_SPI*Lukasz Majewski
This change allows more fine tuning of driver model based SPI support in SPL and TPL. It is now possible to explicitly enable/disable the DM_SPI support in SPL and TPL via Kconfig option. Before this change it was necessary to use: /* SPI Flash Configs */ #if defined(CONFIG_SPL_BUILD) #undef CONFIG_DM_SPI #undef CONFIG_DM_SPI_FLASH #undef CONFIG_SPI_FLASH_MTD #endif in the ./include/configs/<board>.h, which is error prone and shall be avoided when we strive to switch to Kconfig. The goal of this patch: Provide distinction for DM_SPI support in both U-Boot proper and SPL (TPL). Valid use case is when U-Boot proper wants to use DM_SPI, but SPL must still support non DM driver. Another use case is the conversion of non DM/DTS SPI driver to support DM/DTS. When such driver needs to work in both SPL and U-Boot proper, the distinction is needed in Kconfig (also if SPL version of the driver supports OF_PLATDATA). In the end of the day one would have to support following use cases (in single driver file - e.g. mxs_spi.c): - U-Boot proper driver supporting DT/DTS - U-Boot proper driver without DT/DTS support (deprecated) - SPL driver without DT/DTS support - SPL (and TPL) driver with DT/DTS (when the SoC has enough resources to run full blown DT/DTS) - SPL driver with DT/DTS and SPL_OF_PLATDATA (when one have constrained environment with no fitImage and OF_LIBFDT support). Some boards do require SPI support (with DM) in SPL (TPL) and some only have DM_SPI{_FLASH} defined to allow compiling SPL. This patch converts #ifdef CONFIG_DM_SPI* to #if CONFIG_IS_ENABLED(DM_SPI) and provides corresponding defines in Kconfig. Signed-off-by: Lukasz Majewski <lukma@denx.de> Tested-by: Adam Ford <aford173@gmail.com> #da850-evm Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> [trini: Fixup a few platforms] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-01-17common: Move RAM-sizing functions to init.hSimon Glass
These functions relate to memory init so move them into the init header. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-04-06at91: vinco: Enable DM_SPIJagan Teki
AT91 Vinco board uses atmel spi driver, enable DM_SPI to use dm functionality. Cc: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2017-04-13gpio: at91_gpio: remove CPU_HAS_PIO3 macroWenyou Yang
The intention of the removal is the preparation to introduce the new AT91 PIO pinctrl driver. Use the union to make the PIO3 and PIO2's registers be together and make their offset aligned. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-02-20vinco: add Maintainers fileAndreas Bießmann
Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Gregory CLEMENT <gregory.clement@free-electrons.com>
2016-02-19ARM: Add Support for the VInCo platformGregory CLEMENT
The Versatile Industrial Communication platform is a community oriented board from Landis + Gyr. It comes with: - an RS-485 port - 2 Ethernet ports - a wireless M-BUS - a 4G modem - a 4MB SPI flash - a 4GB eMMC Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> [rebase on current TOT] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
